  • AlessandroEmm
  • AlessandroEmm
17 Feb 2026 20:13
So in the meanwhile, without working UI I tried to test comms with halcmd.
Does
4 bit IN TRUE remora.SPI-enable
4 bit IN TRUE remora.SPI-reset
4 bit OUT TRUE remora.SPI-status
actually mean there was some comms? UART doesnt show anything though.
  • PCW
  • PCW's Avatar
17 Feb 2026 20:01
Replied by PCW on topic HURCO KMB-1 Control Update
Category: Milling Machines
If it's open loop, the question becomes what is changing the analog out command?
(bottom trace second plot)
  • Clark222
  • Clark222
17 Feb 2026 19:49
Strange Gantry Squaring/Homing was created by Clark222
Category: Basic Configuration
Hi - I've gotten Linuxcnc to work well on several machines but each time the machine wasn't constructed with enough precision to make it reliably work the way I wanted.  On this machine I finally built it the way I should have.  I used the files from my old machine and adapted them to this machine If something is commented out it is because I haven't got to that yet.  The machine moves great and the X and Z axis move and home really good.  The Y axis moves good but I can't get it to home properly. If things are set up so that each axis has a pnp sensor on side will respond to the sensor but the other side will turn off the led acknowledging it should home but it keeps moving towards the sensor.  If I tie both sides to a single side it works as expected.  This is fine but it prevents squaring.  I've included my files so maybe somebody could see where I've gone wrong.
  • NT4Boy
  • NT4Boy
17 Feb 2026 19:22
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Peter,
No its open loop. I've got all the gains at zero bar FF0=1.
I do have an encoder though.
  • AlessandroEmm
  • AlessandroEmm
17 Feb 2026 19:20 - 17 Feb 2026 19:48
Not really sure whats going on now as I run into segfaults. I havent changed a thing on linuxcnc side, i just changed the config.txt on the SD Card
line 977: 2610 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
Before that I haven't seen anything in the terminal or anywhere, thats why I'm a bit puzzled. Yes I compiled it from main branch, using OS6 Version for the Firmware and likewise for the hal component.
Is there a way to just test it with the halcmd? I tried loading the remora component, but struggle beyond. Show pins shows no active session.
Both the debug file and the regular logfile are basically empty with no specifics concerning the error.
Thanks!
  • 2tinker
  • 2tinker
17 Feb 2026 19:18
Replied by 2tinker on topic AMB FME-U 1400 DI
AMB FME-U 1400 DI
Category: Deutsch
Ehrlich ist gut. Danke für deine Einschätzung.
Was spricht gegen Kohlebürsten?
Die Lautstärke sollte man sicherlich beachten.
Die Frage für mich wäre, wie Laut es wird, wenn der Fräser durchs Material fährt.
Wasserkühlung ist mir zu aufwändig.
Danke für den Hinweis bezüglich des Dauerbetriebes.
Da werde ich bei AMB noch mal nachfragen.
  • tuxcnc
  • tuxcnc
17 Feb 2026 18:56
Replied by tuxcnc on topic EtherCAT driver as simply positioner
Category: EtherCAT
I done some investigations, and it seems my driver is simplified as possible and supports only homing and CSP modes.
There are no registers for velocity and acceleration, the driver uses internal default values.
In LinuxCNC xml configuration you can create hal pins for non existent registers and you can write to them, but it not affect the driver.
My bash script is far of dreams, but works.
  • PCW
  • PCW's Avatar
17 Feb 2026 18:55
If this is closed loop, I would check for issues with the encoder setup
or PID setup
Is the encoder velocity used for feedback?
  • PCW
  • PCW's Avatar
17 Feb 2026 18:50
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
Sounds like you need to set the frequency scale to .390625
  • amanker
  • amanker
17 Feb 2026 18:49
You should post complete serial console output. It will make diagnosis easier.
You should start LinuxCNC from terminal. And terminal window what msg you get when you press estop button in lcnc gui. Is it spi_payload = 0 or something else?
Did you compiled and installed remora-spi lcnc component from same repository?
  • Finngineering
  • Finngineering
17 Feb 2026 18:45
Replied by Finngineering on topic XHC WHB04B development?
If the interrupt endpoint is not continuously polled, you get the disconnects. But also the xhc-whb04b-6 component keeps it from disconnecting, at least in most situations. You can run that directly from the terminal, for instance with "xhc-whb04b-6 -a" to enable all logging, and you will see that the pendant will not disconnect.
So in this "easy" situation, there is not much difference between the three programs. We know that the pendant disconnects in a long-time stress test with the xhc-whb04b-6 component and LinuxCNC running. I'm not sure either of the other programs would do any better in similar situations.
  • DerKlotz
  • DerKlotz
17 Feb 2026 18:35
Replied by DerKlotz on topic Add Buttons in Probe Basic
Category: QtPyVCP
Great, i´ll check tomorrow.
  • AlessandroEmm
  • AlessandroEmm
17 Feb 2026 18:30
Hey there
After having successfully used a NVEM flashed Remora via Ethernet for a while, I want to use an old 3d printer board (SKR E3 Mini v2.0) via SPI for my Plasma. It took me a while but eventually i got it to respond correctly via UART, and am currently sitting at
Starting the SERVO thread
Registering interrupt for interrupt number = 28
        power on Timer 2
## Entering IDLE state
Problem is that I struggle to make any communication via SPI. I think I triple checked every wire. As the SKR Mini Configuration in the repo seems to be for a version 1.2 of the board i modified the pins both in the firmware and config.txt, taking care of not using anything that may conflict with other function. But so far no nothing.
Is there any way to approach debug/test anything further to narrow down why the comms doesn't seem to work?
Thanks a lot,
Alessandro
  • Hakan
  • Hakan
17 Feb 2026 18:26
Replied by Hakan on topic XHC WHB04B development?
I mean, what do your program and usbhid-dump do that stop the disconnect/reconnects?
And why doesn't the whb04b component do the same?
Rhetorical question.
I looked briefly at the codes, but this is a big hurdle..
  • Stephan@work
  • Stephan@work
17 Feb 2026 18:16
I'm back !
With some good new !
I figured out my Problem. (read the fvck!ng manual :D )
For some reasons, you have to decrement the Register address by one for "run" and "reverse".
Now I'm struggling with the command-frequency.
I can run the Vdf using the Mesa pktuart. But I there is still a scaling of 2.56
If i send 10Hz to the Vdf, the displayed frequency on my OmronMx2 show me 25.6Hz
same as 100Hz. Vdf - 256 Hz
I checked all combinations of U_AB, U_BA, S_AB, S_BA, F_AB, F_BA.
Did i miss something or choose the wrong LSB/MSB ?
Same as Motor Current.
Heatsink-temperature works pretty well.
<mesamodbus baudrate="9600" parity="N" interval="10000" stopbits="1" duplex="half">
  <devices>
    <device name="omronmx2" address="0x01"/>
  </devices>
  <initlist>
    <command device="omronmx2" address="0x0000" function="W_COIL">
      <description>Zero Operation</description>
      <data value="0"/>
    </command>
    <command device="omronmx2" address="0x0001" function="W_COIL">
      <description>Reverse Operation</description>
      <data value="0"/>
    </command>
  </initlist>
  <commands>
      <command device="omronmx2" address="0x0000" function="W_COIL"       name="run"/>
      <command device="omronmx2" address="0x0001" function="W_COIL"       name="reverse"/>
      <command device="omronmx2" address="0x0001" function="W_REGISTER"   name="cmd-freq"       haltype="HAL_FLOAT" modbustype="U_BA"/>
      <command device="omronmx2" address="0x0018" function="R_COILS"      name="is-at-speed"    count="1"/>
      <command device="omronmx2" address="0x0017" function="R_COILS"      name="watchdog-out"   count="1"/>
      <command device="omronmx2" address="0x0012" function="R_COILS"      name="is-running"     count="1"/>
      <command device="omronmx2" address="0x1002" function="R_REGISTERS"  name="motor-current"  haltype="HAL_FLOAT" modbustype="S_AB" count="1"/>
      <command device="omronmx2" address="0x1018" function="R_REGISTERS"  name="heatsink-temp"  haltype="HAL_FLOAT" modbustype="F_BA" count="2"/>
  </commands>
</mesamodbus>
Displaying 6856 - 6870 out of 12578 results.
Time to create page: 0.373 seconds
