  • PCW
  • PCW's Avatar
10 Jul 2025 15:46
Replied by PCW on topic Issue 7i92 and Arduino Relay
Category: Driver Boards
Is the 7I92 GPIO pin driving the relay set to output mode?
10 Jul 2025 15:34
Replied by tommylight on topic Issue 7i92 and Arduino Relay
How are you testing them?
  • miniwini
  • miniwini's Avatar
10 Jul 2025 15:30 - 10 Jul 2025 15:35
Replied by miniwini on topic Omron MX2
Omron MX2
Category: EtherCAT
hey i got it working... wasnt that hard as i thought...
here my solution...
the ethercat.xml file first... thats the easy part...
<masters>
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
    <slave idx="0" name="EK1100" type="EK1100"/>
    <slave idx="1" name="EL1018_1" type="EL1018"/>
    <slave idx="2" name="EL1018_2" type="EL1018"/>
    <slave idx="3" name="EL2024_1" type="EL2024"/>
    <slave idx="4" name="EL2008_1" type="EL2008"/>
    <slave idx="5" name="EL2008_2" type="EL2008"/>
    <slave idx="6" name="EL2008_3" type="EL2008"/>
    <slave idx="7" name="3G3AX-MX2-ECT" type="OMMX2"/>
  </master>
</masters>
with this you get all the pins into halshow
then you need to load the main ethercat stuff before the main ui... (ethercat.hal)
# EtherCAT and IO HAL for LinuxCNC 2.9.4
# Load EtherCAT configuration (User-space only!)
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
addf    lcec.read-all            servo-thread
addf    lcec.write-all            servo-thread
then go to your machine halfile and add the nets and pins
#  ETHERCAT SPINDLE - Ethercat mainstuff loaded with ini in ethercat.hal
#Load conversions for speed and controlword
loadrt conv_float_s32 count=1
loadrt conv_float_u32 count=1
addf conv-float-s32.0 servo-thread
addf conv-float-u32.0 servo-thread
#Load mux2 for controlword
loadrt mux2 names=mux2.spindle-enable
addf    mux2.spindle-enable        servo-thread
#mux2 section
#Spindle OFF
setp mux2.spindle-enable.in0 10
#Spindle ON
setp mux2.spindle-enable.in1 15
#networking pins for start / stop
net pdnt.spindle.is-on => mux2.spindle-enable.sel
net spindel-conv conv-float-u32.0.in mux2.spindle-enable.out
net spindle-ctrl-cmd conv-float-u32.0.out => lcec.0.3G3AX-MX2-ECT.srv-cia-controlword
net pdnt.spindle.is-on <=  spindle.0.on  => mux2.spindle-enable.sel
#networking pins for speed
net spindlespeed spindle.0.speed-out conv-float-s32.0.in
net speed_out conv-float-s32.0.out lcec.0.3G3AX-MX2-ECT.srv-target-vl
#sets spindle-at-speed true
this works for me :)
thanks again for all the done work in the past to make this so easy nowadays!
cheers miniwini
10 Jul 2025 15:30
Replied by tommylight on topic Noise issue related to mesa board 7I76E
Is everything on the machine and the PC grounded?
Is that grounding good? This is very hard to figure out, but give it a try.
  • hitchhiker
  • hitchhiker
10 Jul 2025 15:29
Replied by hitchhiker on topic Issue 7i92 and Arduino Relay
yes same powersupply same GND and GND from the IDC parallel.
the relays work when i power them and put GND to the IN pin.
10 Jul 2025 15:25 - 10 Jul 2025 22:09
Replied by tommylight on topic Linux vs Windows value
People will just want a turnkey solution,...
This is what really pisses me off, Linux is the turnkey solution, not windows.
This my main PC has Ryzen 7 7700, RX6800, 96GB RAM, etc, i install Linux in about 3 minutes, reboot and use the PC as everything works.
For any windoze that would be at least 40 minutes to 2 hours for windows, another hour or two for drivers with many reboots, and then software for ... everything!
I play occasionally Doom Eternal on Steam, yet no drivers are required!!! 120 FPS @ 3440X1440 with RT on.
Edit:
Not addressed at you, unknown, addressed at the internet as a whole as everyone on the net keeps repeating that same phrase. Sorry i just noticed it might come as personal, it is not.
10 Jul 2025 15:17
Is the same power supply powering Mesa and relays?
  • TheTinkeringMechanic1
10 Jul 2025 15:16
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
Category: Basic Configuration
The project is on hold at the moment. Didn't want anyone to believe I was ignoring or not getting back to them. I'll update as soon as I can.
  • hitchhiker
  • hitchhiker
10 Jul 2025 15:07
Issue 7i92 and Arduino Relay was created by hitchhiker
Hi dudes !i have a 7i92 .. on the gpio i have the IN from a relsy board.VCC 5V and GND are connected.GND is from 5V Powersupply and GND ftom the ID26 from the 7i92.Relay has a optocoupler.another relay has many jumper settings. i try both options no successhcan someone bring me back to the right route..? please
  • Lcvette
  • Lcvette's Avatar
10 Jul 2025 14:10
Replied by Lcvette on topic Hot reload/update carousel probe basic
Category: QtPyVCP
That requires you build customized M6 remap and subroutines to accommodate your desired functionality. The on screen graphics can be triggered with simple commands in the sub routines. Any specialized tools for instance that cannot be stored in the atc. such as a fixed spindle or large fly cutter for example that won't fit, you would currently have to add exceptions for those tools in the subroutines.
  • my1987toyota
  • my1987toyota's Avatar
10 Jul 2025 11:51 - 10 Jul 2025 11:52
Replied by my1987toyota on topic Linux vs Windows value
the main argument against windows is that it doesn't run LinuxCNC :)
Thank God for that, I could just imagine what B.S. windows would add to it.
  • ShemJ
  • ShemJ's Avatar
10 Jul 2025 11:48
Step By Step Help Needed . EL8 Leadshine to PI 5
Category: EtherCAT
Hello Will,I am also new to the world of LinuxCNC and servos. It can be a lot to take in. I have been working on a Marco Reps clone box as well and have a thorough walkthrough for the process so far. I'm stuck on getting gantry mode working but it looks like you won't have that problem. I have also provided two config files. The modello config is setup as a gantry mode, but I have tried a probe basic config with 3 axis in trying to master/slave the gantry servos via RS 485 cable rather than in LinuxCNC. That should work for your system. You will still need to comment out various bits in the files regarding the LS510 VFD and the xhc-whb04b handheld controller if you are not using this hardware. I am leaving for vacation today but let me know how you get on.
  • ziggi
  • ziggi's Avatar
10 Jul 2025 10:01 - 10 Jul 2025 14:10
Troubles to get started with SD240 Retrofit
Category: Turning
I think I probably detected the source of these  weird settings disabling jog. Guess it can just be the Config file. Nowhere else I can find a similar demonination of the pins etc.
I have to check this, but I started with a config file created by PC-Config and without MPG included.
Then I had PC-Config create a new one with a different name and copied the MPG related lines of the newly created .hal file to my existing .hal file.
But the config file is still the initial one (without MPG) and therefore jogging is disabled.
I will try this weekend to create a new config file with PC-Config, include the MPG and all data I know mean while. Hope to get it working this way.
Sigi
  • unknown
  • unknown
10 Jul 2025 09:43
Replied by unknown on topic Xilinx Zynq 7010 fpga crypto windfall boards
Ah well ATM everything's out of budget.
  • meister
  • meister
10 Jul 2025 09:00
Replied by meister on topic Linux vs Windows value
Displaying 12376 - 12390 out of 17355 results.
Time to create page: 0.420 seconds
