  • Lcvette
  • Lcvette's Avatar
22 May 2025 02:26
Replied by Lcvette on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
If you follow the instructions carefully it takes about an hour start to finish including creating and installing Linux on a clean system. I do it every few days for new builds and testing and it's not too bad considering what it is. The machine setup is the most challenging and that is really such a unique to user thing that is hard to make it simpler.
  • cmorley
  • cmorley
22 May 2025 01:21
Replied by cmorley on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
I would clone the repository and compile
  • unknown
  • unknown
22 May 2025 00:06
Linuxcnc 2.9.4 .iso on Rpi5: apt update does not build /boot/initrd.gz
Category: Installing LinuxCNC
I had no issues when using the earlier RPi5 image, in fact I helped with testing that one prior to it being released as Rod didn't have an RPi5 to test with.
These things don't go out into the wild without testing.
The current RPi5 does have a small issue, which one user caught and another user actually had an issue with, the fix is very easy and is documented in the RPi5 image thread under zswap.
Maybe you accidentally were trying a RPi4 image ?
Actually that wouldn't even have a kernel panic as it would not be able to find a kernel to boot from. And to be honest I can't recall anyone having kernel panics or non booting machines from the first RPi5 image.
Another thing to note is that the kernel headers are pre installed so nothing needs to be done there. Anyways there is no suitable header package in any repos.
  • Doc_emmet
  • Doc_emmet
21 May 2025 22:28
Replied by Doc_emmet on topic Read the S-Command in the HAL
Category: HAL
Hello, can you show me how to read the S command and what you changed.
  • mikereid0817
  • mikereid0817
21 May 2025 21:06
unable to get gpio to work on Raspberry Pi 5 using latest image
Thanks, Andy, you steered me in the right direction.
GPIO13 would not work at all, continuing to research that.
GPIO25, once pullup=GPIO25 was added, works.
I only have 1 limit switch setup, so I'm fully functional with the official image, Byte2Bot board, and my old Probotix motor driver setup.  Attached are the .hal and .ini files that worked, and my config.txt
File Name: cncrouter.hal
File Size:3 KB
File Name: cncrouter.ini
File Size:3 KB
File Name: config.txt
File Size:3 KB
  • Hakan
  • Hakan
21 May 2025 21:01 - 21 May 2025 21:01
RTelligent EtherCAT Servo Drive Setup: RS750E
Category: EtherCAT
Yes ethercat OP state is one thing, cia402 enable state is another thing (on top of OP state)
Linuxcnc need to go through every step to enable the drive. Skipping steps or shortcuts are not allowed.
But I have never worried about that, the cia402 component does that automatically.
  • Lcvette
  • Lcvette's Avatar
21 May 2025 20:55
Replied by Lcvette on topic Activate B-axis in Porbe Basic
Category: QtPyVCP
almost forgot about the job buttons, those are now also dynamically set to display the new options for xyzbc as well as the offsets page ui bits as can be seen in the image below.
just waiting on a tester and need to update the docs once everything tests out and I will push the update out to the apt develop version of PB for install and updating.
  • Routerworks
  • Routerworks
21 May 2025 20:40
Replied by Routerworks on topic Calling next subroutine messes up offsets
Have to thank you for all your help. I finally got this running very well following my above plan. Freecad is great for many things but not so sure it is the best for programs with subroutines.
Again, thanks for your patience.
Routerworks
  • Lcvette
  • Lcvette's Avatar
21 May 2025 20:37
Category: QtPyVCP
ok so i spent the morning and afternoon updating some things with dro display, it is completely modular now in probe basic in the test branch, it includes preconfigured dro displays for the following:
xyz
xyza
xyzab
xyzac
xyabc
user (predefined with xyzabc)
this should allow users to configure however they need to for a multitude of configurations.
it will be activated in the ini section with the addition of the following two lines:
USER_DROS_PATH = user_dro_display/
DRO_DISPLAY = xyzac
(xyz, xyza, xyzab, xyzac, xyzbc, user) these will be the available options with "user" being editable and stored in the config folder same as usertabs/buttons etc.
it is completed but i need a tester to pull the "dro_display_dynamic_loading" branch and just verify all works on a diferent pc than mine before i send it live as an update.  it will require users to update their config if they want to run anything besides xyz which it will default to if no ini entry is used.
thoughts/help testing?
Thanks,
Chris
  • DavidR8
  • DavidR8
21 May 2025 20:21
Replied by DavidR8 on topic Servo as spindle motor configuration
Category: Basic Configuration
Thank you, appreciate the confirmation.
  • PCW
  • PCW's Avatar
21 May 2025 20:16
Replied by PCW on topic Servo as spindle motor configuration
Yes, step/dir spindle control is possible and supported.
You may have to do some minor hal file editing depending
on which configuration utility you use.
Where it gets more complex is when you have a combined
spindle/C axis.
  • DavidR8
  • DavidR8
21 May 2025 19:55
Servo as spindle motor configuration was created by DavidR8
Hey folks, I'm on the verge of replacing the Masso G3 running my 3 axis mill with LinuxCNC likely paired with a Mesa 7i92S board.
It's a basic machine X, Y, Z axis configuration with DMM DC servos and DYN2 drivers for the axis. Three inductive limit switches, a tool setter and a 3D probe. The one possible wrinkle is that the spindle motor is a Bergerda servo motor currently controlled by step and direction. I think it can also be controlled via 0-10v but I'd prefer to retain the step and direction control.
Is LinuxCNC configurable such that spindle control can remain step and direction?
  • richcolvin
  • richcolvin's Avatar
21 May 2025 19:39
Replied by richcolvin on topic C Axis as Second Spindle
I tried using RoseKins, and it does not work to drive the 2nd spindle either.
  • 1911ut
  • 1911ut
21 May 2025 19:00
Prevent interpreter/planner from executing user remap until...
Thanks that worked perfectly
I was using the following which does not work for my purposes.
    if self.task == 0: # ignore the preview interpreter
        yield INTERP_EXECUTE_FINISH
After removing (if self.task == 0: ), it works.
  • Aciera
  • Aciera's Avatar
21 May 2025 17:54 - 21 May 2025 17:57
you can use
NOTE: No 'self.execute(..)' command can be used after this.
linuxcnc.org/docs/html/remap/remap.html
Displaying 14551 - 14565 out of 17470 results.
Time to create page: 0.481 seconds
