  • ihavenofish
  • ihavenofish
01 Mar 2026 00:46
Replied by ihavenofish on topic motion channels for robotic atc library
Thanks, that's basically what I thought
  • Marcos DC
  • Marcos DC's Avatar
01 Mar 2026 00:31
Replied by Marcos DC on topic motion channels for robotic atc library
LinuxCNC has a single realtime motion module (motmod).
All coordinated motion and joint updates go through that one trajectory planner and queue.
Even if you configure additional axes (U/V/W etc.), they still belong to the same motion instance.
There is no concept of a second independent motion channel inside one LinuxCNC process.
Industrial controllers sometimes give the impression that this should be possible because they support true multi-channel motion. For example, platforms like Omron Sysmac can run multiple independent motion groups or program contexts in parallel within the same controller. That capability is built directly into the motion kernel.
LinuxCNC, however, is architected around a single motion instance per process.
If you need the tool robot to move while the main machine is cutting, the practical solutions are:
• Run a second LinuxCNC instance / second controller for the tool robot and handshake via IO/fieldbus.
• Use an external PLC/MCU/drive sequencer for the robot and trigger it from LinuxCNC via M-codes or IO.
A “HAL-only second planner” is technically possible, but then you own all the safety, limits, interlocks and coordination logic yourself — and it tends to become fragile fast.
  • ihavenofish
  • ihavenofish
28 Feb 2026 23:41 - 28 Feb 2026 23:50
motion channels for robotic atc library was created by ihavenofish
So i had a craaazy idea for a little robot tool library.
Wondering how you would implement it in linuxcnc.
So we have our XYZA on our cnc. lets reserve B just in case we ever need a 5th.
That leaves 4 more axes available.
Our little tool robot will have an x2 y2 z2, and a x3 (fixed motion, likely air) and C do pivoting the gripper - again fixed motion.
Basically it is a cnc of its own, and needs to operate while the main machine is cutting so it can sort and stage tools. This is different from using C for an atc platter that is actually coordinated with the main machine.
How could we do this?can we decouple these new axes from the main motion as a "channel" ?
  • Marcos DC
28 Feb 2026 23:37
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
I already have a pure SIM validation setup working (HAL adapter + drive stub). The goals there were to make the logic deterministic and debug wiring/handshake issues before touching real EtherCAT hardware. In SIM I’ve validated:
6060/6061 opmode handshake
bit4 start pulse generation
done mask/value detection
stable statusword behavior (no flicker)
basic “homed” behavior (latched)
So the current work is no longer “does it wire up?”, but refining the architecture to match industrial semantics.
@rodw — yes, exactly: your procedure returning 1 at Operation Enabled is the clean gate. I’m using your barebone logic as the base for a dedicated PDS manager layer: until op_enabled == 1, nothing else (homing or motion modes) is allowed to run. Once op-enabled is reached, then we proceed with homing / CSP.
@Hakan — I also really like your point about not blaming the drive for moving during internal homing. That’s actually the main remaining behavior I’m refining now: instead of freezing targets in a hacky way, it seems cleaner to make the controller follow feedback during drive-internal homing.
So while homing is active:
motion/target follows feedback (pos_cmd := pos_fb)
when homing completes, CSP can resume with zero discontinuity (no jump)
Next steps:
implement the separate PDS manager (based on rodw’s barebone + timeouts + fault reset pulse)
implement mode modules (homing/CSP/etc.) gated by op_enabled and 6060/6061 confirmation
once the layers are solid in SIM, re-integrate with lcec + real hardware
If either of you sees a pitfall in the “motion follows feedback during internal homing” approach, I’d love to hear it — but it looks like the cleanest way to avoid discontinuities when returning to CSP.
  • nichtAlex
  • nichtAlex
28 Feb 2026 20:45
Umstieg von LinuxCNC + Mesa auf EtherCAT (Leadshine EL8 / Beckhoff) – Erfahrunge
Category: Deutsch
Das sind die A6-400EC 400 Watt EtherCat Treiber. Laufen mit einphasig 230V AC. Da die das cia402 Profil nutzen lassen die sich ganz normal mit LinuxCNC und der cia402 Komponente ansteuern. Beispiele für die ethercat-conf.xml gibts hier im Forum ja genug zu den A6 Treibern.
An sich stören mich die IOs der Treiber nicht aber ich finde das übersichtlicher/sauberer wenn alles auf die Beckhoff Module geht. Keine Lust da jetzt noch irgendwelche d-sub stecker zu löten für die Treiber. Habe durch mein Bedienpult nen haufen Digitalein- und ausgänge und mit den Beckhoff Modulen hab ich das schön sortiert.
Ich nutze die Treiber im inkrementalen Modus und referenziere nur über linuxcnc und nicht über den Treiber selber
  • Hakan
  • Hakan
28 Feb 2026 20:28
Category: EtherCAT
How about if we don't blame the drive for moving by itself during homing,
and instead make "motion" understand that it should follow the position feedback?
  • Felsenbart
  • Felsenbart
28 Feb 2026 20:28 - 28 Feb 2026 23:06
Replied by Felsenbart on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
For several days now I’ve been getting the error “Motor 0 position error” whenever I try to move Motor 0 (X-axis). At the moment, only this motor is connected.The setup uses a DM556Y driver with a NEMA 23 motor.
I’ve attached the .hal and .ini files.
I hope someone can help me figure this out.
thanks everyone :)
File Name: ec500_2026-02-28.hal
File Size:2 KB
File Name: ec500_2026-02-28.ini
File Size:2 KB
[/code][/code]
  • Hakan
  • Hakan
28 Feb 2026 20:20
Replied by Hakan on topic XHC WHB04B development?
Still trying to learn exactly where in the code it fails.
It doesn't reconnect, that's for sure. If it had, it wouldn't have been an issue.
I overwrite the log and, alas, no saved useful log.
"Unfortunately" I didn't get a crash today when I worked with the machine.
I like the whb04b a lot.It's worth spending some time improving stability.
  • my1987toyota
  • my1987toyota's Avatar
28 Feb 2026 20:16
  • magpie_lark
  • magpie_lark
28 Feb 2026 19:55
Running LinuxCNC on a Raspbery Pi5 using the Byte2Bot daughter board
Category: Installing LinuxCNC
I'm trying to set up the DB25 board to connect to a geckodrive G540 and running into some confusion. Currently reading the byte2bot guide on this and I'm confused about the hal_gpio pin naming. Where are these pin numbers for "pi5 2025" coming from?  They don't seem to match any pin mapping I've seen in any other online source. Do I use the 2023 or 2025 one?
Image of pinout naming matrix below.
  • Muecke
  • Muecke's Avatar
28 Feb 2026 18:57
Category: Deutsch
Hallo @nichtAlex,
welche Treiber sind das von StepperOnline?
Ich überlege, die A6-Serie (AC) zu nehmen, doch die von StepperOnline konnten mir nicht versichern, dass diese mit LinuxCNC funktionieren. Sie glauben es zwar, getestet haben sie es aber noch nie.
Was mich noch interessieren würde: Was stört dich an den IOs der Motortreiber, sodass du sie nicht nutzen möchtest?
Hast du den Home-Eingang dann nicht in Benutzung?
Sind das AC- oder DC-Motortreiber bei dir?
Gruß Mücke
  • NT4Boy
  • NT4Boy
28 Feb 2026 17:40
Replied by NT4Boy on topic REMAP Mcode seemingly ignored
Category: AXIS
I think that's a good thought, however, I've found M19 is not available to directly remap according to this .
14.1. Existing codes which can be remapped
The current set of existing codes open to redefinition is:
Tx (Prepare)
M6 (Change tool)
M61 (Set tool number)
M0 (pause a running program temporarily)
M1 (pause a running program temporarily if the optional stop switch is on)
M60 (exchange pallet shuttles and then pause a running program temporarily)
S (set spindle speed)
F (set feed)
  • Muecke
  • Muecke's Avatar
28 Feb 2026 17:32 - 28 Feb 2026 17:33
400V Servo (51 Nm) mit EtherCAT / CiA402 in LinuxCNC – bezahlbarer Drive gesucht
Category: Deutsch
Hallo zusammen,
ich möchte einen 400V Synchron-Servomotor in LinuxCNC über EtherCAT (CiA402) einbinden.
Ursprünglich war der Motor mit einem proprietären Encoder geplant, das habe ich jedoch verworfen.
Ich gehe nun davon aus, dass ein Standard-Drehgeber (z. B. Inkremental TTL/HTL oder BiSS) verbaut ist.
Der Drive muss also:
  • den Motor regeln (Drehmoment / Drehzahl / Position)
  • den Drehgeber auswerten
  • EtherCAT mit CiA402 unterstützen (CSP bevorzugt)
Motordaten:
  • Typ: 400V Synchron-Servo
  • Nennspannung: 400 V
  • Stillstandsdrehmoment: 51 Nm
  • Spitzenmoment: 120 Nm
  • Nenndrehzahl: 4500 rpm
  • Max. Strom: 122 A
  • Keine Haltebremse
  • Geber: Standard (kein proprietäres Protokoll)
Die Anwendung ist eine rotierende Achse mit Getriebe, keine hochdynamische Robotik.
Meine Frage:
Habt ihr eine Empfehlung für einen bezahlbaren EtherCAT-Drive mit CiA402, der:
  • 400V Klasse
  • ca. 50 Nm Dauer / 120 Nm Peak
  • Standardgeber (TTL oder BiSS)
  • sauber mit LinuxCNC (IgH + cia402.comp) läuft?
Der ursprüngliche Hersteller-Drive liegt bei ~4.000 €, das ist für mein Projekt zu hoch angesetzt.
Falls ich etwas übersehe:
Reicht es korrekt betrachtet aus, wenn der Drive:
  • den Motorstrom regelt
  • den Encoder auswertet
  • CiA402 unterstützt
Oder gibt es bei 400V-Servos noch typische Stolpersteine, die ich beachten sollte (z. B. Kommutierungsanforderungen, Encoderauflösung, Stromgrenzen etc.)?
Ich freue mich über konkrete Modell-Empfehlungen oder Erfahrungswerte mit LinuxCNC.
Viele Grüße
Mücke
  • JT
  • JT's Avatar
28 Feb 2026 17:29
Proposal to improve forum stability and structure
Category: Forum Questions
We are actually working on updating all the software now.
The downtime of the forum is due to DDOS attacks.
We actually have more control than I thought.
JT
  • Finngineering
  • Finngineering
28 Feb 2026 17:28
Replied by Finngineering on topic XHC WHB04B development?
I was just in the garage using the mill with the pendant. And thought that maybe I should post a mood picture, so we don't forget why we put effort on improving the pendant software :)
Displaying 1606 - 1620 out of 17365 results.
Time to create page: 0.301 seconds
