  • Edi_48
  • Edi_48
15 Jun 2025 14:59
Replied by Edi_48 on topic Rote LED
Rote LED
Category: Deutsch
5.01 Volt
das er die Ethernet Verbindung verloren hat
  • dunnitagain
  • dunnitagain
15 Jun 2025 14:54
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
I went to the file system
home/ jetmill1 / emc2 / configs / jetmill1 /
there seems to be several .ini files in that folder.
could it be looking at the wrong config file?
  • billykid
  • billykid's Avatar
15 Jun 2025 14:08 - 15 Jun 2025 14:14
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
so it's perfect! if I think how much time I wasted with a nuc i3 to improve the latency without succeeding... I need it to tune up some drives that I recovered 2 years ago, now I also have the servos. if anyone knows these maybe they can give me some advice on how to use them in the best way.
drive Sanmotion rs2aa03a0al0 motor r2aa06040fxp
  • dunnitagain
  • dunnitagain
15 Jun 2025 13:34
I cleaned up the lines , but It still wont load . In the file explorer, it looks like I have 2 different .ini files. Is there a way to properly clean up this mess , without starting over? Machine has direct drive steppers , and DRO Scales for position feedback , Tool probe also. I hate to try and reset all pins and parameters.
  • SebastianM
  • SebastianM
15 Jun 2025 13:27
Replied by SebastianM on topic Error finishing read... *sigh*
Thx.
Can’t tell if I still get would that error as I took the mesa out of the workshop and back into my “office” for bench testing and debugging.
Will apply the grub parameters today that you posted.
Currently I do have the following code in my grub customizer (guess I have to remove it).
quiet isolcpus= 3 pcie.aspm=0 r8168.eee_enable=0 pcie_aspm=off idle=poll
The arguments are slightly different (isolcpus 3 vs 2,3), but let’s see.
15 Jun 2025 12:44
Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
Copy your config folder to the configs folder, open it, right click on the .ini file, choose open with, down click on use custom command, under it type linuxcnc, press enter.
Test the machine, does it work correctly?
If yes, run LinuxCNC from the main menu, left select My configs then your config, click on create desktop shortcut, click ok.
Now you have a shortcut on the desktop.
  • Beovoxo
  • Beovoxo
15 Jun 2025 11:58
Replied by Beovoxo on topic Deckel FP4A Retrofit
Category: Milling Machines
Got new cooling lines installed and pressed today :)
15 Jun 2025 11:48
Replied by tommylight on topic Rote LED
Rote LED
Category: Deutsch
Fehlermeldung?
Und mese die 5V an die Mesa karte, soll 4.75-5.25V sein
  • epineh
  • epineh
15 Jun 2025 10:33
Quick question hopefully, I'm setting up my router with closed loop to the controller, apart from getting the scale right it's all working, my question is when you setup the scale in the pwm/dir config, it sets up the axis "scale in" to that, but leaves the scale out value at 1 or zero (can't remember exactly). At this value the axis will run away similar to having the encoder wires around the wrong way.
I can set it using the machine calibrate window within Linuxcnc but it gets overwritten every time setup is run. Then if you forget about it and an axis is close to end of travel, bad things can happen.
I've most likely just missed where to put in the scale out value but I can't seem to find it.
Cheers.
Russell.
  • Edi_48
  • Edi_48
15 Jun 2025 09:12
Rote LED was created by Edi_48
Rote LED
Category: Deutsch
Hallo ich habe eine Mesa 7i96s und Linuxcnc 2.9.4Ich habe eine Installation Mesact  gemacht mit einbinden 3 Servos, 3 Endschalter, 1 Not-Aus, und WKZ Sensor. Ausgänge : Spindel out 0, out1 und RelaysWenn ich jetzt Linuxcnc starte , kann ich die die Maschine Einschalten bekomme ich eine Fehlermeldung und das Ehternet ist unterbrochen.
Auf der 7i76s blinkt LED init Rot, nur durch Neustarten der Hardware ist der Fehler weg.Meine Maschine ist mit 10.10.10.10 mit meiner Workstation verbunden.
  • unknown
  • unknown
15 Jun 2025 07:26
That's the easiest way, I think I mentioned that earlier, I like Network Manager as I can turn the wifi off whilst running a job.
  • unknown
  • unknown
15 Jun 2025 07:24
Replied by unknown on topic Linux vs Windows value
If I have to use Windows it always feels like swimming against the current in a river of molasses
  • billykid
  • billykid's Avatar
15 Jun 2025 07:12
I installed network manager and both connections, 7i80 and internet are fine.
  • DMNZ
  • DMNZ
15 Jun 2025 05:32
Replied by DMNZ on topic Error finishing read... *sigh*
sorry, my bad, you should remove that -q in the command which makes your ping output quiet. try this:
sudo chrt 99 ping -i 0.001 10.10.10.10 -c 1800000 | grep -v time=0.
btw. are you still getting that error finishing read?
  • Aciera
  • Aciera's Avatar
15 Jun 2025 04:59 - 15 Jun 2025 05:00
Is there a way to have more than 9 coordinate systems?
You could use an ngc remap to create a gcode for setting numbered parameters to the required offset values and another ngc remap to read the parameters and set one of the built in offset system. Arrange the parameters in blocks of 10, that way a 'p' word value can easily be used to reference which block to read/store the (x,y,z,..) offset values from/to.
Maybe you can write your own macro to load the offsets from a file
Use python to remap an unused Gcode to get the required offset values from a file and set one of the nine built in offset systems. Takes a bit more effort than the above solution.
Displaying 13351 - 13365 out of 17411 results.
Time to create page: 0.649 seconds
