  • Surmetall
  • Surmetall's Avatar
  • Thllll
  • Thllll
31 Dec 2025 20:14
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
Still looking for a freelancer to help get a tool sensor setup in software
  • RotarySMP
  • RotarySMP's Avatar
31 Dec 2025 19:56
Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Thanks guys. I am collecting up the wisdom of the crowd, and will try to work through everything systematically.
  • Thllll
  • Thllll
31 Dec 2025 19:54
Replied by Thllll on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Doesnt work in sim either
  • Joco
  • Joco's Avatar
31 Dec 2025 19:51 - 01 Jan 2026 07:51
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
That bug should be resolved in recent builds of the framework.  Its not a monokrom bug. It came out due to an errant print statement.
"What's the first rule?  Do NOT use print statements in the code.  Use LOG.debug"
  • Robin123
  • Robin123
31 Dec 2025 19:44
Replied by Robin123 on topic 7i97t Mesaflash Problem
I'm talking about the PWM value. So this value is a voltage value? Like 17V? I know how to limit this value. But I never measure this value on the Mesa. It's always only 0.35V as soon as I enable it.
  • PCW
  • PCW's Avatar
31 Dec 2025 19:40
Replied by PCW on topic 7i97t Mesaflash Problem
The output voltage should be PWMvalue/PWMscale
  • Thllll
  • Thllll
31 Dec 2025 19:31
How to setup a tool sensor was created by Thllll
Category: Gmoccapy
How do you setup a tool sensor exactly? I cant seem get it right after a week of trial and error of setups, parameters changes. This is not a wiring issue or a debounce issue but a setup issue.
Current Setup:
LinuxCNC 2.9.4
2" tool sensor on the bed
Attached is my setup files
From this document  linuxcnc.org/docs/stable/html/gui/gmocca...uto-tool-measurement  I cant tell if I am doing something wrong or where the discrepancy is.
[TOOLSENSOR]
X = 10
Y = 10
Z = -20
MAXPROBE = -20
This example setup would cause the Z axis to come down to get to the -20 setpoint. This results in a crash into the probe and a "Probe tripped during a non-probe move" would appear. The solution to this was to set the Z to 0 so the probing search would start immediately
For this next issue is touch off x and y (not z because the document says to press "Block Height") I immediatly get a error when pressing x or y touch off.
"G-code error in change.ngc near line 76, file ended with no percent sign(5) or program end (m2)"
Now if I just ignore these errors I get the same error when doing a tool change after it probes it.
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 19:23
Ethercat installation from repositories - how to step by step
Category: EtherCAT
@rodw Thanks for the guide, it really helped me! And some Claude assistance ;-)
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 19:14
Replied by RoKoTer on topic JMC Servo in PP mode
Category: EtherCAT
joshualee777,
Not sure if my Quick Reply was successful, so sorry for the duplicate post.
Hi! I've just successfully completed my initial test setup with a single JMC IHSV57. See github.com/rokoter/LinuxCNC/tree/main/ethercat/ihsv-homing. Hope it helps!
Launch LinuxCNC with cia402-ihsv-home-variant.ini
The Z startup error can safely be ignored :-)
  • Robin123
  • Robin123
31 Dec 2025 19:13
Yes, the value comes from the PID. My power amplifier is a -10/+10V. Is the value a voltage value? If the value is, for example, 17, I measure at the Mesa only 0.35V.
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 19:08
Category: EtherCAT
  • PCW
  • PCW's Avatar
31 Dec 2025 19:06
Yes, in the hal file, the analog outputs are all controlled by PWM values.
The actual PWM value shoudl be set by the output of a PID component that
in turn reacts to the difference in the encoder position to LinuxCNCs
commanded position.
  • Thllll
  • Thllll
31 Dec 2025 18:55
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
It wont let you change the mode, its gets locked out. I gave up on getting probe basic to work
  • Robin123
  • Robin123
31 Dec 2025 18:50
I've now loaded the standard 7i97t ini and hal files, and after a few minor adjustments, LinuxCNC is working (name, IP). In the hal file, I've only commented out the encoders and end positions for now, as they aren't connected yet. Is it even correct that the analog outputs are displayed as PWM? The only difference is that the value is set to higher values ​​(e.g., 17) when using the LinuxCNC interface.
Displaying 9031 - 9045 out of 12671 results.
Time to create page: 0.780 seconds
