  • juliankoenig87
  • juliankoenig87
15 Nov 2024 16:08
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Ok. Everytime I use only the terminal I can get a connection to the 7i43.
Once I try to start linuxcnc I get an error. After that the pc freezes when I try to reacg for the card by the terminal.
  • PCW
  • PCW's Avatar
15 Nov 2024 16:04
Replied by PCW on topic Only one of the gantry joints move
Category: Basic Configuration
Can you post your hal/ini files?
  • juliankoenig87
  • juliankoenig87
15 Nov 2024 16:00 - 15 Nov 2024 16:05
Thank you for the support.
lspci:
Warning: Spoiler!
It is a Sunix 4008T card. I have a Sunix PAR6408A card for pci-e, but cant use it.
Tried also "cat /proc/ioports":
Warning: Spoiler!
mesaflash:
Warning: Spoiler!
  • meister
  • meister
15 Nov 2024 15:30
Wellcome back Mecanix :)
there are two new cool boards:
github.com/digiexchris/rio-solidwater-shield
github.com/festlv/rioctrl-hw
and little bugfixes in the software
@all
gitano from the german forum 'https://www.cnc-aus-holz.at'has put together a cool logo
what do you think of it ?
  • Malteser01
  • Malteser01
15 Nov 2024 15:25
Replied by Malteser01 on topic Only one of the gantry joints move
So, RodW, I've seen you helping loads of people throughout the forums with gantry issues.
I have no idea what I'm doing wrong.
I followed all the advice  I found.
In the ini, coordinates are XYYZ, where joints 1 and 2 are y axis, both with home_sequence=-2.
Individually with other configs they move fine and correctly.
Together they home successfully, but after that only Joint1 is moving when jogging Y.
Maybe it's different if I ran GCode, but I doubt it.
I am truly at my wits-end, and slowly I start to want to throw away this whole project out of frustration.
Which I really don't want to.
  • Mecanix
  • Mecanix
15 Nov 2024 15:08
Replied by Mecanix on topic LinuxCNC for lathe questions
Same same. Active "Axis UI" Gaga here!! 2ax LATHE, and also MILL. I'd use nothing else other than Axis even if paid or tortured. Sure a few will promote other UIs, but don't believe them, they are terrible influence  (jjk)
  • slowpoke
  • slowpoke
15 Nov 2024 14:44 - 15 Nov 2024 18:28
LinuxCNC for lathe questions was created by slowpoke
Bunch of questions, Hopefully someone can fill in a few blanks as I formulate a plan for the lathe.
I'm using Axis for my mill and I'm completely happy with it. I'm now considering using LinuxCNC for my lathe. I definitely want to maintain manual operation capability.
Presently I have a derivative of the Clough42 ELS with feedback from the spindle and a stepper driving the leadscrew for threading. I like the simplicity of selecting various thread pitches metric and SAE electronically.
1) I don't suppose LinuxCNC has this "ELS" capability?
2) I also have DRO scales. Assuming I will use a MESA board, is it possible to connect the scales to the MESA board and use LinuxCNC as a glorified DRO without actually driving any steppers/servos?
3) Assuming for the moment I can use LinuxCNC simply as a DRO, what MESA board(s) would be a good fit for say max 3 encoder inputs and possibly up to 3 steppers later?
 I have a RaspberryPi of some sort and I might try using it for the LinuxCNC for both space and $.
4) What RaspberryPI's are likely to have acceptable latency and what versions should I avoid?
 I find the Axis GUI a good fit for my needs on the mill, what GUI is a good fit for lathe control?
Much appreciated.
  • Mecanix
  • Mecanix
15 Nov 2024 14:41 - 15 Nov 2024 14:46
Did I missed anything? New Dev? New tricks!? Is RIO finally able to read minds and make a part start to finish on its own yet? Or I still need to CAD, CAM, Gcode fix this, gcode fix that, gear in tooling, fixture stuff, dial feedrate, make coffee, dial more, make more coffee?
Link up, Oliver. If you think I've missed anything important since 90 days shoot me in the correct direction please, I'll have spare time during the weekend to spy on The Best Cult around!
  • PCW
  • PCW's Avatar
15 Nov 2024 14:37 - 15 Nov 2024 14:39
Replied by PCW on topic Suggestion for a PCI EPP card for 7i43
You might try explicitly setting the high address in the hm2_7i43 command line (and the debug option)
did you try the --readhmid mesaflash option?
What kind of parallel port card do you have (what chip manufacturer?)
what does lspci report for the parallel port addresses? (trying to verify the high address)
  • Mecanix
  • Mecanix
15 Nov 2024 14:30 - 15 Nov 2024 14:32
Yo what's up Cult RIO & Awesome Fabricators! I hope Chief Technology Officer Oliver and his Lcnc crew are all doing fine?
Pardon my disappearance from my last updates, had to swing cross border to deal with pressing family issues (nothing health or negative related, only good stuff). The better news is when I came back I immediately rushed to the garage to see my gears and V O I L A , the RIO kit was shinning a led haha.
Everything werks spins moves scream slice chew cut chips its amazing to be back, it's just all full of f n dust everywhere though HELP lol
Thought to stop by and say Hello! Peace All ✌
  • JT
  • JT's Avatar
15 Nov 2024 13:54
Replied by JT on topic Flex GUI Tutorials
Flex GUI Tutorials
Category: Other User Interfaces
Tutorial 20
JT
  • hmearns
  • hmearns
15 Nov 2024 13:09
Replied by hmearns on topic Novakon Mill Conversion - Getting Started
Category: CNC Machines
Thank you! That did the trick. I did that when I was trying to mash two files together, but when I realized that I could use the wizard i forgot about it plus the wizard lets you select the drive which gives you 500 for that value which maybe keeps you from running away or burning something up but doesn't do much for making the motors turn. I dug the other specs out of my old files for the drive and put them in the wizard and the steppers sound happy again. Now I just have to get the spindle drive to respond and I'll be back where I started :O) Thanks again for your quick replies and patience with me.
  • AD_15
  • AD_15
15 Nov 2024 12:39
Unrecognized error -1 was created by AD_15
Hello!!
I have implemented mesa 7c81 on spartan 6. Raspberry pi is connected with my board (spartan 6) and we implement linuxcnc on that board, everything works good here but while we run some big files after some time it shows error Unrecognized error -1 and my python scripts stop suddenly, even estop didn't work, file will run but my scripts, estop functionality stop working. Please Suggest any solution.
  • aleksamc
  • aleksamc's Avatar
15 Nov 2024 12:19
Replied by aleksamc on topic Trajectory Planner using Ruckig Lib
Unfortunately I'm bad programmer))) But if you you will be successful (as it seems it is) in multi threaded running of g-code interpreters.
It would be good and easily to implement for user to add such possibility as "assign each axis to it's own g-code interpreter and path-interpolation with help of HAL.ini".
For example: assign axes X1,Y1,Z1, A1,B1 to thread 1.
assign axes X2, Y2, Z2 to thread 2.
  • juliankoenig87
  • juliankoenig87
15 Nov 2024 08:46
This is ma hal line
Displaying 17701 - 17715 out of 24286 results.
Time to create page: 0.415 seconds
