  • prokopcio
  • prokopcio's Avatar
21 Jan 2026 22:16
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
A test device would be great. What information do you need to get it to me?
Are you still interested and would you have time to test the sensor?
If so, please contact me, preferably through the Proma-Elektronika contact page.
  • grandixximo
  • grandixximo's Avatar
21 Jan 2026 22:06
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Did you build ehtercat yourself?
My two cents, don't use the official build, make one yourself with disable EoE disabled, and use good shielded cables.
  • prokopcio
21 Jan 2026 21:41
Hi, Unfortunately, I have no experience with Aerotech.
As I mentioned, the sensor was developed for my own needs, but I would like it to be easy to use also in open-source control systems such as LinuxCNC.
Trying to use it at this stage in closed, good working solutions does not make sense.
I appreciate your willingness to support me, but at this point it is not a good idea.
  • grandixximo
21 Jan 2026 21:23 - 22 Jan 2026 07:26
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I get notifications, I do check on them when I am free...
Edit:
YangYang also replied, those will be fixed, but we have bigger fish to fry now, we are working on arc stopping, and some other arc blending related issues.
  • grzester
  • grzester
21 Jan 2026 20:58 - 21 Jan 2026 21:06
Cia402 no connection was created by grzester
Category: EtherCAT
  Hallo guys , at the begining I woud like to thanks for that great forum.I'm trying to connect ethercat device like ORIENTAL MOTOR AZD4A-KED but with no lack.At first i run ethercat on ek1100 and some io -> evrything is working fine ,therefor I know that System is working properly also lan card .Second step connection Oriental drive , but there is no connection , when I type in terminal Ethercat slaves there is nothing.I know that unit is able to work properly because I tested it under Twincat3.Some info about thesystem:drive :    oriental motor azd4a-ked compatibility cia402.system : Linux grzesiekzxr 6.1.0-30-rt-amd64. Thank you in advance for your help.
Attachment not found
File Name: dmesgcan402_1.txt
File Size:3 KB
File Name: axis_2026-01-21.ini
File Size:5 KB
File Name: ethercatCA...1-21.hal
File Size:3 KB
File Name: ethercat-c...1-21.xml
File Size:1 KB
  • cncfreak
  • cncfreak
21 Jan 2026 19:21
Replied by cncfreak on topic asd-a2-e ... lcec driver?
Category: EtherCAT
Try this xml file.
File Name: ASDA_A2E.xml
File Size:2 KB
File Size:2 KB
  • Mbrand1901
  • Mbrand1901
21 Jan 2026 19:15
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Hello everyone!
Does anyone of you guys have the 257 411 01 EXE Platine? Und does anyone have a exakt Pin connection drawing? I have found some online, but i dont know if i can trust them.
Finaly every component has arived to bring the Deckel back to life.
I am currently installing linuxcnc and getting to know how to write the hal and ini script.
Has anyone a good hal and ini script to use as a base?
Here is the a picture of my elecrticle cabinete. I am also currently marking every wire i have to connect.
I wont use a vfd because the gears give me a good enought rpm range for now.
Thanks to all wich have replied
  • rodw
  • rodw's Avatar
21 Jan 2026 18:52
MAC address not retrieved (after 2 years stop)
Category: Driver Boards
try sudo apt install r8168-dkms which is the driver for your R8111 (requires non-free)
Follow my YouTube tutorial for PREEMPT_RT tuning for a detailed process to tune your kernel and the steps required to install this and more
www.youtube.com/playlist?list=PLG0NtQtZP...aAlFBsmYP1ay8VNQwsyY
  • phino
  • phino
21 Jan 2026 18:47
Hi, we're interested in your height sensor and could test it for cutting metal (tool steel) but not familiar yet with LinuxCNC.
The machine available for use right now uses a 1.5 kW laser, an Aerotech controller, and an optical height sensor, and it could be reconfigured to test your capacitive height sensor. If that is of use to you, please advise.
In any case, we're interested in this height sensor for possible use on upcoming projects, especially since our intention is to move towards LinuxCNC with future laser machines.
  • DemonClaW
  • DemonClaW
21 Jan 2026 18:16
Replied by DemonClaW on topic Generating a own Popup
Category: Qtvcp
Im soooo sorry i did miss to Tell you, yeah the original .ui is already touched a bit. The handler is untouched. Ive got trough a Lot of Tutorials and almost everyone copied the Files into their Main Maschine, it Made sence for me to have them all together in one folder so i got with that, too.
In my opinion it would be the easist way to extend the current handler Data so the Rest could stay Like i already got it
  • Mr. Mass
  • Mr. Mass's Avatar
21 Jan 2026 18:06
Replied by Mr. Mass on topic asd-a2-e ... lcec driver?
Category: EtherCAT
The file opens for me, 0kb seems to be a display error. Here's what's in this file:
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000">
<!-- Joint 0 -->
<slave idx="1" type="DeASDA" name="x-axis">
<modParam name="opmode" value="CSV"/>
</slave>
</master>
</masters>
  • freemoore
  • freemoore
21 Jan 2026 17:43
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
We also have a problem with the smart serial ports in this config (via the 7i42ta): if I understand correctly, the 7i42ta pins used for the first sserial instance should be 21 and 22 (IO 45 and 46 in the firmware/readhmid result).
At the moment, whether or not "sserial_port_0=0xxxxxxx" is added to the hm2_eth line, all 7i42TA pins behave as GPIO - they can be set/cleared in halshow.
If the sserial line is added and any of its pins linked to a function, lcnc errors on startup.
  • Jocman
  • Jocman
21 Jan 2026 17:28
Ok, here you find the specs of my system:
MB Asrock Q1900M
Intel celeron J1900 1.99Ghz
RAM 8 Gb
About the onboard LAN section:
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111GR
- Supports Wake-On-WAN
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection (ASRock Full Spike Protection)
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE
The PCI LAN card:
EP-9602GS
Chip Realtek RTL8111F
10/100/1000Mbps
PCI Express x1
Port RJ45
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3ab
Auto MDIX Yes
Full Duplex Support Yes
Jumbo Frame Support 9k max
MTBF 376,212 hours
Supported Protocols CSMA/CD
  • cmorley
  • cmorley
21 Jan 2026 17:14
Replied by cmorley on topic Generating a own Popup
Category: Qtvcp
DId you modify the qtdragon ui and handler fikes is that why you copied
the original files? I don't think you told me that.
The qtdragon_handler file that I posted creates an addition to the original. But you can't do both, either you copy the whole file and modify them or you set the file to extend the original.
Let me know what you want to do.
  • PCW
  • PCW's Avatar
21 Jan 2026 17:05
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
Any daughtercard that provides a RS-422 interface will work for BISS
With your 7I76 + 7I74 configuration, the BISS interface could either be on the one RS422 interface on the 7I76 or
any of the eight RS-422 interfaces on the 7I74 depending on the firmware.
Displaying 8206 - 8220 out of 12667 results.
Time to create page: 0.915 seconds
