  • clayton2ndtry
  • clayton2ndtry
29 Jan 2026 23:36 - 30 Jan 2026 00:05
Replied by clayton2ndtry on topic Can't issue MDI command when not homed
Category: AXIS
Boy that was easy. I guess I never tried this before without homing every axis.  Thank you!
29 Jan 2026 23:26
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
Actually, I have something around 8°C thats not very comfortable for sitting and fiddeling in my garage.
Well, 3 days ago this was me in my shop and the temperature was 4 degree C, in a t-shirt for 20 to 30 minutes at a time, nearly 2 hours in total "freezing" time.
Recorded a PC build as i had several PC's to build and i rarely record anything, so this time called the services of my brothers photo/video studio, so it should be good.
29 Jan 2026 22:39
Replied by tommylight on topic Can't issue MDI command when not homed
Category: AXIS
Machine must have all axis/joints homed before issuing MDI commands or running in Auto mode.
Or to put it your way, all axis must have the little diamond in front on DRO
29 Jan 2026 22:37
Replied by tommylight on topic Empty
Empty
Category: Forum Questions
What was your user name?
  • IndeeSales
  • IndeeSales's Avatar
29 Jan 2026 22:25
Stepperonline Y series/ YAKO YKD2608PE configuration
Category: EtherCAT
Hello I have been trying to get theses stepper drives configured along with a beckhoff EK1100 and have had no luck at all. I have followed the Ethercat step by step instructions and seem to have hit a wall. Any help would be appreciated. Attached is my pdos and ethercat slaves
File Name: ethercatslaves.txt
File Size:0 KB
File Name: ethercatpdos.txt
File Size:4 KB
  • rodw
  • rodw's Avatar
29 Jan 2026 21:47
Replied by rodw on topic LinuxCNC S-Curve Accelerations
The CiA 402 standard provides feedforward objects exactly for this: 0x60B1 (velocity offset) and 0x60B2 (torque offset). The master can send position plus velocity feedforward so the drive can anticipate acceleration. This is the standard's solution, it just needs to be mapped in lcec.
Also, good drives interpolate internally. The servo loop runs faster than the bus cycle (Maxon runs 0.4ms internal vs 1ms bus). The drive doesn't jump between positions, it interpolates. That's what 0x60C2 configures.
Can we explore this on another topic when I get to it? I wanted to rewrite dominic's cia402 component to make it easier to maintain and properly deal with homing so it comes into line with the custom homing that wasn't around when it was written. So it would be perfect for inclusion. Could the new TP have output pins that could be taken as input to calculate these?   Or how would we do it? Any conversion/massaging would be done in the revised component.
  • bobwolf
  • bobwolf
29 Jan 2026 21:11
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
Thanks, I had an error in the rules file, that's why that error appeared.
Thanks COFHAL! You're right, I found the typo in the README and demo files. I missed a curly bracket in the
ENV{ID_MM_DEVICE_IGNORE}
part of the udev rule.I've just pushed the fix to the repository. This is exactly why community feedback is so important! Now everything should set up correctly with a simple copy-paste.
  • IndeeSales
29 Jan 2026 21:05
Replied by IndeeSales on topic Ethercat Leadshine L6N Gantry XYYZ Config
Category: EtherCAT
Could you post your CoreDC.hal file? I am trying to setup a gantry router with steppersonline ethercat drives. and have hit a wall with this setup
  • Muftijaja
  • Muftijaja
29 Jan 2026 20:58
Category: Deutsch
Dear tommylight, well, I didn't try that until now. I will have that in mind if I get back to my machine at better temperatures. Actually, I have something around 8°C thats not very comfortable for sitting and fiddeling in my garage.
I will come back asap.
  • Muftijaja
  • Muftijaja
29 Jan 2026 20:54
Category: Deutsch
Moin Andrax, die Idee ist super. Tatsächlich habe ich beim Servo den zugehörigen Bremswiderstand aber immer angeschlossen gehabt.
Dagegen spricht, dass ich die gleichen Abweichungen beim Tausch auf einen 3,5 Nm CL Stepper auch hatte.
Momentan hab ich noch Winterpause, meine Garage mit der Fräse ist nur 8° kalt, das ist zu ungemütlich um da große Diagnostik zu machen.
Was ich schon vorbereitet habe ist der (vorübergehende) Wechsel von LCNC zu einer Estlcam Controller Karte, bei der man nichts verfusen kann an Motoreinstellungen. ICh will wissen, ob ich weiter an der MEchanik suchen muss oder in der Konfig von LCNC. Aber auch dafür brauche ich etwas mehr Temperatur im Raum. Danke für Deinen Input,ich melde mich wieder!
Hi Andrax, that's a great idea. Actually, I always had the corresponding braking resistor connected to the servo.
The downside is that I had the same deviations when switching to a 3.5 Nm CL stepper.
I'm currently on winter break, and my garage with the milling machine is only 8°C, which is too uncomfortable to do any major diagnostics.
What I have already prepared is the (temporary) switch from LCNC to an Estlcam controller card, where you can't mess up the motor settings. I want to know whether I need to continue looking at the mechanics or at the LCNC configuration. But for that, I also need a slightly warmer room temperature. Thanks for your input, I'll be in touch!
  • bobwolf
  • bobwolf
29 Jan 2026 20:52
So.....you are wanting testers for a closed source hardware project ;)
What's in it for the testers ? :)
I don't want you to be my free testers.
To do this project I came up with, I first experimented on a breadboard and then created the PCBs with the features I wanted. Unfortunately, I made some youthful mistakes in hardware development... trivial but significant...
I redid the PCB designs but haven't ordered them from the service yet. For now, I've already spent enough money on a "gamble."
If you want, there are some kits that need fixing, so it would arrive with various jumpers soldered on the fly.
In any case, the eval version is fully functional like the final one, but it doesn't have all the peripherals enabled.
  • Will_cnc
  • Will_cnc
29 Jan 2026 20:51
Issues setting up Tool setter / manual tool change
Category: QtPyVCP
Hi all,I’m currently having trouble setting up a tool presetter in LinuxCNC. My setup consists of a Raspberry Pi 5 running LinuxCNC, three Leadshine servo motors, and a Beckhoff unit handling the toolsetter input.
The main issue is that when I press “Set Tool Offset PSO,” LinuxCNC does not apply the current machine coordinates. Also, when attempting to perform a tool height setting, nothing happens.
I’m also experiencing problems with manual tool changes. When using the Unload Tool or Load Tool commands, nothing occurs. The only way I can trigger a tool change is by using an M6 T"x" command, which brings up a popup asking for confirmation that the tool has been changed.I have not yet connected the solenoid valve that will actuate the drawbar.
I’ve attached my HAL and INI files. Any suggestions or ideas would be appreciated.
  • bobwolf
  • bobwolf
29 Jan 2026 20:35
2. Closed Firmware & 'Over-engineering' I respect the Open Source philosophy, but io_decoder is a professional project that includes dedicated hardware. The 'over-engineering' you see in the HAL driver is actually optimization. While a user-space component can work, a dedicated C component ensures deterministic polling and much lower jitter. If you want a 'professional feel' on the handwheel, those milliseconds matter.
ahh, ok, This is what professional code looks like when compiling.
halcompile --compile io_decoder.c
Compiling realtime io_decoder.c
MEGACUT
[i][i][i][i][i][i]Linking io_decoder.so[/i][/i][/i][/i][/i][/i]
[i][i][i][i][i][i]“Bare-Metal” Firmware (No Bootloader)
We have removed the Arduino bootloader for two critical reasons:
Safety: No random pin state changes during startup (typical of bootloaders).
Speed: The board is operational within a few milliseconds.
what about updates ?[/i][/i][/i][/i][/i][/i]
Thank you for alerting me to all those warnings... apparently my system is set up so that I don't see them... I'll try to fix everything in the next few days... they're all warnings for things I left lying around due to closed roads and changes of direction in the program.
As for the choice to remove the bootloader, it's because I didn't want every communication, which occurs every 20ms, to waste time trying to figure out whether it was a new program or a regular message about the work it's doing.
If you want to modify the firmware, you need to use a programmer like tinyusb.
  • bobwolf
  • bobwolf
29 Jan 2026 20:18 - 29 Jan 2026 20:22
I use Arduino Connector, I really like your project, it's very professional. I don't know if you plan to create matrix-type keyboards to simulate keys or to be used as HAL pins like in Arduino Connector, which gives great flexibility.
There's no direct support for a matrix keyboard; I had considered it during the project development phase, but I was too far along and would have had to completely overhaul everything... perhaps in a future version...
However, all the inputs have the keyboard functionality that allows them to send keyboard characters with the physical input pins.
the only difference is that you have to wire all the buttons one wire for each button + the common which must come from the io_decoder board
It's all explained in the docs on GitHub.
  • juliankoenig87
  • juliankoenig87
29 Jan 2026 20:14
Replied by juliankoenig87 on topic How can I contact juliankoenig87
how can I help you exactly?
Displaying 7741 - 7755 out of 12610 results.
Time to create page: 0.619 seconds
