  • NWE
  • NWE's Avatar
27 Dec 2025 16:45
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
I think I got it!
  • Use ferrites/EMI filters on the lines coming in and out of the VFD - this solved my problem!
I'm happy to hear of your success!
I want to add a clarification to that one bullet point: EMI filters are very good for the input side of VFDs, but don't try them on the output side unless they are listed for such use. The output side of a VFD produces such a high level of harmonics, a common emi filter will smoke. Ferrites are fine for input and output side.
  • tlightus
  • tlightus
27 Dec 2025 16:33
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
i did notice you use machine zero as the G54 offset. try setting it off that and run the test.
  • zippoffs
  • zippoffs's Avatar
27 Dec 2025 16:06
Replied by zippoffs on topic DIY CNC Mill - Random Limit Switch Errors
I think I got it!
I tried moving the AC lines by the BOB, but that didn't work, probably because I didn't move them far enough. Last night I added a ferrite on the AC lines, and I was able to run the program without failing. This morning I removed the earth ground because it was temporarily through my window, and ran the program again. It did fail.
When I started building it I had installed an EMI filter on the main power coming in, before the breaker box. I now realize that anything coming in is negligible compared to what the VFD produces. So I moved the filter to the VFD 220v lines. I think that fixed it! I have now run the program three times without fail! (see pic)
Thank you everyone for your help!
For those looking at this later, here is what I learned:
  • Interference is a BIG ISSUE
  • Separate AC and DC lines as much as possible
  • Use shielding on low voltage signal lines (maybe fine without if 24v)
  • Use a shielded spindle cable and keep it short!
  • Ground all shielding, but only at one end
  • Avoid ground loops - only have one ground connection for each component
  • Ferrites may help stop interference - try putting them if other things don't work
Do these things from the beginning! It will save you a huge headache.
  • grandixximo
  • grandixximo's Avatar
27 Dec 2025 15:44
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
github.com/linuxcnc-ethercat/linuxcnc-et...631ab668516b649fcaaf
Posted the PR
Will be happy to get some feedback, thanks
  • dann1324
  • dann1324
27 Dec 2025 13:46
Replied by dann1324 on topic 7c81 + 7i73
7c81 + 7i73
Category: Driver Boards
Okay,I did a dumb haha. I got a little too hung up on pncconf not picking up the 7i73. So I started linuxcnc and ran halcmd show pin | grep 7i73 and they're all there. I'm just going to set my pins in my hal file and it should be good to go
  • dann1324
  • dann1324
27 Dec 2025 13:09
7c81 + 7i73
Thanks for the quick response. I ran mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --sserial and seems like it's communicating with the 7i73! I'm still not sure why pncconf isn't showing it? Is there some extra hal configuration that I need to do?
Here's the truncated output from the mesaflash command, just to show it is there
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 2
SSLBP Baud Rate: 2500000
sserial device at channel 1: 7I73 (unit 0x130001F9)
SwRevision = 14
HwRevision = 1
NVBaudRate = 2.5Mb
NVUnitNumber = 0x130001F9
NVWatchDogTimeout = 50ms
  • RotarySMP
  • RotarySMP's Avatar
27 Dec 2025 12:31
How to install simplescreenrecorder on old version of Debian?
I could but that is a pretty huge overhead on a old pc.
27 Dec 2025 12:22
No idea, but you can always use OBS-Studio
sudo apt install obs-studio
27 Dec 2025 12:20
Replied by tommylight on topic Bluetooth Mouse on Linuxcnc
Category: Basic Configuration
2.9.4 is based on Debian 12 so might have better luck asking on Debian forums.
  • MaHa
  • MaHa
27 Dec 2025 11:16
  • Lili
  • Lili
27 Dec 2025 10:57
Bluetooth Mouse on Linuxcnc was created by Lili
i installed Linuxcnc 2.9.4 , and would like to use Mouse with bluetooth(logitech m350s).
kommand sudo apt update shows that adding this repository is not safe and disabled by default.
WHAT TO DO ?:)
  • RotarySMP
27 Dec 2025 10:16
Hi All,
My Maho 400E is still running an old version of Debian, with XFCE, that would have been the live CD back in about 2019. For my videos, I need to install simplescreenrecorder, as pointing a camera at the screen is lame.
I have tried:
sudo apt-add-repository ppa:maarten-baert/simplescreenrecorder
sudo apt update
sudo apt install simplescreenrecorder
This fails with "unable to locate simplescreenrecorder."
Please help with this. I seem to forget all linux knowledge the instant whatever I was trying to do gets done :/
Cheers,
Mark
  • abs32
  • abs32
27 Dec 2025 08:17
How to fix "Queue is not empty after probing"
да пожалуйста.
According to my observations, the queue error simply replaced the error  Probe tripped during non-probe move.
  • NWE
  • NWE's Avatar
27 Dec 2025 07:33
Wow, that's a lot to take in.
Sorry, I think I made too big a deal about some of this. That is a nice mill you've got. With a few tweaks it'll be fine.
  • NWE
  • NWE's Avatar
27 Dec 2025 07:29
Do the 220v lines going from the breaker box to the VFD also emit interference?
Yes.
Not sure how I overlooked this part of your question previously.
Displaying 5116 - 5130 out of 16967 results.
Time to create page: 0.339 seconds
