  • tsaG
  • tsaG
06 Aug 2025 09:49
Enable / Disable Output when Spindle is ON /OFF
Thanks for the tips!
I applied it to my setup and realized that the
xhc-whb04b-6 Hal code already used the spindle valve signal.
net pdnt.spindle.is-on whb.halui.spindle.is-on spindle.0.on"
After fiddling for some time, I came up with
"net pdnt.spindle.is-on => hm2_7i76e.0.7i76.0.0.output-11"
In my Hal file. Everything is working now. Thanks! :)
  • darrylb123
  • darrylb123
06 Aug 2025 09:45
Replied by darrylb123 on topic SCATECH EV1616DN - Example config
Category: EtherCAT
Ended up using the EV1616DN for 'slow' signals such as limits and lights. Used a PCIe parallel port card and Mach3 breakout board for the steppers. Stepconfig used for the mach3 card config (with modifications for homing) and hand coded the hal file. Works pretty well and now I have plenty of I/O for further development.
ethercat-config.xml
File Name: ethercat-config.xml
File Size:3 KB
ev1616.hal
File Name: ev1616dn.hal
File Size:2 KB
Ha
  • my1987toyota
  • my1987toyota's Avatar
06 Aug 2025 09:33
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
And even if it doesn't go anywhere this time governments will continue to try again. It's how the American
Government has gotten away with mandating kill switches into all new road vehicle
(2026 forward if I remember correctly). There is another bill that is suppose to repeal it (H.R. 1137) but
I don't know if it passed or not. Given all the other crap that has gone on I wouldn't be surprised if it
got lost in the noise.
  • Hakan
  • Hakan
06 Aug 2025 09:14
Replied by Hakan on topic vibration at lowspeed.
Something that happens every 100 ms it seems like.
You can see a small change or step in joint_vel and the servos are responding to that. At least where the main spikes are.
So what are you doing every 100 ms?
  • Kempinger
  • Kempinger
06 Aug 2025 08:59
Replied by Kempinger on topic Acr ok/Up/Down not working
Category: Plasmac
Thank you guys!
I don't know why but now it's working. I have not made any changes in the configuration, just re-starting the wizzard and toggeling the modes several times. Strange.
Really nice GUI!
  • heaven
  • heaven
06 Aug 2025 08:55
Replied by heaven on topic vibration at lowspeed.
i'm using servos, i don't think it comes from the motor side because jogging from LinuxCNC is still smooth. Just look at the figures i attached, the input velocity before the simple_tp module is still smooth but the output velocity from this module is not.
  • rodw
  • rodw's Avatar
06 Aug 2025 08:44
Sometimes you might need to use a timedelay on the spindle.0.on to ensure the air circuit gets up to pressure before the spindle actually spins.
  • rodw
  • rodw's Avatar
06 Aug 2025 08:40
Replied by rodw on topic Switch relay in a defined x position
I can't help but wonder if a pneumatic presssure switch would not be a better safety feature. They are not expensive. Tie it into estop or motion.inhibit somehow.
  • rodw
  • rodw's Avatar
06 Aug 2025 08:23
Replied by rodw on topic prevent jog limit error
Slow your velocities down and see.
I think the sign is the opposite of LATCH_VELOCITY
One of my machines:
MIN_LIMIT = -106
MAX_LIMIT = 0.01
HOME                    = 0
HOME_OFFSET                = 1
HOME_SEQUENCE            = 0
HOME_SEARCH_VEL            = 5
HOME_LATCH_VEL            = -2
HOME_IGNORE_LIMITS    = yes
HOME_USE_INDEX = NO
  • rodw
  • rodw's Avatar
06 Aug 2025 08:11
Replied by rodw on topic vibration at lowspeed.
Are you using steppers or servos?
It's possible you are observing  low speed stepper harmonics. If that's the case, the solution would be to alter the motor gearing to avoid low motor speeds in the harmonics range.
  • konrad
  • konrad
06 Aug 2025 07:59
Replied by konrad on topic prevent jog limit error
thanks, yeah I think that is the problem. Sorry again to ask: Should this value be positive or negative in my case, where the machines homes on the min X/ Y side (and switch is on the moving gantry) --
I assumed negative as the HOME_OFFSET specifies the position of the limit switch in relation to the actual home position. Is that correct?
  • Lcvette
  • Lcvette's Avatar
06 Aug 2025 05:09
Replied by Lcvette on topic Probe Basic ATC Questions
Category: QtPyVCP
Enter these numbers in your var file...
kcjengr.github.io/probe_basic/probe_basic_parameters.html
  • Lcvette
  • Lcvette's Avatar
06 Aug 2025 05:05
Category: QtPyVCP
You need to update the var file parameters, also in the docs.
I'm not sure what you mean about the tool table and the rack the rack stores tools the tool data is stored in the tool table. The rack holds whatever tools you put in it they don't have to be in order it tracks them persistently as long as you have the var file set up. When a tool is loaded from the rack and you use the offset for stored in the tool table everything works as expected it works perfectly fine with cheat code. You call the tool not the rack number.
  • heaven
  • heaven
06 Aug 2025 04:05 - 06 Aug 2025 04:06
vibration at lowspeed. was created by heaven
I'm developing a feature that is called "admittance control", it's a method to control motor base on external force.
The system workflow is:
External force (from ft sensor)-> admittance module (100Hz update rate) -->joint cmd--> simple_tp/limit3 (1Khz) -> ethercat -> driver motor
The admittance module will convert external force to joint-cmd to control motor. Everything look fine except vibration at low speed like this chart
The velocity input look fine but the output velocity-cmd (derivative from position) is not smooth at low speed. Is this problem come from simple_tp/limit3 component? I look at linuxcnc code note and see cubic interpolator is using. Should i rewrite a cubic interpolator to replace simple_tp/limit3 or try to increase admittance update rate to 1 Khz and skip interpolator?
  • PCW
  • PCW's Avatar
06 Aug 2025 01:57
5i25 to 7i92TM - Spindle Index No Longer Working
Category: HAL
The most likely issue on the index is that the encoder differential
receiver (U6 ISL32273) or possibly U13 (74ACT04) have been damaged
On the other 7I76, do you mean 1 isolated input does not work?
This is odd because there is a relatively high power 10K resistor
in series with each isolated input so even a short connection to
120 VAC  is survive-able. It might be a contamination issue.
Perhaps the resistive divider and filter cap for the specific input
could be looked at closely
Displaying 11416 - 11430 out of 17179 results.
Time to create page: 1.582 seconds
