  • chernogorsky
  • chernogorsky
15 Aug 2024 16:48
Replied by chernogorsky on topic qtdragonhd / probing
Category: Qtvcp
It looks like with 2x Z it works
  • LucasWorx
  • LucasWorx
15 Aug 2024 16:42
Straight cut error was created by LucasWorx
Straight cut error
Category: Plasmac
Hey guys, I used to be able to use the straight cut button to make quick cuts across sheets, but now I always receive an error and I'm not able to make the cuts anymore. I think something happened with my .ini file awhile back but I see no issues. I can make programmed g-code cuts just fine. No matter how much I change the coordinates or where I'm at on the table I receive the same error. I've attached a screenshot of the error with my .ini file. I feel like this should be something obvious but I can't see the issue.
  • Moutomation
  • Moutomation
15 Aug 2024 16:23
Replied by Moutomation on topic Change the axis limit
Category: AXIS
Thanks to you, many of my problems were solved. Thank you very much for your help. You are truly an expert.
  • Souza
  • Souza
15 Aug 2024 16:19
Troca de ferramenta em linha was created by Souza
Category: Configuration Tools
Olá! Filipe
Estou realizando uma troca de ferramentas mais preciso fazer o seguinte quando ferramenta m6t1 tiver no spindle ela tem que volta para mesmo lugar que foi retirado para ir pegar a T2 como faço isso ?
  • PCW
  • PCW's Avatar
15 Aug 2024 15:59
Replied by PCW on topic 7i97t with 7i84d connection problem
Category: Driver Boards
OK that looks like a rod421m.0000,3600 which is a 5V TTL
or possible differential interface encoder which is good
  • Mecanix
  • Mecanix
15 Aug 2024 15:58 - 15 Aug 2024 16:19
@cornholio
I'm havin a hell of a bumpy start getting that ancient 2013 'ISE WebPACK' working under linux. Haven't tried windows yet. Is there anything like a lil more updated so to have those Spartan-6 working again?... or that's legacy rated already?
Mind sharing your eda/toolchain set-up? that'd be good info
edit: never mind/ignore. I had it. Took an hour to set-up the licensing, ./xsetup doing nothing, to having it installed but randomly crashing after 3 clicks, to realizing that I can't even access my usb ports anymore right now. Won't put up with this crap thank you very much. FORMAT HDD - Bye Spartans - back in the abandoned legacy gizmo box.
  • hans48
  • hans48
15 Aug 2024 15:49
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo
Danke werde es Versuchen.
Gruß Hans
  • fons
  • fons's Avatar
15 Aug 2024 15:31
Replied by fons on topic 7i97t with 7i84d connection problem
i take the encoder out of the machine and had a clear vieuw of the number  and there was another rcd in frond
the whole number is  rcd 421m.0000, 3600
i already found also  th original box of the encoder with inside the  color code of the wires
  • PCW
  • PCW's Avatar
15 Aug 2024 15:22
I cannot find that Heidenhain encoder, are you sure you have the number correct?
  • Mecanix
  • Mecanix
15 Aug 2024 14:20 - 15 Aug 2024 14:21
there is one, ok, i will try
discord.com/invite/SbskPKPJc6
Well bad news, tried to login with my old u/p and discord locked me up under the infamous pretext of "we've detected something unusual" so to fetch my mobile number & data for verification. a.k.a internet hacky-services I do not subscribe too anymore. And so deleted the account rather. Farewell discrooks, for another life maybe (not really!).
I'd invite you on a domestic venue I share open-source on with little over 120k cnc mind-like however nothing english there :( And so I guess we'll stick to platform-propriatary linuxcnc.org for updates!!
  • fons
  • fons's Avatar
15 Aug 2024 14:14 - 15 Aug 2024 15:24
i found some info
the spindeldrive
  reliance electric compay cleveland ohio model 1gaq811/1 30hp date 12/14/79          untill now i don't find any info
  ac in 480v 50/60 hz 3ph 69.4A
  dc out 240v 108A
x and z axe
   driver    inland motor  kollmorgen ireland  dpar 3330-00 serial 695                            untill now i don't find any info
   motor    continue 15v  20A 10 lb/ft  peak 67v 90A 45 lb/ft
tured  2 times
  aerotech inc   model 6020hr  690-1037  rev  "g"  dash #2  10 amp cont               online i found a user manual this drive had no secret anymore
shaft encoder  all 5 are the same
heidenhain model 421m.0000,3600 s8  (it was wrong in me previous post )                   i found the wire colors  in orginal box  in the lath machine
where can you buy a dc servo driver  for experiment testsetup   i don't find one   even not on aliexpress for a low price
  • chernogorsky
  • chernogorsky
15 Aug 2024 13:56
Category: Qtvcp
Will check on master and be back
  • Mecanix
  • Mecanix
15 Aug 2024 13:32
Spartans Warriors, Gowin C7 high-speed freshies, all up to the first-in-world high performance ESP P4 silicon on my benchtop!!! So much cool shit happening at this end I don't even know where to begin lool Let's start by finding a neutral hangout and relocate the share drive shall we. Really hope to catch you awesome guys on discord...
no. 82 & 159 outta 200 ;)
  • PCW
  • PCW's Avatar
15 Aug 2024 13:26
Replied by PCW on topic Mesa 7i77 out of stock everywhere
Still ironing out some bugs with the I/O section
(Especially remote updates of the DSPIC firmware)
For similar capabilities on currently available cards,
I would suggest a 7I96S +7I84 is more I/O is needed.
15 Aug 2024 13:13
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
If it wasn't so expensive to get the Mesa boards to Oz I would already have a 7i90 running the rio firmware.
I've been looking into doing a minor redesign of one of my boards to make the SPI connector more compatible with the WZ5500 blue boards with the yellow connector.
As these boards are compatible with the aforementioned Mesa models a external buffer board or generic BoB is a must. But on the plus side each and every pin can be used as an input or out put.
Just for a bit of reference the board that has the SPI interface connector on it has the following:
4 pins dedicated for leds
17 pin connector for use with a generic bob, 4 of the ground pins can jumpered to supply 5 volts.
3 pins on a header
And the 12 pins that are used for the EPP interface are available for I\O with the rio firmware.
32 pins not including the 4 dedicated to the LEDS.
The second board has
2x17 pin connectors for use with a generic bob, 4 of the ground pins can jumpered to supply 5 volts.
And 6 I/O pins on a header for I\O.
For a total of 40 pins.
So 72 pins available without having to use shift registers or anything like that.
All I\O pins are 5v tolerant except the 4 Leds & the SPI interface.
Of course the leds don't need to be installed, those pins could be used for a 3.3v interface to an external device.
Displaying 23836 - 23850 out of 24398 results.
Time to create page: 2.598 seconds
