  • freylax
  • freylax
03 Jan 2026 22:56
Lieber Oliver,
vielen Dank, die option rpi5:true hat geholfen, jetzt funktioniert die Axis App!
Nun kann ich mich in die Konfiguration vertiefen.
sei lieb gegruesst,
Robert
03 Jan 2026 22:55
Replied by tommylight on topic Mesa Configuration Tool
Category: Configuration Tools
Open a terminal and type:
sudo apt update
type the password and hit enter.
Now try to install MesaCT.
03 Jan 2026 22:51
Replied by tommylight on topic Servos drives directly start turning
Or is it possible that the drifting is normal (approx. 3-5 rpm)?
Yes it is normal for analog drives when there is no controller in use.
As I understand it, the axis should stand still when the OUTPUT_OFFSET is set correct, even in the normal CNC GUI. Is that correct?
Not entirely:
-the axis should stand still if everything is configured properly
-OUTPUT_OFFSET is used for adjusting forward/reverse speed, very rarely used.
You have other issues with enable not wired properly and controlled by LinuxCNC, you can NOT continue to do anything before fixing that as it is dangerous to you and to the machine.
The link i posted above, go step by step and check things work as described, no skipping.
  • T_D
  • T_D
03 Jan 2026 22:25
Ich brauche Hilfe bei meiner Konfiguration
Okay , thanks i want to use this board combined with a breakout board where the original flat cable sub d plugs are connected so i want to get +24v input signals and 24v output signals that means i just have to connect field a and b with the +24v from my power supply or do i have to connecht the two a and b with a bridge ?
  • PCW
  • PCW's Avatar
03 Jan 2026 22:15
The 7I84/7I84U has split field power supplies so you can have different
voltages (say 5V and 24V) on the inputs and outputs
You can normally ignore VIN as it powered by field power when W1 is in the default
left position.
  • PCW
  • PCW's Avatar
03 Jan 2026 21:37 - 03 Jan 2026 21:40
Replied by PCW on topic Servos drives directly start turning
Drifting usually indicates that you do not have the drive enables working.
The drives should be disabled until linuxCNC in running and in the machine-on state.
At this point, the encoder feedback and PID loop will prevent drifting.
If you get drift in the machine-on state that indicates a hal, encoder or PID tuning issue.
This is a safety issue, with analog drives, the drive enable is critical.
  • meister
  • meister
03 Jan 2026 21:35
Benutzt du einen RPI5 ?
dann trag mal bitte diese option mit ins json ein:
"boardcfg": "Olimex-ICE40HX8K-EVB",
"protocol": "SPI",
"rpi5": true,
"flashcmd": "/home/cnc/prog/olice40prog/spiflash.py -b rio.bin",
ansonsten bin ich etwas ratlos.
an welchem CS pin hast du das board ?
per default benutzt RIO CE0 an pin 8:
#define SPI_PIN_MOSI 10
#define SPI_PIN_MISO 9
#define SPI_PIN_CLK 11
#define SPI_PIN_CS 8
  • T_D
  • T_D
03 Jan 2026 21:29
Hello , i had figured out what the mistake was , i think i had taken bad cables because i took other cables and now the connection works and i have made some exercises for myself with a led and some playing with hal commands and now the 7i73 and the 7i84u is connected to the 7i74 per cat 6 cables and with the command " halcmd show pin" i am able to see 7i97t_7i73 and 7i97t_7i84u . Another question , why are there two vfield a and two vfield b screw terminals for the 7i84u for power supply and for what stands VIN ? I couldnt figure that out . Thanks for your answer.
  • JanCNC
  • JanCNC
03 Jan 2026 21:16
Replied by JanCNC on topic Servos drives directly start turning
Thanks for your reply. I've read through the entire forum thread, but I haven't found anything specifically related to my problem.
I suspect the OUTPUT_OFFSET value isn't working correctly. When I configure the axis in the pncconf wizard and adjust the offset value so the axis no longer drifts, everything works fine. However, as soon as I switch to the normal Linux CNC environment and enable the axes, they start drifting. I also tried disconnecting the analog signal connector from the 7i77 to see what effect it would have. There's no noticeable change. The axis drifts slightly faster, but that could be misleading.
Could it be that there are missing links in my .hal and .ini files? Or do I need to adjust other settings? I've also experimented with the calibration, increasing the P value or setting all values ​​to 0, but this hasn't helped. The axes are still drifting.
Or is it possible that the drifting is normal (approx. 3-5 rpm)? As I understand it, the axis should stand still when the OUTPUT_OFFSET is set correct, even in the normal CNC GUI. Is that correct?
  • Thllll
  • Thllll
03 Jan 2026 21:05
Replied by Thllll on topic Auto Tool Probe - not callable
Category: Qtvcp
Okay figured that out too, the "Tool Measure" needs to be ON in the probe tab. So now I am able to T# M6, it moves to tool sensor, I get the pop up, I change the tool, it starts to probe down...suspense... touches the tool sensor and I get the error below.
On a side note the tool sensor does work. I would say to exclude out the "probe tripped during non-probe move" because when using the offset commands "Go to Sensor" and "Tool Sensor" it works and I do not get that error, what is the difference?
  • Thllll
  • Thllll
03 Jan 2026 20:46
Category: Qtvcp
Made a solid jump in progress. The issue was the qt_dragon would appear to "freeze" thus looking at the terminal led me down this rabbit hole. The problem was the Message Dialog was not popping up (or maybe it was because you need to acknowelge it to do anything). Either way I am starting to think the "not callable" is normal?
After checking my .hal file and my postgui.hal file the problem was this wasy in my postgui.hal file, I was missing this in my postgui.hal file and I comment out all the unlinkp lines ande uncommented the toolchange signals.
net tool-prepare-loopback  iocontrol.0.tool-prepare  =>  iocontrol.0.tool-prepared
Attached is what I have as the lastest and I was able to somewhat make progress, it goes to tool senosr and the message dialog appears now! However after I accept I get the next error
Sat03 12:35: Auto Tool probe disabled
  • Thllll
  • Thllll
03 Jan 2026 20:36
Category: Qtvcp
I corrected the program prefix, to be one and have the "~" at the start. Ran again I am getting the following from the terminal. The path is valid as well. The following is from the terminal
home/cnc/linuxcnc/configs/New_TAIG_dragon/New_TAIG_dragon.ini:92: executing 'import sys
sys.path.append("/home/cnc/linuxcnc/nc_files/examples/remap_lib/python-stdglue/python")'
PythonPlugin: Python  '3.13.5 (main, Jun 25 2025, 18:55:22) [GCC 14.2.0]'
is_callable(__init__) = FALSE
[QTvcp.QTVCP.QT_ISTAT][WARNING]  Path not valid in INI File [DISPLAY] PROGRAM_PREFIX section (qt_istat.py:96)
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_LINEAR_VELOCITY Entry in DISPLAY, Using: 5 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_POWER Entry in DISPLAY, Using: 1500 (qt_istat.py:532)
is_callable(oword.on_abort) = FALSE
task: main loop took 0.119162 seconds
is_callable(oword.qt_auto_probe_tool) = FALSE
I compared to the sim .ini file and found that the "~" was not part of the program_prefix. Running it again without the "~", cleared the error
Still does not work but this was noticable
Running the sim actually in debug shows the same thing..
/home/cnc/linuxcnc/configs/sim.qtdragon.qtdragon_tool_probe/qtdragon_auto_tool_probe.ini:120: executing 'import sys
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
tool_result(id=2, xoffset=0.0, yoffset=0.0, zoffset=0.1, aoffset=0.0, boffset=0.0, coffset=0.0, uoffset=0.0, voffset=0.0, woffset=0.0, diameter=0.0625, frontangle=0.0, backangle=0.0, orientation=0)
  • freylax
  • freylax
03 Jan 2026 20:31 - 03 Jan 2026 22:34
Hi Oliver, thank you! I post the configuration (json.txt), linuxcnc_print.txt output and a copy of the terminal output linux_cnc_out.txt
I generall I know that I have to do some HAL configuration to (software) wire the machine together. What for the beginning is not so easy to know is what exactly has to be done. I see what your rio-setup does, and there is also the possibility to make linuxcnc HAL net connections in the setup, but what is necessary to start with..
I'm looking forward to hear from you,
regards, Robert
PS: do you run robot os on RPI5 Debian Trixie?
  • Surmetall
  • Surmetall's Avatar
03 Jan 2026 20:14 - 03 Jan 2026 20:15
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
thanks a lot for the update. I’m always happy to see new progress in this thread! :)
Also thanks for the screenshots, everything is looking very promising.I noticed that you’re writing the manual in German as well, so I assume you’re German too.
If you’re interested in chatting "in real time" in German with like-minded people, there’s a German-speaking Discord from Peter aka Talla83. You’ll find many LinuxCNC users there, including quite a few lathe users. If you’re ever looking for feedback or beta testers, that could be a good place to connect.
Of course, this is only meant as an addition, please definitely keep posting updates here as well. If you are interested, here is a Discord server invite link: discord.gg/dPBgNR3t
Best regards
Tom
  • Fastfred
  • Fastfred
03 Jan 2026 20:05
Replied by Fastfred on topic Manual tool change + tool lengh touch off
Hopefully not a silly question if i got this tool change config to work could I use it with easyprobe with min effort? (Axis Gui) easy probe not yet installed but like the GUI AXIS/Easy probe very basic.
Displaying 4726 - 4740 out of 17018 results.
Time to create page: 0.271 seconds
