  • SwitchWitch
  • SwitchWitch
14 Jul 2025 13:51
Yaskawa GA500 with SI-ES3,U1000 was created by SwitchWitch
Category: EtherCAT
Hi, I am thinking about changing my existing VFD against one with Ethercat Option.
I found the Yaskawa GA 500 wich could be connected to ethercat using the YASKAWA, SI-ES3,U1000 interface card.
I didn`t find the vfd in the long list of the yet implemented devices so the question would be how to do so.
First option to use the esi file and to build the hal by myself could be a bit too hard oder too demanding for me.
The GA500 should be full cia402 compatible related to the documentations - does this make it as easy to integrate as with the servo drives?
What problems could occur?
  • meister
  • meister
14 Jul 2025 10:50
  • epineh
  • epineh
14 Jul 2025 10:09 - 14 Jul 2025 10:11
I've attached the config, this is a basic test setup, axis setups work. With the WLED expansion plugin loaded it will compile/flash/run LinuxCNC no issues, but when I add a Blink plugin, and tie it to the WLED0 blue LED it won't compile.
Cheers.
Russell.
File Name: Karen.zip
File Size:1 KB
  • Gautham
  • Gautham
14 Jul 2025 08:26 - 14 Jul 2025 08:27
Replied by Gautham on topic 5 axis milling machine with 7i96s
Category: Driver Boards
Hi PCW,
I found a card locally that seems similar to the Sainsmart breakout you had mentioned. I'll add the link below. It says its for Mach3 and LinuxCnc, would this work with my Mesa 7i96s. Thanks so much for your help. Interface Board CNC 5 Axis
  • beauxnez
  • beauxnez
14 Jul 2025 07:09 - 14 Jul 2025 07:11
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Thank you,
I managed to correct 2 errors myself in addition to the 2 you indicated to me but I can't find this one.
[codeVERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtplasmac
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
emc/iotask/ioControl.cc 786: can't load tool table.
twopass:invoked with <> options
twopass:found ./UDP2.hal
twopass:found ./custom.hal
twopass: Error in file ./UDP2.hal:
    Pin 'motion.float-switch-input' does not exist
Running HAL shutdown script
Debug file information:
Note: Using POSIX realtime
3280
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtim]
  • MaxEkb77
  • MaxEkb77's Avatar
14 Jul 2025 06:30
Replied by MaxEkb77 on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I use abs position, when set to zero i reset encoder multiturn position.
If you need a ini setup for abs, late copy this side a config.
  • ziggi
  • ziggi's Avatar
14 Jul 2025 05:32 - 14 Jul 2025 07:27
Troubles to get started with SD240 Retrofit
Category: Turning
Oh, damned... Thank you for the brief explanation.
The root of all the trouble seems I understood this totally wrong.
I thought "selected axis" and also the "increment" was taken from the AXIS screen- both can be chosen there
Sorry for my sillyness. Now I understood that I need to connect the MPG in the HAL via in/outputs.
Thank you both of you
​​​​​​​Sigi
  • Gautham
  • Gautham
14 Jul 2025 05:32
Thank you so much PCW and Jimmy, I will do more research into the options you have both suggested and see which would be easier for me to implement.
  • michaeln
  • michaeln
14 Jul 2025 04:58 - 14 Jul 2025 04:59
  • farmer_mike
  • farmer_mike
14 Jul 2025 04:00
Replied by farmer_mike on topic RTelligent EtherCAT Servo Drive Setup: RS750E
Category: EtherCAT
Hi MTate01, thanks for your posts. I have my RS 750E drives jogging. My next step is to wire the E stop.
I don’t know what differential input e stop means or how to wire that circuit. The manual seems to indicate that 24v gets wired to both pins 19 and 21. What is supposed to happen to the voltage on pins 19 and 21 when the e stop button is pressed?
  • Gautham
  • Gautham
14 Jul 2025 02:33
Replied by Gautham on topic Mesaflash not working on 7i96s but it pings
Hey thank you so much, this worked.
  • sivaraj
  • sivaraj
14 Jul 2025 02:09 - 14 Jul 2025 04:19
HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Category: Show Your Stuff
Any chance you used program numbers O9xxx or O8xxx .This needs parameter setting (3202) to edit from CNC
google for Fanuc manual B–63525EN/02 page 405 & 428
It should be in EDIT mode and EDIT key enabled.
However you may not be able to delete the active foreground program , the program number which usually shows on top right of the screen.
Could you able to select different program to foreground or not? only the foreground program Number will run in Auto.
The last selected or ran program only will be active as foreground program till you select another program to foregraound.
There is Background edit . it is different
  • Benb
  • Benb's Avatar
14 Jul 2025 01:29
Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie.
Category: Milling Machines
Try this mpg configuration, you need one toggle switch to choose incremental or continuous jog mode, one 3 position selector switch and one MPG encoder. This configuration will work for hardwired or ui based switches. I am showing the configuration for hardwired system.but if you need to use soft switches replace hm2.7xx... with exposed ui switch adresses. If you experience jog acceleration issues just play with jog acceleration value right now it's set for 1.0.
# 3 axis hal mpg configuration
# This section will set the jog mode using a hardwired toggle switch
# switch open incremental mode switch closed continuous mode
net set-mode hm2_7ixx.your input-address-of-toggle-switch
net set-mode joint.0.jog-vel-mode
net set-mode joint.1.jog-vel-mode
net set-mode joint.2.jog-vel-mode
net set-mode axis.x.jog-vel-mode
net set-mode axis.y.jog-vel-mode
net set-mode axis.z.jog-vel-mode
# Set jog scale (as per your configuation 0.1)
net mpg-scale 0.1
net mpg-scale joint.0.jog-scale axis.x.jog-scale
net mpg-scale joint.1.jog-scale axis.y.jog-scale
net mpg-scale joint.2.jog-scale axis.z.jog-scale
# Set jog acceleration (value between 0 and 1)
net jog-accel 1.0
net jog-accel joint.0.jog-accel-fraction axis.x.jog-accel-fraction
net jog-accel joint.1.jog-accel-fraction axis.y.jog-accel-fraction
net jog-accel joint.2.jog-accel-fraction axis.z.jog-accel-fraction
# Joint selection (enable only one at a time)
net mpg-select-x joint.0.jog-enable axis.x.jog-enable <= hm2_7ixx.your input x address of selector switch
net mpg-select-y joint.1.jog-enable axis.y.jog-enable <= hm2_7ixx.your input y address of selector switch
net mpg-select-z joint.2.jog-enable axis.z.jog-enable <= hm2_7ixx.your input z address of selector switch
# Connect encoder counts to all joints (only enabled one will move)
net mpg-counts  hm2_7ixx.your mpg encoder address
net mpg=counts  joint.0.jog-counts  axis.x.jog-counts
net mpg-counts  joint.1.jog-counts  axis.y.jog-counts
net mpg-counts  joint.2.jog-counts  axis.z.jog-counts
  • stirra
  • stirra
14 Jul 2025 00:08
Replied by stirra on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Could you post your configuration files? I still have been unable to get homing to work correctly with the Lichuan LC10E and a home switch.
  • Benb
  • Benb's Avatar
13 Jul 2025 23:53
Category: Turning
Following is a hal netlisting for the MPG part of your question:
# Set jog-vel-mode to false (joint will move exactly jog-scale units for each count)
setp joint.0.jog-vel-mode 0
setp joint.2.jog-vel-mode 0
setp axis.x.jog-vel-mode 0
setp axis.z.jog-vel-mode 0
# Set jog scale
setp mpg-scale 1.0
net mpg-select-x joint.0.jog-enable axis.x.jog-enable <= hm2_7ixx.your selector switch input
net mpg-select-z joint.2.jog-enable axis.z.jog-enable <= hm2_7ixx.your selector switch input
Displaying 12226 - 12240 out of 17344 results.
Time to create page: 0.570 seconds
