  • unknown
  • unknown
29 Jan 2026 01:08
Replied by unknown on topic Debian Trixie upgrade/install to 2.9.4
Category: Installing LinuxCNC
Google "linux clone hdd"
And choose your poison, the subject is a bit expansive, and it's not something I'd like to describe to a newbie. There are many many ways to do this.
You can also use debian's preseed config to install extra apps.
Once again google "debian preseed" and you will have a clean install without any fluff.
  • grandixximo
  • grandixximo's Avatar
29 Jan 2026 01:07
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Please share a zip of entire configuration, so I can reproduce what you are seeing on my end, thank you
  • phino
  • phino
29 Jan 2026 01:05
Using Mesa 7i95T for laser + galvo (xy2-100) control
Category: Driver Boards
Do you need the galvo status?
Would be great to have firmware for both option. Thanks for making the firmware!
Are there instructions somewhere for building the firmware for oneself?
  • COFHAL
  • COFHAL
29 Jan 2026 00:56
Experimental raspios Linuxcnc Trixie images.
How do I create an image of the contents of one hard drive to install it on another? This is to avoid having to reinstall the additional applications I use with LCN.
  • COFHAL
  • COFHAL
29 Jan 2026 00:50
Replied by COFHAL on topic Debian Trixie upgrade/install to 2.9.4
Excuse my ignorance, but how do I create an image of the contents of one hard drive to install it on another? This is to avoid having to reinstall the additional applications I use with LCN.
  • COFHAL
  • COFHAL
29 Jan 2026 00:38 - 29 Jan 2026 00:40
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
I use Arduino Connector, I really like your project, it's very professional. I don't know if you plan to create matrix-type keyboards to simulate keys or to be used as HAL pins like in Arduino Connector, which gives great flexibility.
  • COFHAL
  • COFHAL
29 Jan 2026 00:32
Thanks, I had an error in the rules file, that's why that error appeared.
  • micklethenickel
  • micklethenickel
  • PCW
  • PCW's Avatar
29 Jan 2026 00:20
  • micklethenickel
  • micklethenickel
29 Jan 2026 00:16
Replied by micklethenickel on topic Using Mesa 7i95T for laser + galvo (xy2-100) control
Thanks! Yeah getting the firmware for this would be much appreciated :)
  • PCW
  • PCW's Avatar
28 Jan 2026 23:44
Yes, you can steal 2 Step/Dir channels to support the 4 differential output signals
that XY2-100 needs. If you don't need the status data back from the galvanometer,
that's all that would be required. If you need the galvanometer status, you could
steal 1 of the 7I95T's RS-422 serial port RX pairs
I can make this firmware if needed
28 Jan 2026 22:36
  • Ismacr63
  • Ismacr63
28 Jan 2026 22:12
keyboard shortcut was created by Ismacr63
keyboard shortcut
Category: QtPyVCP
I’ve been using Probe Basic for a while, and I was wondering if it’s possible to assign keyboard shortcuts to turn the spindle on and off.
  • Nkbhvid
  • Nkbhvid
28 Jan 2026 22:07
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Quadrature A,B and Z should be the standard of the ecodrives position signal.
Could you direct me to some knowledge resources or forum threads related to the setup?
Displaying 3316 - 3330 out of 17179 results.
Time to create page: 0.287 seconds
