  • Danil
  • Danil
08 Nov 2024 11:46 - 08 Nov 2024 11:46
Replied by Danil on topic Please help create atc code
Category: Configuration Tools
Thanks for the reply, now I'm trying to do something via remap but I'm not sure I'm doing it right. I can't figure out how to interact with pin 17 on port 0.So far there is this outline of the remap, I would appreciate it if you could point out any errors.Thanks for the links, I'll have a look.
  • sk_linuxcnc
  • sk_linuxcnc
08 Nov 2024 11:41
Execute G-code when triggered by an external input (on parallel port input pin)
thank you for the guide. i am looking into it and so far it seems promising. i might have some questions down the line when i start building my g-code around the suggested solution.
  • Adam_C
  • Adam_C
08 Nov 2024 11:14
Which LinuxCNC version for a MESA 7i96s in 2024?
Which version of LinuxCNC is recommended for the MESA 7i96s (for a beginner user) in late 2024 / '25?
Debian 10 (Buster) + 2.8.4 has a few very good youtube beginner tutorials.  Is Buster + 2.8.4 still a reliable and recommended install?
A forum search on 7i96s + 2.9 seems mainly to be posts of people with issues getting 2.9 working reliably ...
I'd just like whichever solution is easiest to get up and running reliably!
  • Aciera
  • Aciera's Avatar
08 Nov 2024 10:26
Have a look at the halui.program.* halpins:
linuxcnc.org/docs/html/man/man1/halui.1.html
Depending on the gui you are using it may provide its own hal pins to steer program execution.
  • meister
  • meister
08 Nov 2024 10:25
You need only to lower the voltage a little bit for the Level-Shifter with a Diode or two Resistors,
the FPGA can handle up to 3.3V input and the Level-Shifter need to detect 1.8V as high.
  • Aciera
  • Aciera's Avatar
08 Nov 2024 10:24
Replied by Aciera on topic Rotary axis Display
Rotary axis Display
but after applying G54 on X, it becomes a mess:
This issue is a known limitation of the feature. Please read paragraph 11 the documentation I posted above.
  • tommy
  • tommy
08 Nov 2024 09:35 - 08 Nov 2024 09:36
Replied by tommy on topic Rotary axis Display
Rotary axis Display
I hope this video will make more clear what is happening, I have no issue with g-code from CAM, machined parts are ok, only display section is a bit off in my case:
  • sk_linuxcnc
  • sk_linuxcnc
08 Nov 2024 09:34
Hello, i am new to the linuxCNC systems.
I wish to build a simple rotating axis controlled by linuxcnc gcode. And i have a external robot which would perform some machining operations on the rotating part.
Now i want to sync both the machines. such that when i start the robot, the linuxcnc should also start executing the gcode.
Is it possible to execute the gcode when an input is provided through one of the parallel port input pins?
does the M66 code work here?
how to then pause the program if i pause the action of the robot (incase i have to e-stop the robot) and how to make sure then that the gcode is resumed from the paused location once the robot restarts and sends execution trigger to the linux cnc.
  • behai
  • behai
08 Nov 2024 08:04
Installing LinuxCNC 2.9 on Raspberry Pi 4B with Preempt-RT kernel
Category: Installing LinuxCNC
A shot from the hip, but usually those drive/steppers will have wrong encoder wiring, would be prudent to double check.
Hi tommylight,
It just so turned out you were right: one of my encoder wire were loose, I tightened it on the CL57T-V41 driver and it behaves now.
This is the wiring diagram:
My References for the Wiring Diagram:
1.
From 34:14 CL57T Driver Overview.
2. help.stepperonline.com/en/article/wiring...tepper-motor-4cddqy/
The first CL57T diagram.
3. pypi.org/project/cl57t-raspberry-pi-stepper-drive/
See the table for signal pins to the Raspberry Pi 4B.
And I have learned to work the ENA+ pin: setting it to low to enable, to high to disable.
The Python code below turns the motor 1 revolution, pauses for a little then keeps on turning till Control C to stop.
If I changed [ gpio.output( ena_pin, gpio.LOW ) ] to [ gpio.output( ena_pin, gpio.HIGH ) ] the motor won't turn.
Now I am trying to figure out why I need 1600 to do one revolution, it is about how the DIP switches are set, I have to understand the table in the manual :)
Thank you and best regards,
...behai.
# 08/11/2024
# Enable by setting ENA+ pin to low. Expected: motor will run.
# /usr/bin/python3 nema23_04_ena_enabled.py
from time import sleep
import RPi.GPIO as gpio
direction_pin   = 13
pulse_pin       = 6
ena_pin         = 19
cw_direction    = 0
ccw_direction   = 1
gpio.setmode( gpio.BCM )
gpio.setup( direction_pin, gpio.OUT )
gpio.setup( pulse_pin, gpio.OUT )
gpio.setup( ena_pin, gpio.OUT )
gpio.output( direction_pin, cw_direction )
# Enable.
# ENA pin must be ahead of DIR by at least 200ms.
sleep( 0.5 )
try:
    while True:
        print( 'Direction CW' )
        sleep( .5 )
        gpio.output( direction_pin,cw_direction )
        for x in range( 1600 ):
            gpio.output( pulse_pin, gpio.HIGH )
            sleep( 0.0001 )
            gpio.output( pulse_pin, gpio.LOW )
            sleep( 0.0001 )
except KeyboardInterrupt:
    # Disable.
    gpio.cleanup()
  • SertanATL
  • SertanATL's Avatar
08 Nov 2024 06:51
Replied by SertanATL on topic 7i76e I/O Input Field Stopped Working
Category: Driver Boards
In case this happens to anyone else, I reached out to Mesa and they replied back quickly. They offerred to fix the card for free if under warranty, for a small fee if not. Unfortunately shipping is more costly than card since I live in Turkey, therefore I decided to scrap the card.
  • SertanATL
08 Nov 2024 06:49
I ordered 3 new 7i96S for 2 of my machines and 1 backup. I only need few inputs, thank you for taking the time.
  • Creative25
  • Creative25
08 Nov 2024 05:20
Replied by Creative25 on topic Controlling a compressor with Linuxcnc.
Category: Plasmac
I struggle to find an electric unloader valve
on all of them it states for oil less compressors. Does that mean the seals will deteriorate from compressor oil? Or is it nothing to worry about?
  • Micro2000
  • Micro2000
08 Nov 2024 05:14
Replied by Micro2000 on topic LinuxCNC Error
LinuxCNC Error
This is with int graphics
08 Nov 2024 01:45
Replied by tommylight on topic Estop, external and internal with physical relay
Category: HAL
Done, thank you, i will delete this and the one above this after you get a chance to read it to keep this topic clean.
Displaying 18256 - 18270 out of 24295 results.
Time to create page: 0.682 seconds
