  • DMNZ
  • DMNZ
25 Jun 2025 02:20
How to design new driver for my own board
Category: Driver Boards
if you plan to use Orange PI why not just dedicate few pins and use SPI. RIO already has the driver and i believe works on other spartan 6 boards like a charm. you can use usb for firmware updates and non real time data (like pendant for example). usb has great speed but absolutely no guarantee time wise especially if your board will identify itself as vendor specific class. you can try to play with usb audio devices class, which seem to have better latency but you may still be disappointed after all that hard work you plan to do.
  • DMNZ
  • DMNZ
25 Jun 2025 02:01
Xilinx Zynq 7010 fpga crypto windfall boards
Well, the board has arrived and i think i know now why these are so cheap. I can see the signs of dust, discoloration and rework. Looks like these boards are taken from old equipment and refurbished. I will use it for my fpga learning experiments but would not recommend for any serious use.
I guess this closes the topic.
  • dunnitagain
  • dunnitagain
25 Jun 2025 00:23
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Thank You , I have had other things happening , ill try and work on it this weekend.
  • unknown
  • unknown
24 Jun 2025 23:34
Replied by unknown on topic How to design new driver for my own board
It's not speed that is the issue, it's regularity. Once you introduce a buffer you lose the ability for realtime response.
There's a reason that no USB development has been done for Linuxcnc.
Search the forum for questions related to USB and you'll get the same response over and over.
Mesa has one or two boards that have USB interfaces but none are used for Linuxcnc.
As previously stated, Ethernet, SPI or EPP are the way to go. USB maybe ok for control panels for non realtime input, but disconnection can be an issue.
I really suggest you look into it more, especially the difference between speed and regularity. You may also want to look to see if USB has any realtime drivers.
  • PCW
  • PCW's Avatar
24 Jun 2025 22:31
Replied by PCW on topic Weiler DZ26 Millturn Conversion
Category: Turning
Should be something like:
sserial_port_0=000xxxxx
or
sserial_port_0=002xxxxx
Assuming you want the 7I84 to run in mode 2.
There is no sserial_port_1 in 7i77x2 configurations
(there is only sserial_port_0 with 6 channels, 3 for the first 7I77 and 3 for the second)
  • kworm
  • kworm
24 Jun 2025 22:27
Replied by kworm on topic Mesa 7i95t and THCAD pncconf screen
Category: PnCConf Wizard
Yes, I overlooked the /usr/bin/pncconf in my search. The problem was that the pin number for the 7i95t first encoder port was 0 which caused "if self.d._arcvin ..." to evaluate to false. I fixed it by using "if self.d._arcvin != None ...".
  • irwinger
  • irwinger
24 Jun 2025 21:25
Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
Outside of my use of StepConf - any suggestion as to what I might want to look at to understand why the rapid moves of SHIFT-RT/LT/UP/DN/PG UP/PG DN just move a couple inches and then stop? Unless StepConf 'does' something in file I'm not overwriting from my previous working system.
Again - thanks in advance for any suggestions... I know I'm not the quickest getting back, I have a part time job in my retirement which is starting to occupy me more than I like.
Arden
  • PCW
  • PCW's Avatar
24 Jun 2025 21:23
Replied by PCW on topic Mesa 7i95t and THCAD pncconf screen
This is the only place I noticed it set true:
                # for encoder pins
                elif widgetptype == _PD.ENCA:
                    #print"\nptype encoder"
                    halsignallist = 'hal_encoder_input_names'
                    humansignallist = _PD.human_encoder_input_names
                    addsignalto = self.d.halencoderinputsignames
                    relatedsearch = [_PD.ENCA,_PD.ENCB,_PD.ENCI,_PD.ENCM]
                    relatedending = ["-a","-b","-i","-m"]
                    customindex = len(humansignallist)-1
                    # check for a thcad encoder
                    if "Arc Voltage" in pinchanged:
                        self.d._arcvpin = pin
                    elif self.d._arcvpin == pin:
                        self.d._arcvpin = None
                    if self.d._arcvpin and self.d.frontend == _PD._QTPLASMAC:
                        self.p.page_set_state('thcad', True)
                    else:
                        self.p.page_set_state('thcad', False)
  • matasbuk
  • matasbuk
24 Jun 2025 21:19
Replied by matasbuk on topic Qtdragon for lathe??
Category: Qtvcp
Thank you! Worked perfectly
  • kworm
  • kworm
24 Jun 2025 21:19
Replied by kworm on topic New with questions on LinuxCNC and Mesa
You might also want to consider servo drives from Delta, Rexroth, or others that support direct connection of the linear encoders to the servo drive for full closed loop operation.  This is combination with absolute encoders on the servos is how I think most new machines are doing it...at least the ones I have seen.   They could be controlled from either Mesa or with Ethercat.
  • kworm
  • kworm
24 Jun 2025 21:15
You can just replace the private_data.py file in /usr/lib/python3/dist-packages/pncconf with the private_data.py that is attached to my post. I would backup the original file first just in case.
Well MesaCT doesn't support QTPlasmaC at the moment. I have done some work on supporting it but haven't heard from JT if he's interested in bringing those changes in if I make a pull request.
  • phino
  • phino
24 Jun 2025 21:05
Replied by phino on topic Mesa 7i95t and THCAD pncconf screen
Nice effort! How would one apply the changes to get 7i95t support in pncconf?
What are pros/cons of using pncconf vs mesa CT? github.com/jethornton/mesact
  • kworm
  • kworm
24 Jun 2025 21:00
Sorry I should have had that in my initial post...yes I have QTPlasmaC selected as GUI.
  • Johnnysacalu
  • Johnnysacalu
24 Jun 2025 20:38 - 24 Jun 2025 20:40
Replied by Johnnysacalu on topic Como conectar mesa 7i96s
Si la señal es cc lo mediré por tenerlo en cuenta pero si es mas seguro con el rele ssr creo que lo pondré.
Otra pregunta crees que es necesario tener picas de tierra separadas una en la caja de controles y otra en la mesa o no hay ningún problema en estar en la misma?gracias por todas tus respuestas
El plasma es trifasico
Displaying 12961 - 12975 out of 17375 results.
Time to create page: 0.483 seconds
