  • joshualee777
  • joshualee777
11 Aug 2025 18:47
Replied by joshualee777 on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
Hello, Hakan. My Mama told me that if you receive help from someone,
you shouldn't just say thank you, but express it.
I wanted to thank you for your help with a small gift and propose a personal project, so I asked for your contact information,
but I can't find it.
Please contact me. You have no idea how much my mom nags.
My email is joshualee777-at-gmail-dot-com.
11 Aug 2025 18:40
HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Category: Show Your Stuff
@ErrickW
Here is the exact controller model/type.
Thank you.
Now they have another issue that i think it is a safety feature, not an issue:
- when the left side is a straight cut, unloading works properly
- when there is any angle on the left side, even 4 degree tested, it will not unload, the left most spindle will not move at all
That is all the info i have so far, advised them to do a test cut where the angle is on the right side with the left side left straight, i have a feeling it will unload, but waiting till tomorrow for the result.
  • Hakan
  • Hakan
11 Aug 2025 18:37 - 11 Aug 2025 18:57
Replied by Hakan on topic Debian Trixie upgrade/install to 2.9.4
Category: Installing LinuxCNC
apt update, apt upgrade, apt dist-upgrade
Ethercat works. Didn't have an issue with the Qt package, might have brought it in earlier.
Did need to reinstall linuxcnc-ethercat.
Then it ran fine on the right RT kernel.
Adding that I see the Ethercat kernel modules get signed so there's a big chance we don't need the trouble with secure boot anymore.
Can't test it but someone maybe can check?
  • rodw
  • rodw's Avatar
11 Aug 2025 18:04
Replied by rodw on topic Debian Trixie upgrade/install to 2.9.4
Great feedback guys.
Did you have any issues with libqt5webengine5?
Last feedback I got, this was an issue with the Debian installer not properly handling our Deb file...
  • MaxEkb77
  • MaxEkb77's Avatar
11 Aug 2025 17:05
Replied by MaxEkb77 on topic Debian Trixie upgrade/install to 2.9.4
I upgrade from bookworm to trixie & ethercat work fine
11 Aug 2025 16:28
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
TAILS is the only distro that is set out correctly out of the box to use TOR.
Other distros expect you to set up stuff and make sure the TOR network is ON and connected before opening the internet browser.
Again, the issue is internet, search youtube and you end up with millions of videos on how to stay anonymous on the net, all insisting on using Kali Linux. So far i've seen 1 insist on TAILS.
The "content creator" profession has cr@pped out, as with everything humans do, millions of dumb f@ks yapping about stuff they have no clue.
Pity, as there are some magnificent creators on youtube that i enjoy watching, some i watch despite being certain i am way more capable than, but i enjoy how they present and do stuff, some are funny, some swear and curse, some have no clue but learn by doing, some are just "watchable" .....
We need to start on that list.
  • PCW
  • PCW's Avatar
11 Aug 2025 16:26
"pwm/dir" (Out1) switches for spindle CCW
Category: Basic Configuration
Something like this? (no sure if you need inversion or not)
# Invert the DIR signal
setp   hm2_6i25.0.gpio.007.is_output true
setp   hm2_6i25.0.gpio.007.invert_output true
net spindle-ccw hm2_6i25.0.gpio.007.out
  • joshualee777
  • joshualee777
11 Aug 2025 15:54
Category: EtherCAT
Huuu Thanks you , you save my days !!!
11 Aug 2025 15:38
Replied by tommylight on topic Hardware requirement if a MESA 7i97T card is used
1x PC with LinuxCNC installed
1x Ethernet cable
1x 5 V DC power supply
1x MESA 7i97T
That is all you need.
But, it would be advisable to give us more info about the machine/drives/motors, as 7i97T will work with analog servo drives.
If you are sure they are analog, go for it.
  • Hartwig
  • Hartwig
11 Aug 2025 15:29
Hi members,
I got the recommendation from a member to use t< for my retrofit project he MESA 7i97T card.
Would I need another type of MESA as a "motherboard" - or would the hardware list be as simple as listed below:
1x Ethernet cable
1x MESA 7i97T
Thanks a lot and best regards
Hartwig
  • PCW
  • PCW's Avatar
11 Aug 2025 14:12
Replied by PCW on topic Rote LED
Rote LED
Category: Deutsch
Might try disabling IPV6 and setting the netmask to /24 on the 10.10.10.5  interface.
  • Edi_48
  • Edi_48
11 Aug 2025 14:03
Replied by Edi_48 on topic Rote LED
Rote LED
Category: Deutsch
cnc@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp7s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 50:3e:aa:07:75:d0 brd ff:ff:ff:ff:ff:ff
inet 192.168.178.50/24 brd 192.168.178.255 scope global dynamic noprefixroute enp7s0
valid_lft 863976sec preferred_lft 863976sec
inet6 2003:d8:7748:d100:c2a3:9935:efd4:98be/64 scope global dynamic noprefixroute
valid_lft 7177sec preferred_lft 1353sec
inet6 fd73:2eef:88e8:0:5448:95f3:d261:cfb8/64 scope global dynamic noprefixroute
valid_lft 7177sec preferred_lft 3577sec
inet6 fe80::6726:6743:cea6:428e/64 scope link noprefixroute
3: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 24:4b:fe:cf:eb:d8 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.5/8 brd 10.255.255.255 scope global noprefixroute enp8s0
inet6 fe80::3d43:4957:bbbf:6e2d/64 scope link noprefixroute
  • onceloved
  • onceloved's Avatar
11 Aug 2025 13:39
Replied by onceloved on topic Debian Trixie upgrade/install to 2.9.4
I have a fresh install of Trixie and linuxcnc and ethercat and it works fine
  • juergen-home
  • juergen-home
11 Aug 2025 12:30
Replied by juergen-home on topic "pwm/dir" (Out1) switches for spindle CCW
... it is driven by a 6i25.
I have tried to invert, but that does not the trick for me. It inverts only the Relay signal for CCW but I need the action on CW.
  • Hartwig
  • Hartwig
11 Aug 2025 12:22
Heidenhain EXE610 - which MESA board would be needed to connect 4 of them?
Category: Driver Boards
I have checked the MESA 7i97T documentation and the Heidenhain (HDH) EXE outputs. My idea of the connections is shown in the picture,
#1 Is my idea correct?
#2 Unclear are the connections of the HDH pins 10, 11, and 12. Do you have an idea?
Hartwig
Displaying 11176 - 11190 out of 17169 results.
Time to create page: 0.400 seconds
