  • DonatasO
  • DonatasO
17 May 2025 14:31
G53 not ignoring tool length offset after a Python M6 remap
Thanks for the reply.
I can't use self.execute() as using INTERP_EXECUTE_FINISH is unavoidable in my procedure, and no MDI commands can be sent after it. I made it possible to switch between ATC and manual tool change (like drop tool, ask to insert a new one).
At least my understanding about emccanon.USE_TOOL_LENGTH_OFFSET() is that it's supposed to be the equivalent of G43, as it issues the same EMC_TRAJ_SET_OFFSET message. Apparently, it does not fully update the initial state.
Calling USE_TOOL_LENGTH_OFFSET() multiple times before moving does not resolve the problem.
  • Aciera
  • Aciera's Avatar
17 May 2025 13:44 - 17 May 2025 13:48
Not sure but I think that 'emccanon.USE_TOOL_LENGTH_OFFSET(pose)'
might actually not be a good approach here.
 Note that 'G53' will actually use the 'tool_offset' values to calculate the target coordinates:
if(block->z_flag) {
            *pz = block->z_number - s->origin_offset_z - s->axis_offset_z - s->tool_offset.tran.z;
        } else {
            *pz = s->current_z;
github.com/LinuxCNC/linuxcnc/blob/1b8867.../interp_find.cc#L197
My guess would be that your change of tool-length is possibly not reflected in 'tool_offset.tran.z'.
Generally I've become very cautious about using 'emccanon' commands to manipulate offset values  in remaps. I've had a similar issue setting work offsets this way.
I changed to using 'self.execute(..' instead (although that has its own pitfalls).
See the mentioned issue with work offsets:
forum.linuxcnc.org/20-g-code/48199-chang...-self-execute#264285
  • MarkoPolo
  • MarkoPolo
17 May 2025 13:12
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
I noticed that after starting it doesn't load the 'true' state
in radiobuttons .
I modified this logic a bit and now it works:
rabiobutton with "radiotrue/true/radiofalse/false'
checkbox with 'checktrue/checkfalse'
What do you think about this?
  • epineh
  • epineh
17 May 2025 13:05
Hmm so I had checked the datasheet earlier, never actually looked at price and availability, I see what you mean.
The main idea was to save pins, they run out quickly on the tang nano. I guess the simplest solution is to step up to the spartan 6.
There is OctoQuad by DigitalChickenLabs for the pi pico that will do a similar thing for 8 encoders via I2C but as you say it would also require a new plugin.
Cheers.
Russell.
  • meister
  • meister
17 May 2025 12:47
Hi Russell,
the LS7366 are no longer manufactured and you would have to write a new plugin. The ones you can still get are also quite expensive.
can't you just make a plug-in board (on the top) and route all the encoder pins to the top via pin headers?
Cheers, Olli
  • DonatasO
  • DonatasO
17 May 2025 12:21 - 17 May 2025 12:33
I'm writing an M6 remap in Python and encountered strange and dangerous behavior. After the first M6 call, G53 G0 takes into account the tool length offset, which should not be happening.
I'm unsure if I'm doing something wrong or if this is a bug in LinuxCNC. I hope you can help me clarify and resolve it.
LinuxCNC version: 2.9.4
UI (probably irrelevant): qtdragon_hd
This is a minimal working code to reproduce the issue:
# REMAP=M6 modalgroup=6 prolog=change_prolog python=is_this_a_bug epilog=change_epilog
def is_this_a_bug(self):
    if self.task == 0:  # ignore the preview interpreter
        return INTERP_OK
    emccanon.CHANGE_TOOL_NUMBER(self.selected_pocket)
    yield INTERP_EXECUTE_FINISH
    pose = EmcPose()
    pose.z = -50
    yield INTERP_OK
Steps to reproduce the issue:
  • Turn on and home the machine
  • T6 M6: the tool is loaded and offsets are set correctly.
  • G53 G0 Z0: the spindle rapids down to -50mm. This is not expected.
  • G49: cancel tool length compensation.
  • G43: enable tool length compensation
  • G53 G0 Z: the spindle rapids back up to zero. This is expected.
The issue can no longer be reproduced by issuing T6 M6, everything works correctly.
Attaching debug logs for each command:
T6 M6
Warning: Spoiler!
G53 G0 Z0
Warning: Spoiler!
G49
Warning: Spoiler!
G43
Warning: Spoiler!
G53 G0 Z0
Warning: Spoiler!
  • JT
  • JT's Avatar
17 May 2025 11:54
linux cnc keeps bending shortcutting to the next line.
It's important to understand how Linuxcnc follows the programmed path.
linuxcnc.org/docs/stable/html/user/user-concepts.html
Note that G64 Blend Without Tolerance Mode is the default
A good preamble should always be the first line of any nc code program.
gnipsel.com/linuxcnc-old/g-code/gen01.html
JT
  • Sternfox
  • Sternfox
17 May 2025 11:38 - 17 May 2025 11:49
Mill as lathe with probebasic was created by Sternfox
Category: QtPyVCP
Hey peeps.
I have A couple of questions. I want to use my mill as a cnc lathe.
Can I have pb turn and mill on seperate profiles?
And can pb turn utilise 3 axis? I need the third to line up the work and to change tools which I will have in the vice.
The other option is using a custom post in fusion but im guessing thats way more complicated.
Thoughts?
Much appreciated
  • rodw
  • rodw's Avatar
17 May 2025 11:28
Replied by rodw on topic Linuxcnc wood lathe insufficient torque
48 volt power supply and DM542A stepper drivers would almost quadruple torque you have now with your same Nema 23's
  • Hakan
  • Hakan
17 May 2025 11:14
Replied by Hakan on topic el5151 reseting counts
Category: EtherCAT
Yes that would be a problem. Linuxcnc asks the encoder to reset the counter to zero and count continuously up/down from there. I don't know any details of this encoder so I guess it is reading the manual to find how that can be done. Luckily Beckhoff has ok manuals.
For velocity you can try the ddt hal function, generate velocity as the derivative of the position. Taking the encoder pin values is limited by the servo loop time and EtherCAT cycle time, anything faster than some hundred Hz will fail.
  • SanzuiWorks
  • SanzuiWorks's Avatar
17 May 2025 09:40 - 21 May 2025 03:45
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
This requires QtDragon to support parsing (MDI_COMMAND, Gxx) output from FILTERs and executing it as an MDI command.
load_wsc_from_ngc.py
import re
import linuxcnc
import os
def on_button_detect_wcs(self):
    filename = STATUS.file
    if not os.path.exists(filename):
        print("G-code file not found.")
        return
    try:
        with open(filename, 'r') as f:
            for line in f:
                m = re.search(r'\bG5(4|5|6|7|8|9)(\.\d)?\b', line.upper())
                if m:
                    g_code = m.group(0)
                    print(f"Detected WCS: {g_code}")
                    c = linuxcnc.command()
                    s = linuxcnc.stat()
                    s.poll()
                    if s.task_state == linuxcnc.STATE_ON and s.interp_state == linuxcnc.INTERP_IDLE:
                        c.mode(linuxcnc.MODE_MDI)
                        c.wait_complete()
                        c.mdi(g_code)
                    else:
                        print("Interpreter not idle. Cannot send MDI.")
                    return
        print("No WCS (G54~G59.3) found.")
    except Exception as e:
        print(f"Error: {e}")
.ini
[FILTER]
PROGRAM_EXTENSION = .ngc G-Code File
FILTER = load_wsc_from_ngc.py .ngc
When you run the program directly, you can obtain the WSC, but it does not run automatically during the NGC loading.
  • aleene
  • aleene
17 May 2025 09:18
Could this board be a contender for a cheap alternative for simple applications?
Category: Driver Boards
Hello
I'm using the same controller and I might be able to assist.
The attached PDF file is all the documentation I received / I could find online.
The board seems to use a custom protocol - not TCP/IP based, I can see the MAC of the controller board.
The current control software is ~ a pain - i need to keep a specific windows 10 virtual machine to run it.
There's no linux support.
I've been thinking for some time to rip it out and replace it with a MESA 7i96S or something similar.
If you think there might  be any interest in this controller, please point me to a list of thing to prepare - protocol capture via wireshark / data dumps between the CPU and the ethernet controller, etc.
  • SanzuiWorks
17 May 2025 09:14 - 17 May 2025 09:17
Category: Qtvcp
This is the first time I've seen the filter function. I need to learn about this first.
  • MarkoPolo
  • MarkoPolo
17 May 2025 09:00
Category: Qtvcp
Maybe leave it as it is now, but add so that radioButton also works with true/false string for backward compatibility ?
  • cmorley
  • cmorley
Displaying 14776 - 14790 out of 17470 results.
Time to create page: 0.771 seconds
