  • MaHa
  • MaHa
13 Dec 2025 22:23
freelancer needed to create a routine for ATC tool change (rackchange)
I think the problem is, not using uppercase letter. This should work:
Y_GAP = -206
13 Dec 2025 22:20
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
There is no perceptible rotor cogging when you spin them by hand.
Nice to know, thank you for taking the time to explain that.
  • MaHa
  • MaHa
13 Dec 2025 21:49
Did you add this to the .ini file, the  line with y_gap ?
[TOOL_SLOT_DELTA]
X = 0
Y = -111
Z = 0
y_gap = -206
  • Masiwood123
  • Masiwood123's Avatar
13 Dec 2025 21:29
now the first three slots work as usual, if I select the fourth one when returning the tool to one of the first three I get this error
  • Sandro
  • Sandro
13 Dec 2025 20:14 - 13 Dec 2025 20:16
Axis deflecting while jogging in G54 was created by Sandro
Category: QtPyVCP
Hello everyone,
I’m experiencing some odd behavior when jogging in the G54 coordinate system. When I jog from X0 Y0 to X100 Y0, the Y-axis deflects slightly, as if a small rotation or compensation is being applied. The final reported position is X100 Y0.084. The Z-axis is not affected. A similar issue occurs in the opposite direction: when I jog along the Y-axis, the X-axis also deflects. However, if I issue an MDI command to move to X100, the Y-axis remains unchanged, which is the expected behavior. When I switch to G55 or G56, everything works as intended—there is no coupling or linkage between the X and Y axes. I’ve attached a screenshot showing the issue: first I moved from X0 to X100 using an MDI command, then manually jogged back. You can clearly see the Y-axis deflection during the jog. I have already cleared all work coordinate systems, but the problem persists specifically with G54.
Any help would be greatly appreciated.
Greetings,
Sandro
  • Fastfred
  • Fastfred
13 Dec 2025 19:49
  • Fastfred
  • Fastfred
13 Dec 2025 19:27
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
File Name: custom_2025-12-13.hal
File Size:1 KB
  • Fastfred
  • Fastfred
13 Dec 2025 19:24
Category: HAL
I did setup the MSP software, And I just confirmed the pins again.
  • MaHa
  • MaHa
13 Dec 2025 18:52 - 13 Dec 2025 20:07
I modified the routine for unload and load, o315 and o 316 used. In .ini file the value for 'y_gap' should be 206, not 317 The diff shows the modification
File Name: rack_change.txt
File Size:3 KB
  • Hakan
  • Hakan
13 Dec 2025 17:49
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Are you sure spi works?
Apart from that, make sure the stm32 and the eeprom are in sync, that is, they both come from the same saving of "Save all files"
and that the firmware is compiled and downloaded. It doesn't hurt to do it one more time.
Power cycle the board to make sure both stm32 and lan9252 read the most recent data.
Right-click the mouse on the marked item and remove it. Scan for new boxes to make it reappear.
Also quit Twincat and start it.
All a bit extra cautious to make sure any old data/cache is eliminated.
  • LCR
  • LCR
13 Dec 2025 17:14
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
LinuxCNC must have timed out I'll attach again hopefully.
File Name: My_Etherca...2-13.zip
File Size:25 KB
  • LCR
  • LCR
13 Dec 2025 17:12 - 13 Dec 2025 17:15
Category: EtherCAT
So here is my setup directory. It has been 6 months since I've looked at this, also I'm not too proud, I just got it working.
It is for a gantry. Includes homing and compensates for the buildup of following error I see on all the axes.
The integration loop bit is at the bottom of cia402.comp.  It's more like a slow drift than hard integration. But it does the job of eliminating the buildup of position error.
Also make sure you are sending the target velocity 60B1 and adjust the velocity gains. I ran the machine back and forth and watched following error as I adjusted the various velocity gains. They matter.
Attachment not found
  • Masiwood123
13 Dec 2025 16:44 - 13 Dec 2025 16:52
.this does not work, maybe because you entered the parameters in the routine in the section of returning the current tool to its place, also o302 already exists, so I changed it to o303, but the same thing happens when selecting T4 M6(spindle goes 111mm from tool 3). you should somehow add it to the section of the file where it says ``POKUPI ALAT'',- means that is, ``selected tool'' down in routine, if you are able to edit that part. Thank you very much
  • spumco
  • spumco
13 Dec 2025 16:43
Replied by spumco on topic Clearpath HLFB amp.joint.delay
Category: HAL
 back when they were selling stepper motors and labeling them as "revolutionary servo motors" for a lot more $, and i think they still do, but now with encoder feedback.
Tommy,
They aren't steppers and I don't think they ever have been.  I haven't seen the internal windings, but they don't act like any steppers I've come across.  There is no perceptible rotor cogging when you spin them by hand.  Even the Berger-Lahr 5-phase steppers I have on my Emco lathe have a tiny bit of cogging feel.
The Nema 23/34's are BLDC's with an encoder, trajectory generator, and IO (not just some halls).  The AC-input versions are... maybe something else, don't know.
I've been using them off and on for automation equipment for about 7-8 years and they haven't changed, at least not the mechanical/electrical parts.  They've got upgraded IP67 connectors as an option now, as well as Ethercat models.
Best thing since sliced bread?  No.  There's an upper limit to the performance you can get with 75VDC and 16AWG(ish) cables.
But they are extremely useful in certain applications and no separate drive makes integrating them very easy.
Displaying 9706 - 9720 out of 12686 results.
Time to create page: 0.591 seconds
