  • whyme
  • whyme
04 Jul 2025 14:57
Replied by whyme on topic Raspberry Pi 4 with Mesa 7c81
Category: Driver Boards
Maybe a stupid question, but how do you use the relay on those cheap MACH3 BOBs with the 7c81?
For the inputs to work I need to enable the pullups on the 7C81.
But enabling the pullups makes the relay close as soon as the BOB is powered.
Ideally I would want the relay to be open until linuxcnc is started and I tell linuxcnc to close the relay.
But the relay closing by default due to the pullups makes it unusable, or did I miss something?
  • kworm
  • kworm
04 Jul 2025 14:39
QTplasmac material database enhancement
Category: Plasmac
I cut a lot of thicker material that needs a ramp pierce.  I am thinking of adding ramp pierce parameters to the material database along with adding ramp pierce to the conversational area of QTplasmac.   My purpose for this would be to keep all the cut info in one place and to be able to use the conversational on thicker parts vs having to CAM simple things.   Just thought I would see if there was interest in this from others and/or other thoughts on it.
  • PCW
  • PCW's Avatar
04 Jul 2025 14:27
MESA 7i76U inputs changing state without changes to config
Category: Basic Configuration
Normally you would use a NC switch for Estop and the you would use the true (no -not)
input to sense it. This is so that when Estop is not activated (switch = closed circuit),
iocontrol.0.emc-enable-in will be true so no Estop. Then when Estop button is activated
(switch= open circuit), iocontrol.0.emc-enable-in goes false, signaling an estop event.
Did you verify that estop-ext changes state when you change the Estop button from on to off?
  • besriworld
  • besriworld
04 Jul 2025 14:23
Replied by besriworld on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
This time, the spindle didn’t stop. However, when exiting the editor, the graphical interface shows that the program is not running
youtube.com/shorts/axVyF3tfrcw?si=d6pKXhjEwYUU1QWp
youtube.com/shorts/ay-Nz62fcPs?si=QHA_4l6xV2o7P6Ro
  • kn612
  • kn612
04 Jul 2025 14:15
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Thank you, the wiring is making much more sense and less challenging now.
Im using linuxcnc_2.9.4-amd64.hybrid.iso that I downloaded here.  It installed qtplasmac 2.9.  Is it recommended to install 2.10?
What is the easiest way to configure a 7i97t and a couple thcad2 for plasma?  I dont see 7i97t as an option in pncconf and in mesact there isnt an option for qtplasmac.
I asked chatgpt to create a quick ini for qtplasmac and a 7i97t and it came up with this pretty quick:
File Name: mesa_7_i_9...smac.txt
File Size:1 KB
  • dunnitagain
  • dunnitagain
04 Jul 2025 13:37
Recommended New Install of LinuxCNC coming from EMC2 and Ubuntu 10.4
Category: Installing LinuxCNC
Created the Boot USB STick . both machines recognize the stick on the desk top. But dont recognize it in Bios settings . All the bios settings are set to boot from the stick , but it doesnt show up in the boot drive order.
  • Tim Bee
  • Tim Bee
04 Jul 2025 13:37
Dear meister:
Thanks for your repay and fix it,thanks again.
Tim
  • besriworld
  • besriworld
04 Jul 2025 13:25
Gmoccapy 3.5.1
Category: Gmoccapy
I start the program with an external button.
  • Aciera
  • Aciera's Avatar
04 Jul 2025 13:23 - 04 Jul 2025 13:24
Replied by Aciera on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
When you're in the G-code editor, it's possible to start the program execution, but if you exit the editor, the program stops .
How do you do that? Using halui?
  • scsmith1451
  • scsmith1451's Avatar
04 Jul 2025 13:10 - 04 Jul 2025 13:14
HY_VFD RS-485 HAL config was created by scsmith1451
Re-configuring my DIY Router Mill to use LinuxCNC after MACH3 began glitching on me. At this point I'm trying to get my HY_VFD to respond via RS-485.  Under Mach3 this RS-485 adapter worked great, but not getting any response now.
I found this HAL file on line for the HY-VFD RS-485 config:
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
# RS-485 Spindle Control
loadusr -Wn vfd hy_vfd -n vfd -d /dev/bus/usb/004/002 -p none -r 19200
net spindle-vel-cmd-rpm-abs    vfd.speed-command
net spindle-enable              vfd.spindle-on
net spindle-cw vfd.spindle-forward
net spindle-ccw vfd.spindle-reverse
net spindle-at-speed vfd.spindle-at-speed
setp vfd.enable 1
having replaced the device reference with the output of lsusb for my machine.
When I issue a M3 S6000 command via MDI, nothing happens. Would someone please help me resolve this issue?
The above HAL config is in custom.hal. I'm running LCNC 2.9.4 on Debian 12.
Also, on a fairly regular basis I get the following error on startup of LCNC:
Debug file information:
Note: Using POSIX realtime
tcsetattr
: Inappropriate ioctl for device
./custom.hal:4: waitpid failed hy_vfd vfd
./custom.hal:4: hy_vfd exited without becoming ready
5241
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f1e95251000
  • Happppppppy
  • Happppppppy
04 Jul 2025 13:02 - 04 Jul 2025 13:14
I don't have any devices configured with 192.168.10.xxx on the linuxcnc computer.
Here is the config:
"name": "BushmasterFPGA",
"description": "Terasic DECA Max10",
"boardcfg": "TerasicDECAMax10",
"protocol": "UDP",
"plugins": [
"type": "w5500",
"mac": "AA:AF:FA:CC:E3:1C",
"ip": "192.168.10.194",
"port": 2390,
"pins": {
"mosi": {
"pin": "Header Right:GPIO1_D0"
"miso": {
"pin": "Header Right:GPIO1_D1",
"pull": "down"
"sclk": {
"pin": "Header Right:GPIO1_D2"
"sel": {
"pin": "Header Right:GPIO1_D3"
"rst": {
"modifier": [
"type": "invert"
"pin": "Header Left:GPIO0_D4"
"uid": "w55000"
"linuxcnc": {
"ini": {
"EMC": {
"MACHINE": "BUSHMASTERFPGA"
"KINS": {
"JOINTS": 4,
"KINEMATICS": "trivkins coordinates=XYYZ kinstype=both"
"TRAJ": {
"COORDINATES": "X Y Y Z"
"machinetype": "mill"
Here are the outputs from the terminal:
cnc@BUSHMASTER-CNC:~$ ip a s
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether f8:0f:41:80:f0:e7 brd ff:ff:ff:ff:ff:ff
altname enp0s25
inet6 fe80::696b:7c3c:f7c9:4de2/64 scope link noprefixroute
cnc@BUSHMASTER-CNC:~$ ip r s
  • besriworld
  • besriworld
04 Jul 2025 12:48
Gmoccapy 3.5.1
Category: Gmoccapy
I use Match 3 on another machine and it has this functionality and I thought it was something standard. :)"You mean when the machine is already homed? "
 YES .
"But the spindle should resume at the same speed. Can you give an exmple to reproduce that?"
I will make a video.
"A bit unusual use case though, but I agree that should not abort the program."
Yes, I accidentally started the program from this menu and at one point I decided to go to the main page and the machine stopped. The program should simply not be started from this menu or it should not stop. I already know and I will not start the program in the editor. But maybe I will not be the first to find this bug. :)
  • meister
  • meister
04 Jul 2025 12:17
do have configure one of your network-interface to the 192.168.10.xxx range ?
please add you config and the output of:
ip a s
and
ip r s
  • scsmith1451
04 Jul 2025 12:02
Thank you to everyone. I've finally got the EStop to work correctly, though I don't understand why. Apparently, it works opposite of the limit switches in that there must be a high signal on the pin at startup and EStop is triggered when the switch is opened. Regardless, I can now home and run as expected.
  • dubstar_04
  • dubstar_04's Avatar
04 Jul 2025 12:01 - 06 Jul 2025 09:35
[Solved] Mesa 7i96 Spindle PWM was created by dubstar_04
I'm converting a lathe to run LinuxCNC, everything is working but the spindle.
I have flashed firmware: 7i96d_1pwm
Mesa flash output:
mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: PWM
  There are 1 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: StepGen
  There are 4 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: SSR
  There are 1 of SSR in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3 -> 7I96_0
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
TB3-1                   0   IOPort       None
TB3-2                   1   IOPort       None
TB3-3                   2   IOPort       None
TB3-4                   3   IOPort       None
TB3-5                   4   IOPort       None
TB3-6                   5   IOPort       None
TB3-7                   6   IOPort       None
TB3-8                   7   IOPort       None
TB3-9                   8   IOPort       None
TB3-10                  9   IOPort       None
TB3-11                 10   IOPort       None
TB3-13,14              11   IOPort       SSR              0        Out-00          (Out)
TB3-15,16              12   IOPort       SSR              0        Out-01          (Out)
TB3-17,18              13   IOPort       SSR              0        Out-02          (Out)
TB3-19,20              14   IOPort       SSR              0        Out-03          (Out)
TB3-21,22              15   IOPort       SSR              0        Out-04          (Out)
TB3-23,24              16   IOPort       SSR              0        Out-05          (Out)
IO Connections for TB1/TB2 -> 7I96_1
TB1-2,3                17   IOPort       StepGen          0        Step/Table1     (Out)
TB1-4,5                18   IOPort       StepGen          0        Dir/Table2      (Out)
TB1-8,9                19   IOPort       StepGen          1        Step/Table1     (Out)
TB1-10,11              20   IOPort       StepGen          1        Dir/Table2      (Out)
TB1-14,15              21   IOPort       StepGen          2        Step/Table1     (Out)
TB1-16,17              22   IOPort       StepGen          2        Dir/Table2      (Out)
TB1-20,21              23   IOPort       StepGen          3        Step/Table1     (Out)
TB1-22,23              24   IOPort       StepGen          3        Dir/Table2      (Out)
TB2-2,3                25   IOPort       PWM              0        PWM             (Out)
TB2-4,5                26   IOPort       PWM              0        Dir             (Out)
TB2-7,8                27   IOPort       QCount           0        Quad-A          (In)
TB2-10,11              28   IOPort       QCount           0        Quad-B          (In)
TB2-13,14              29   IOPort       QCount           0        Quad-IDX        (In)
TB2-16,17              30   IOPort       SSerial          0        RXData0         (In)
TB2-18,19              31   IOPort       SSerial          0        TXData0         (Out)
Internal-TXEn          32   IOPort       SSerial          0        TXEn0           (Out)
Internal               33   IOPort       SSR              0        AC Ref          (Out)
IO Connections for P1 -> 7I96_2
P1-01/DB25-01          34   IOPort       None
P1-02/DB25-14          35   IOPort       None
P1-03/DB25-02          36   IOPort       None
P1-04/DB25-15          37   IOPort       None
P1-05/DB25-03          38   IOPort       None
P1-06/DB25-16          39   IOPort       None
P1-07/DB25-04          40   IOPort       None
P1-08/DB25-17          41   IOPort       None
P1-09/DB25-05          42   IOPort       None
P1-11/DB25-06          43   IOPort       None
P1-13/DB25-07          44   IOPort       None
P1-15/DB25-08          45   IOPort       None
P1-17/DB25-09          46   IOPort       None
P1-19/DB25-10          47   IOPort       None
P1-21/DB25-11          48   IOPort       None
P1-23/DB25-12          49   IOPort       None
P1-25/DB25-13          50   IOPort       None
Connections:
Pin TB2-1 -> GND
Pin TB2-3 > PWM+
I'm not getting anything out of pwm to analog boards. I have tried 5 different convertor boards with the same result. Before I invest in a scope or a new mesa board can anyone spot anything wrong with the config?
Thank you,
Dan
Displaying 12646 - 12660 out of 17374 results.
Time to create page: 0.444 seconds
