14 Sep 2026 09:57
Replied by tommylight on topic Crash
Crash
Category: Plasmac
Upload the pictures here, not on plasmaspider.
  • Keith3D
  • Keith3D
14 Sep 2026 06:35
Replied by Keith3D on topic Headless
Headless
I am using direct UDP to the board instead. Thanks for the input!
  • adamster112
  • adamster112
14 Sep 2026 05:54
Replied by adamster112 on topic Remora with STM32H753ZI
hi ive got this working flawlessly on my scylla btt board took 3 days drop us a message on here if u still looking .
  • RMJ fabrication
  • RMJ fabrication
14 Sep 2026 05:26
Replied by RMJ fabrication on topic Home switches stopping machine but not latching fully
Category: Plasmac
These are the limit switches I am using I believe they are connected to tb5 on the mesa 7i76e.
And here are my latch positions and velocities
  • rodw
  • rodw's Avatar
14 Sep 2026 01:54
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
1.44.0 is the latest version, also ethercat don't get from IGH, please uninstall IGH ethercat, and install the one from here instead
github.com/linuxcnc-ethercat/ethercat/releases
your devices will OP much quicker.
also note this new version needs an additional command in hal
lcec.activate
  • rodw
  • rodw's Avatar
14 Sep 2026 01:52
Replied by rodw on topic Notifications
Notifications
Category: Show Your Stuff
There seems to be a lot of systems like this recently.
The correct method is to use MTconnect  which is a standards based read only API now included in LinuxCNC master branch.
With MTconnect you can publish the same data to Home assistant which can then trigger automations
mtconnect.org/
This took me all  of 5 minutes to publish to Home Assistant (sorry Linuxcnc is not running right now...)
  • FabLabRacing
  • FabLabRacing
14 Sep 2026 01:42
Replied by FabLabRacing on topic Thinking of moving my Plasma from Masso to LinuxCNC
Category: Plasma & Laser
I just did the same thing, Please feel free to reach out if you need any help. I feel like I learned a fair bit along the way...
  • grandixximo
  • grandixximo's Avatar
14 Sep 2026 00:25
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
  • gomond
  • gomond
13 Sep 2026 23:06
Thanks Rod
Its a ripper, just what I was after,
  • PCW
  • PCW's Avatar
13 Sep 2026 21:40
Replied by PCW on topic 7i98 and 5abobx3 firmware
Category: PnCConf Wizard
If you indicate what the exact pinout required is, I can build the firmware.
  • coffeeking
  • coffeeking
13 Sep 2026 20:51 - 13 Sep 2026 20:54
Notifications was created by coffeeking
Notifications
Hey Folks, I threw together a wee python package to run on a standard LinuxCNC installation. I tend to have  an IP cam watching my machine but I know not everyone wants to do that. This package monitors the internal LCNC status and pings it out to a ntfy.sh  topic so you get "Machine stopped - ESTOP" etc. No account needed on NTFY. You can install the app for free on android or ios, and there's a web page on the LCNC machine showing the stats too.
github.com/bucklevision/Linuxcnc-notify/
Feel free to try it and see if it helps, give me a ping if you find issues or have ideas for improvements.
Free for all, no intention of that changing - LCNC has been a great tool for me, hope this is useful for some.
  • Jdog
  • Jdog
13 Sep 2026 19:06
Crash was created by Jdog
Crash
Category: Plasmac
Hi Guys,
Looking for some help getting my table back up and running. Table is homebuilt running Linux 2.8.4 with a mesa 7i76E. I had no issues for the last year and half however today i tried to cut some simple 4x4 square plates in the plasmac extras section which I've used before but it would not load the g code or file. I managed to load previous saved files that i cut before with no issues. One thing i had noticed was the system had been connected to the internet which I'm not sure how this could have happened because i never connect this system to the internet, at least i thought. After disconnecting again I cannot load anything without error messages and i noticed sheetcam will not open when linux cnc is running. I have tried searching a fix but I am afraid of making things worse. I am not very good with any of the programming or technical issues and the friend i had helping with that is no longer with us. I attached a pic of the screen with messages that came up. This is when i first open it
ThanksAttachmentshttps://plasmaspider.com/download/file.php?id=98309
  • Marslukan
  • Marslukan
13 Sep 2026 18:49
Replied by Marslukan on topic 7i98 and 5abobx3 firmware
Всем доброго дня.
Подскажите, можно ли достать такую прошивку, нужно: 1 мотор, 2-3 step/dir, 5 энкодеров и остальные разные кнопки, переключатели?
Или как можно изменить текущую прошивку, в какой программе?
  • spumco
  • spumco
13 Sep 2026 18:23
Faceting/Linearization leading to poor surface finish
Category: PathPilot
I know this is an old thread, but I have a 2020 1100MX, with the same issue.
Has there been a solution to this issue?
BSAT
Have you checked or adjusted the servo tuning using Teknic's software yet?
The OP never reported back attempting this, and it's step #1 in identifying the faceting.
Step #2 would be checking the steps-per-unit  - can be calculated from the OEM motor config (also available in Teknic's software).
Step #3 would be to see if PathPilot, the Tormach hardware, and the Clearpath are capable of finer resolution.
Step #4 - if #3 is possible, change to finer resolution and make some test cuts.
PathPilot could be set to Clearpath's default steps-per-rev input, and there may be some room left given the Tormach stock max rapids:
  • BSAT
  • BSAT
13 Sep 2026 16:58
Category: PathPilot
BSAT
Displaying 901 - 915 out of 11519 results.
Time to create page: 0.627 seconds
