  • Aciera
  • Aciera's Avatar
Today 17:39 - Today 17:44
Replied by Aciera on topic CSS/G96 for other than X-axis?
Interesting. Just checked on a sim on 2.10pre and setting ini velocities to 0 does not quite work for me. The tool moves to the start of the spiral and then moves back. A bit strange really:
Same on 2.9.8
  • Lcvette
  • Lcvette's Avatar
Today 17:26
Replied by Lcvette on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
thats true, i did that because we now listed everything here in the docs. I will remove the machine setup file ini since it can be copied directly from the docs page instead and will be kept more current. good looking out susan-parker!
Today 17:10
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Category: Turning
You still have the:
.turret.hal:1: Unknown command ''
error, there is something on the first line of that file causing the error.
Try running it through a dos/win to Linux script, might be some strange character there.
  • RotarySMP
  • RotarySMP's Avatar
Today 16:33 - Today 16:43
Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
Category: Gmoccapy
Hans contacted over the github bug tracker, to have me run the Gmoccapy lathe sim, and sure enough, there is no scaling error behaviour there.
So I also tried the Gmoccapy Lathe_Macros sim, and that has the scaling behavior error.
When I created my current config, copied my old 2.8.2 config files, and cut paste the lathe macro files from this sim. Any ideas where I need to look for corrective action appreciated.
Cheers,
Mark
  • RotarySMP
Today 16:30
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
I tried running just the turret.comp under halrun, and have the same result as Andy. It works.
But when I call it from my custompostgui.hal, it errors out. See attached error logs.
Cheers,
Mark
  • spumco
  • spumco
Today 15:44
Replied by spumco on topic CSS/G96 for other than X-axis?
That worked like magic.
I removed all the jog-disconnect stuff from the M-codes and substituted
hal setp ini.v.max_velocity    0
hal setp ini.0.max_velocity    0
in the switched-mode M-code file, and the opposite in the normal-mode M-code.
Switchkins still works: parting slide is still connected to the X-axis controls, but the V-axis/Joint_0 simply doesn't move.
  • Axis GUI jog controls do nothing (!)
  • G-code V-axis moves do nothing
  • MDI does nothing
  • V-axis jogging does nothing (via MPG or continuous buttons)
  • No following errors or other issues noted
Best part is if I command a G0 Vnnn via MDI and then switch the axes back to normal, nothing 'jumps' like there's a blocked command waiting to be unblocked or re-enabled.
I'm probably missing some odd situation where this could bite me, but the fact is I'm only planning to use this switched mode briefly while the parting tool is in action (during a program) and then immediately restore the kinematics.
See any 'gotchas' with this?
  • juan13372k
  • juan13372k
Today 15:21
SIEG SX3.5Z Drivers EtherCAT A6 Steppers was created by juan13372k
Category: Driver Boards
Hello,
i bought this Sieg Typ Mill SX 3.5 from Paulimot in Germany. I now need to buy Steppers and Drivers.
This is the Mill:  sieg-sx3.5z i bought the Mill with glas scales and i like to implement them in the driver if possible?
I am thinking of getting the the following Driver and Steppers if it makes sense:  400-w-ethercat-ac-servomotor-kit
i would be nice if the experts can give me a feedback because iam quit new to this topic.
thank you
  • spumco
  • spumco
Today 15:10
I think I just found what may be a stupidly-easy solution:  set MAX_VELOCITY to zero.
I set AXIS_X & JOINT_0 max velocity to 0 in a test INI file and LCNC started up with no complaints.
Z-axis homed first, then X just sat there doing nothing - as expected.
Next test will be to edit the switchkins M-code and try it after everything is homed.
  • Aciera
  • Aciera's Avatar
Today 14:47 - Today 15:03
This may be of interest:
github.com/LinuxCNC/linuxcnc/compare/mas..._axes_in_interpreter
Adds a magic comment (mask,xyzabcuvw) to the interpreter. This allows setting which axis words (ie any of 'xyzabcuvw') to disable in the interpreter.
Works for MDI and inside Gcode programs.
(mask, <if none of 'xyzabcuvw'>;)    ->  no restrictions apply [default]
(mask,z)    ->  if the interpreter finds a 'z' word an error is raised
(mask,zab)  ->  if the interpreter finds a 'z', 'a', or 'b' word an error is raised
Notes:
 Only the first nine (9) characters after the comma (,) are considered.
 Upper- and/or lowercase letters are supported.
  • RotarySMP
Today 13:49 - Today 13:57
Category: Turning
Thanks a lot for trying that Andy. I'll compile your correction this evening. I will probably have to put the 2.8.2 SSD back in the machine, and I can also see if this works there without error.
If I fall back on somehing like 2.8.4 buster ISO, do I loose your latest macros layout?
  • HansU
  • HansU's Avatar
Today 13:14
Replied by HansU on topic Display slightly too big
Category: Gmoccapy
I think it's a bit different. Because the original issue is about expanding the width but your window gets expanded in both dimensions.
  • susan-parker
  • susan-parker
Today 13:09
Replied by susan-parker on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
This step 5 appears to be missing from the current documentation:
kcjengr.github.io/probe_basic/machine_config.html
Step 3: Edit INI files
... only has 4 steps.
  • cekaa
  • cekaa's Avatar
Today 12:13
Hello, I would like to add an EtherCAT IO device. What should I do
Category: EtherCAT
Is there a place to learn how to use XML?
ceka@debian:~$ ethercat pdos
=== Master 0, Slave 2 ===
SM0: PhysAddr 0x1000, DefaultSize   64, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1100, DefaultSize   64, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1200, DefaultSize    6, ControlRegister 0x64, Enable 1
SM3: PhysAddr 0x1400, DefaultSize   12, ControlRegister 0x20, Enable 1
=== Master 0, Slave 3 ===
SM0: PhysAddr 0x1000, DefaultSize  128, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize  128, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize    5, ControlRegister 0x64, Enable 1
  RxPDO 0x1600 "RxPDO0-Map"
    PDO entry 0x7000:01, 16 bit, "OUT"
SM3: PhysAddr 0x1c00, DefaultSize    7, ControlRegister 0x20, Enable 1
  TxPDO 0x1a00 "TxPDO1-Map"
    PDO entry 0x6000:01, 16 bit, "IN"
ceka@debian:~$
  • andypugh
  • andypugh's Avatar
Today 10:50
Replied by andypugh on topic Schaublin 125-CNC retrofit.
Category: Turning
Thanks Andy, It compiles for me as well. I get the error when I have linuxnc load it.
That's working for me too:
andypugh@Boookworm:~/linuxcnc-dev$ halrun
halcmd: show pin
Component Pins:
Owner   Type  Dir         Value  Name
halcmd: loadrt turret
Note: Using POSIX realtime
halcmd: show pin
Component Pins:
     4  bit   OUT         FALSE  turret.0.busy
     4  bit   OUT         FALSE  turret.0.done
     4  bit   OUT         FALSE  turret.0.error
     4  s32   OUT             0  turret.0.position
     4  bit   IN          FALSE  turret.0.sensor0
     4  bit   IN          FALSE  turret.0.sensor1
     4  bit   IN          FALSE  turret.0.sensor2
     4  bit   IN          FALSE  turret.0.sensor3
     4  bit   IN          FALSE  turret.0.start
     4  s32   IN              0  turret.0.target
     4  s32   OUT             0  turret.0.time
     4  bit   OUT         FALSE  turret.0.valve
I have taken the liberty of changing the function name to "_" so that the addf line is "addf turret.0" not "addf turret.0.turret"
  • Aciera
  • Aciera's Avatar
Today 08:10
So the NML description in the LCNC manual isn't accurate? Or perhaps not exactly clear what happens?
Not sure but looking at motion/control.c gives me the impression that 'GET_JOINT_ACTIVE_FLAG(joint)' is used in motion mode FREE only:
github.com/LinuxCNC/linuxcnc/blob/c760c1...ontrol.c#L1217-L1219
but apparently not in modes TELEOP and COORD. So maybe it was only ever needed in FREE mode but who knows.
However I'm not sure this is the right place to implement what we want as we would still seems to cut things after the trajectory planner. Even if we are not updating the pos-cmd pin for that joint the internal position in the planner might still be updated and cause problems when reactivating the joint.
Displaying 16 - 30 out of 17467 results.
Time to create page: 0.231 seconds
