  • alangibson
  • alangibson
27 Mar 2026 13:00
Replied by alangibson on topic Review Request for Arc Volt Sensor Schematic
Category: Plasma & Laser
I use the filter for a couple of reasons:
1. environmental noise
2. I don't trust cheap plasma cutters to output clean DC
I see a couple of capacitors and resistors as cheap insurance against potential future problems.
I want to be able to confidently support cheaper options like Lotos LTP5500CNC. That's the one I have. It works fine and is a small fraction the price of a Hypertherm.
I actually looked at supporting HF start machines in the past. I just couldn't justify the cost and effort.
  • JT
  • JT's Avatar
27 Mar 2026 09:58
Replied by JT on topic Flex GUI Keyboard Jogging
Category: Flex GUI
Anything is possible, I just need to think about the best way to implement that.
Just about finished a massive update on control enable/disable so the dust needs to settle a bit on that.
JT
  • Pierangelo
  • Pierangelo
27 Mar 2026 08:22
4-Axis RP5 with Bigtreetech Octopus Pro- How to make axis indipendent
Category: Driver Boards
Luca
Thank you for your response.
I have eventually managed to make it work.
It looks like the Octopus Pro board has Motor3 and Motor4 running in parallel.
I have used Motor0,1,3 and 5, defined XY;UV axis and it works.
Now I have 4 independent linear axis.
  • Hakan
  • Hakan
27 Mar 2026 08:15
I also wonder about the 2 50k resistors.
Good find on the regulated TMR-0511.
I looked at the output of the isolated power supply I use. I wasn't terrible, almost ok but not totally stable.
Why the filter step? HF?
  • Hakan
  • Hakan
27 Mar 2026 07:28
Replied by Hakan on topic Ethercat Setup help needed for beginner
Category: EtherCAT
Basically what you do is replace the motion part of the sim config with the ethercat motion.
Here is an example I often refer to. You do need the cia402 component as well.
github.com/dbraun1981/hal-cia402/tree/main/example
  • Yannis
  • Yannis
27 Mar 2026 07:07
Replied by Yannis on topic W axis machine config
The signals looks ok
Also on the WATCH tablet the virtual led for e-stop and machine enable are working fine
  • MiMaMoadlo
  • MiMaMoadlo
27 Mar 2026 06:58
Stepperonline A6 400W Servo RS485 Step/Dir (ohne EtherCAT)
Category: Deutsch
ja, der the stepperonline support hat mich noch auf diesen Artikel hingewiesen:
Why Does the Motor Not Rotate After I Connect My Pulse Controller to the A6 Driver? | Help Center
Mein Fehler war, dass ich den S-On Pin mit GND und nicht mit COM- beim Testen verbunden hatte, jetzt funktioniert es!
  • ts
  • ts
27 Mar 2026 06:38
Replied by ts on topic Flex GUI Keyboard Jogging
Category: Flex GUI
This is works cool
And is there option for toggle between continues and limited (0.01 0.1 1) movements? I mean for example if keyboard jog is active, and i push 1 on keyboard, jog speed switch to 0.01, if i push 2 on the keyboard, then jog speed switch to 0.1 etc
  • ts
  • ts
27 Mar 2026 06:17
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Additional :
I tryed to add halui to have functionality of power on button and reset with external hard button, but somewhy there is an errors duing start of halui. May be flexgui didnt let halui to start?
  • AntonioT
  • AntonioT
27 Mar 2026 06:12
THC not getting active even when "all seemingly needed" requirements are met
Category: Plasmac
ok, found this to try those 2 seconds maybe:
Two methods of THC activation are available and are selected with the Auto Activation check-button. Both methods begin their calculations when the current velocity of the torch matches the cut feed rate specified for the selected material:
Delay Activation (the default) is selected when Auto Activation is unchecked. This method uses a time delay set with the Delay parameter.
Auto Activation is selected when Auto Activation is checked. This method determines that the arc voltage is stable by using the Sample Counts and Sample Threshold parameters.
  • Nathan40
  • Nathan40
27 Mar 2026 03:10
Replied by Nathan40 on topic Qtplasmac- adding .py files as user buttons
I am trying to generate a pop up window telling if the nozzle needs change depending on the distance traveled.
26 Mar 2026 23:47
Replied by tommylight on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
  • jschulze
  • jschulze
26 Mar 2026 23:13 - 27 Mar 2026 03:37
Pico Systems Servo Controller was created by jschulze
Category: User Exchange
Had these sitting around and figured someone might be able to put them to use.  Pico Systems servo controller with 2 servo amps and braking resistor modules.  Also includes a spindle dac.  Had this running a 2 axis lathe that I ended up having to scrap.  $150 shipped in the US.
  • my1987toyota
  • my1987toyota's Avatar
26 Mar 2026 21:54
Replied by my1987toyota on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
Displaying 301 - 315 out of 17469 results.
Time to create page: 0.274 seconds
