  • NWE
  • NWE's Avatar
02 Feb 2026 23:35
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
Most PLC's and touchscreen HMIs do pretty much everything in their software. For workcell controllers intended for operator safety, you need a combination of hardwired safety controllers and power disconnects that can be locked. LinuxCNC has many available interfaces for communicating with PLCs. Ethercat, discrete I/O, analog, RS232, RS485, CAN, Modbus TCP, Modbus RTU. Probably more. Safety controlling is outside the domain of LinuxCNC.
On systems where the PLC/computer automatically start/stop 250HP machines or even 1/4HP machines, every machine on the premises has a dedicated power disconnect switch that can be locked. If that disconnect switch is on, the machine must be assumed to be running, whether or not it is making noise. Everything is prominently labeled with danger signs, reminding personel that the process equipment starts/stops automatically.
Plus we have the hard wired safety circuit that disables everything and only communicates to LinuxCNC that it has been disabled. LinuxCNC cannot activate this safety circuit. Not even an industrial PLC is qualified to run this safety circuit, only dedicated fail-safe safety controllers do that.
  • NWE
  • NWE's Avatar
02 Feb 2026 22:43 - 02 Feb 2026 23:07
MAC address not retrieved (after 2 years stop)
Category: Driver Boards
Jocman post=342013 userid=24026
As I've 2 lan cards (the onboard and a second PCI board), I tried to launch
ip a
when connected to both, and this is what I get:
connected to Mesa (onboard card):
joccnc@JocCnc:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
-- snip --
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether e8:4e:06:84:dc:c9 brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.11/8 brd 10.255.255.255 scope global eth0
-- snip --
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 70:85:c2:6a:f0:3d brd ff:ff:ff:ff:ff:ff
joccnc@JocCnc:~$
and pinging  my router:
joccnc@JocCnc:~$ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
ping: sending packet: Network is unreachable
connected to WEB:
-- snip --
    inet 192.168.1.245/24 brd 192.168.1.255 scope global dynamic eth0
-- snip --
joccnc@JocCnc:~$
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=0.651 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.488 ms
[\quote]
Going by your most recent answer I interpret the above:
It appears to me you have two network configurations "Web" and "Mesa 7i76e" In both configurations you appear to have the first network port selected. This means, when you click on the "Mesa 7i76e" network, the pc tries to connect to the Mesa card via the network port that is connected to your LAN.
To fix, right-click on the network icon, click "edit connections", click on "Mesa 7i76e", click on the little gear at bottom "edit the selected connection", click on the "Device" dropdown, and select the correct device, click on "IPv4 Settings" tab, make sure the "Gateway" field is empty. click "Save", close the network edit window, and try reconnecting to both networks. On my system, I have both networks connected at the same time.
Don't change settings for the "Web" connection, from what I see, that one is likely configured correctly.
  • Hakan
  • Hakan
02 Feb 2026 21:46
Replied by Hakan on topic Cia402 no connection
Category: EtherCAT
Sounds like you forgot to enable ethercat service and it didn't start at boot.
Some 30 lines down in this post
forum.linuxcnc.org/ethercat/45336-etherc...step-by-step?start=0
tells you how to check status of the ethercat service and, if needed, enable it for automatic start at boot.
  • grzester
  • grzester
02 Feb 2026 21:32
Replied by grzester on topic Cia402 no connection
Category: EtherCAT
...when Beckhoff EK1100 is connected terminal give such information
  • grzester
  • grzester
02 Feb 2026 21:24
Category: EtherCAT
Hallo, a litle explanation and  update. Altough LCNC is starting but ethercat connection is not activated.Normaly when I work with Beckhoff EK1100 i see small icon ethercat up on the screen and also i can write terminal command Ethercat Slaves it showing me active participiants.
Also when I try   ...ip link set dev ... down / up   it doesnt work to.It looks like driver dont try to start at all when I try to connect oriental motor.
What can I do more ,how to test why eth driver dont start/trying to run.
Thanks.
02 Feb 2026 20:34
Replied by tommylight on topic Forum Fehler, ... :-(
Category: Deutsch
Can you post from a phone or a tablet?
  • Muecke
  • Muecke's Avatar
02 Feb 2026 19:50
Forum Fehler, ... :-( was created by Muecke
Category: Deutsch
Ich würde ja wirklich gerne auf mein eigenes Thema antworten, doch das Forum meint, es gäbe einen internen Fehler. :-(
  • tar_san
  • tar_san
02 Feb 2026 18:23
Replied by tommylight on topic Raspberry pi 5 freze
Can you run LinuxCNC from the terminal and copy/paste the errors reported when that happens?
Usually linuxcnc -l should start last used config.
  • krille
  • krille
02 Feb 2026 18:08
Raspberry pi 5 freze was created by krille
Hi and so much thanks to the people made all the work with the linuxcnc for raspberry pi 5 ,its a great job.
I have downloaded 4.8.9 and it's a great distro working so fine from beguining and today after a week or two the program stop and freze after 5-10 min. I can still run the stepper from the keyboard and the speedometer on the spindle is i ok and run but the rest of the program stop . the only way to go on is a hard rebot and then it start fine and then the problem starts again . Are there people who can help me in the right direction
I use the byte2bot board in Lathe config. /krister
  • opw
  • opw
02 Feb 2026 15:19
Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
Hi guys,
Created this simple, but effective profile editor for myself.
It is a lightweight Tk-based conversational editor for lathe profiles, designed for LinuxCNC / PathPilot style workflows.It lets you sketch, edit, and preview turning profiles interactively, then generates a G71 or G72 roughing cycle with a G70 finish pass. All core functionality uses only the Python standard library (Tk), so it can be dropped directly into a AXIS environment.Optional DXF / 3MF import is supported via external libraries.
For example you can:
  1. import an STL as a background reference
  2. Auto create segment points or (recommended) tracing the rotational outline with profile points
  3. Adding chamfers and radii for finishing details
  4. Adjusting geometry for optimal cutting
  5. Setting machining parameters
  6. Generating G-code
  7. Sending to LinuxCNC/AXIS
 You can find it here:  Repository
  • djdelorie
  • djdelorie
02 Feb 2026 15:05
Replied by djdelorie on topic Where should linux cnc tool offsets be stored?
I will add, though, that when I started using my ATC I mixed the old and new ways, and it was a disaster :-)
  • djdelorie
  • djdelorie
02 Feb 2026 15:04
I suspect ALL cnc's apply offsets the same way. And as long as the offsets add up to the right tool location, it doesn't matter if you change G54 or T1 when you manually change tools. If you're using a trim router with a collet and change tools all the time but never issue a T command, you just have to know how to change the G54 so that it does the right thing.
So external measurement, toolsetters, manual tool touch off, part touch off, they're all just ways of making those offsets add up to the right thing.
  • ruediger123
  • ruediger123
02 Feb 2026 14:35
Replied by ruediger123 on topic LinuxCNC S-Curve Accelerations
@grandixximo
In the blue circles, the jerk is outside the limits.
In the red circle, the speed of the axis should, in my opinion, always be the same.
  • Hakan
  • Hakan
02 Feb 2026 14:20
Umstieg von LinuxCNC + Mesa auf EtherCAT (Leadshine EL8 / Beckhoff) – Erfahrunge
Category: Deutsch
Is there much to say about it? Both Mesa and EtherCAT work, and work well.
We do miss an EtherCAT documentation page linuxcnc.org/docs/devel/html/.
Much info is scattered here in the forum and at a few github pages. This could be better.
It's not uncommon to have some configuration issues, specifically with the ethercat-conf.xml file.
This adds to the complexity. Mesa has a pncconf tool, there is nothing similar for EtherCAT.
The forum people can come to help if you get stuck on that.
Once configured, my impression is that an EtherCAT system just runs.
Both parallel ports and Mesa have their weak points but people have worked around them for many years and don't see them anymore.
EtherCAT has one unique weak point  forum.linuxcnc.org/ethercat/58227-how-go...trol?start=10#341798
which isn't to difficult to work around.
Your Leadshine EL8 drives have several digital IOs that you can use for general purposes.
This may make the Beckhoff components redundant. Worth checking.
Displaying 7591 - 7605 out of 12629 results.
Time to create page: 0.592 seconds
