  • Chia
  • Chia
26 May 2025 06:28
LinuxCNC errors was created by Chia
LinuxCNC errors
It is a RPI.
When I run the yzEllipse75.ngc, the machine encounters an error related to IMG_6867.JPG, IMG_6868.JPG, and IMG_6869.JPG.
  • DavidR8
  • DavidR8
26 May 2025 02:11
Replied by DavidR8 on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
Brilliant, that makes complete sense now. I'm a Linux noob so I'll probably ask a bunch of questions with seemingly obvious answers. I do know how to search so I try to keep it to a minimum.
  • ihavenofish
  • ihavenofish
26 May 2025 01:45
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
it go zoom zoom now
next steps:
IO
modbus spindle control
UI
getting there. :)
  • ihavenofish
  • ihavenofish
26 May 2025 01:37
  • cmorley
  • cmorley
26 May 2025 01:16
Replied by cmorley on topic Indicators on Push Buttons
Category: Qtvcp
IndicatorMixin is not meant to be used directly. It is 'mixed in' with another button widget such as Qtvcp's PushButton widget or IndicatedPushButton widget
  • unknown
  • unknown
26 May 2025 01:02
Replied by unknown on topic Not able to get outputs on GPIO of Raspberry5
Category: Installing LinuxCNC
Link to manpage
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
First hint is here:
The GPIO line PIN3 can not be found.
PIN3 isn't a name of a pin, pins are named as per man page.
  • tiagounderground
  • tiagounderground
26 May 2025 00:12
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
the config im tryng to use works in version 2.9.4, tomorow i will post my config here,
  • MaHa
  • MaHa
25 May 2025 23:31
Replied by MaHa on topic repeat calls to subroutine
Have a look at Fanuc style numbered programs M98 Pn Ln
linuxcnc.org/docs/2.9/html/gcode/o-code....fanuc-style-programs
  • unknown
  • unknown
25 May 2025 23:20
Why does it seem like everyone here is Australian?
And it was great to see an Aussie take the win in the Moto2 at the British GP.
I feel sorry for Dixon, no Binder to blame for his performance.
  • unknown
  • unknown
25 May 2025 23:16
Mine were 10 pound poms.
And to be sure we're quite proud of Australia being built by convicts.
Insult an Aussie and they'll take on as a badge of honour, Rats of Tobruk is an example, something the OP fails to understand, tho the little weasel hasn't bothered to reply.
  • unknown
  • unknown
25 May 2025 23:08
forum.linuxcnc.org/38-general-linuxcnc-q...official-images-only
Index to major thread, there's a section regarding your query with an example for a simple 3 axis machine that works.
  • clayton2ndtry
  • clayton2ndtry
25 May 2025 22:36
repeat calls to subroutine was created by clayton2ndtry
I would like to call a subroutine some arbitrary number of times.  Some gCode variants support M91 Psubroutline Lcount.  But not linuxCNC.  Any suggestions how to do this?  I do not need anything as fancy as a while loop.  Juist count executions.
25 May 2025 20:15
Replied by tommylight on topic help with ethercat and omron drives
Category: EtherCAT
Yeah, i might have shot from the hip there ...
25 May 2025 20:13
Replied by tommylight on topic Need 8i20
Need 8i20
Category: User Exchange
Moved to "user exchange" .
  • ihavenofish
  • ihavenofish
25 May 2025 19:15
Replied by ihavenofish on topic help with ethercat and omron drives
Category: EtherCAT
Adjusted motor tuning, its fine now. moves and is happy. Still need to tweak the y a little.
It does seem that tuning in the omron software is not *quite* the same as running under position control. Didn't lose anything, just small tweaks. X was the howling one and it still tracks within 3 microns during acceleration. The Y has 2 microns lad in straight motion and 6 during accel. Bigger motor and MUCH more mass. Just trying to keep it "stiff" as possible. Anything under 10 microns during accel is a win. (this machine does high speed surfacing).
Anyhow, break time, I'm very happy. thanks for all the uh.. moral support? :) hahah. I get frustrated a lot when the instructions are missing big blocks of important information. I think I need to write a "ethercat setup for dummies" post so other people can follow something a bit more straight forward. The "implied prior knowledge" is what really turns people away from linuxcnc in general.
Displaying 14326 - 14340 out of 17460 results.
Time to create page: 0.322 seconds
