08 Dec 2025 14:59
Qtplasmac- Auto Z axis movement not happening with thc proma 150
Category: Plasmac
Does the machine reach the requested speed while cutting?
If it does not, it will not turn height control on.
What are the settings on the Parameters page?
Set the VAD to 60% first and try again.
  • Nathan40
  • Nathan40
08 Dec 2025 14:15
Category: Plasmac
hi,
The Z axis DRO will not move in spite of the following in Raspi 4/5:
a. torch on
b. THC enabled setting
c. HALSHOW is showing move up and even.
d. After trying the changed settings mentioned previously on proma.
e. Mode is 2 for the external THC
Please help as I have been trying to do the same for few weeks now and let me know if any settings need to be added in the HAL or ini.
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
  • abs32
  • abs32
08 Dec 2025 14:04
  • Masiwood123
  • Masiwood123's Avatar
08 Dec 2025 13:54
freelancer needed to create a routine for ATC tool change (rackchange)
this won't work either in sim mode or in reality, I tried something via chatgpt but I know that it doesn't work, it can't create a routine. here is my configuration if anyone is free to look at where the error is and what needs to be added in Hal eventually. Tx m6 works but will not return the tool to its pocket when you give it another tool, it also reports in the bottom line that there is no tool even though in reality it took it. each pocket has its own active high sensor on inputs 16-21 and the spindle has a sensor for ``flush'' input 10 the tool is in the spindle, input 12 reports that there is no tool in the spindle. Thanks
File Name: betabeta_2...2-08.zip
File Size:22 KB
youtube.com/shorts/CXxlm92xtt8?si=KCv1wBtX9AL_1eM2
  • abs32
  • abs32
08 Dec 2025 13:28 - 08 Dec 2025 13:30
Probe tripped during non-probe move deadlock
Perhaps due to the language barrier, we are misunderstanding each other.
1. There was a bug in version 2.8.4, which was fixed in 2.9.7.
2. Instead of fixing the bug that was interfering with the operation, they created a new one for which there is no solution.
However! First, I used a steel probe (before electrical contact) as a probe. Then I bought a Chinese Probe sensor (a so-called center finder). It did not suit me for a number of reasons:
1. Unacceptably high operating force (“out of the box” 450 grams, with my processing “with a file” (and a hammer) about 220 grams.
2. speed of operation
In version 2.8.4, I got 50,000-80,000 continuous sequential measurements at a rate of 5,000-6,500 per hour. But in version 2.9.7, the usual error for 2.9.7 appeared
And the other day I made my own version of such a sensor. The actuation force is 15 grams. The operating speed is higher (to such an extent that during G0 movements, the vibration sensor is triggered). But in version 2.8.4, I haven't exceeded 10,000 continuous measurements yet. In version 2.9.7, I got up to 12,000 measurements per hour, and now (tests are being conducted right now) more than 13,000 measurements without errors.
Conclusions: it is quite possible that version 2.9.7 works adequately with high-quality sensors.
  • andrax
  • andrax's Avatar
08 Dec 2025 13:14
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Edit:
i just realized that I probably have the same problem as @dschultz.
I just don't know how to switch to variable PDO mapping?
I believe the real issue was the drive didn't like the PDOS I had in the xml.
Even though my original settings were one of the "Fixed PDO mapping" options from the manual (1704 & 1B02).
Anyway, I switched it to the "Variable PDO mapping" 1600 & 1A00 and the drive goes to OP mode and comes alive when I enable the machine!
Has anyone had success with setting up the CIA402 homing mode?
  • jschulze
  • jschulze
08 Dec 2025 13:11
Replied by jschulze on topic First LinuxCNC Project
Category: Show Your Stuff
Very cool. That little lapping machine is awesome.
08 Dec 2025 13:00
Replied by tommylight on topic Probe tripped during non-probe move deadlock
The updates in 2.9.7 fix (hopefully) a bug where the "probe triggered during non-probe move" error was raised when the machine was actually probing (due to probe contact bounce).
Am i understanding this correctly:
A software solution was implemented in LinuxCNC for a hardware problem/issue ?
It does seem like it, or what am i missing?
  • andypugh
  • andypugh's Avatar
08 Dec 2025 12:50
Replied by andypugh on topic Probe tripped during non-probe move deadlock
It kinda improved, but the „probe triggered“ fault is still happening.
I was not able to finish even shorter milling programs (<5 mins).
If you are seeing the message when _not_ actually probing (and you refer to a 5 minute milling cycle, with no mention of probing) then that is a different issue.
  • voltaicsca
  • voltaicsca
08 Dec 2025 11:58 - 08 Dec 2025 11:59
First LinuxCNC Project was created by voltaicsca
Makin' Christmas presents... We like dice games.
Cross-posted from reddit, so I could include some media a bit more easily.
www.reddit.com/r/Machinists/comments/1ph8ig5/comment/nsx4clj/
So, I just got a Precision Matthews PM-970 (RF45 clone) up and running with a Linuxcnc based retrofit with all of the bells and whistles. This is my first project.Also, built a planetary gear polisher, since I don't want to hand-polish 6 sides of 36 dice.Not a single step of this went the way I planned, but I think the work product turned out nicely.I didn't tune the PID properly to begin with, which I think is why my final dims were ~5 thou out of spec in some parts. This cascaded down to needing to remove more material in sanding/polishing. I left the final profile cut to 0.005", but didn't do a spring pass, which I think led to some tool deflection, which caused some tilt in the second op.Anyway, for a first CNC project for a manual machinist. I'm happy.
  • jc2ktr
  • jc2ktr
08 Dec 2025 11:16 - 08 Dec 2025 11:18
Replied by jc2ktr on topic Config 2 ethercat ports?
Category: EtherCAT
This is my Config which should Work.
It´s a small setup in my Shop on my Workbench. It is for tinkering with, EtherCAT & LinuxCNC.
The PC is an old Siemens Microbox PC with 3 Ethernet Ports.
File Name: ethercat_t...ench.zip
File Size:5 KB
08 Dec 2025 11:14
Replied by tommylight on topic Hybrid Manual/Stepper Control
I am pretty sure something can be done with some hal or tailor made component, but i never had the need for such thing.
Should be possible with encoder feedback to LinuxCNC as it will continue to monitor position even when drives are disabled, but i do not recall if it also adjusts the output position while disabled (i think not).
That also has the advantage of using the LinuxCNC as a DRO when using it manually.
  • andrax
  • andrax's Avatar
08 Dec 2025 10:58
Category: EtherCAT
Here is my cthercAT.xml.
When loading, I get an error saying that the pin lcec.0.A6.control-word already exists.
>EtherCAT pdos< gives me completely different addresses for the A6 400W.
0x6060 is not mapped:
It is possible that my XML has an error.
But how am I supposed to write an 8 (csp mode) to 0x6060 if it does not currently exist on the A
File Name: ethercat.xml
File Size:8 KB
6 400W?
Here is the excerpt from my post again:
A6 750W
=== Master 0, Slave 0 ===
SM0: PhysAddr 0x1000, DefaultSize  256, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize  256, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize   12, ControlRegister 0x64, Enable 1
  RxPDO 0x1600 ""
    PDO entry 0x6040:00, 16 bit, ""
    PDO entry 0x6060:00,  8 bit, ""
    PDO entry 0x607a:00, 32 bit, ""
    PDO entry 0x60ff:00, 32 bit, ""
    PDO entry 0x607c:00, 32 bit, ""
    PDO entry 0x6098:00,  8 bit, ""
    PDO entry 0x6099:01, 32 bit, ""
    PDO entry 0x6099:02, 32 bit, ""
    PDO entry 0x609a:00, 32 bit, ""
SM3: PhysAddr 0x1c00, DefaultSize   28, ControlRegister 0x20, Enable 1
  TxPDO 0x1a00 ""
    PDO entry 0x6041:00, 16 bit, ""
    PDO entry 0x6061:00,  8 bit, ""
    PDO entry 0x6064:00, 32 bit, ""
    PDO entry 0x606c:00, 32 bit, ""
    PDO entry 0x6077:00, 16 bit, ""
A6 400W
=== Master 0, Slave 1 ===
  RxPDO 0x1701 ""
    PDO entry 0x60b8:00, 16 bit, ""
    PDO entry 0x60fe:01, 32 bit, ""
  TxPDO 0x1b01 ""
    PDO entry 0x603f:00, 16 bit, ""
    PDO entry 0x60f4:00, 32 bit, ""
    PDO entry 0x60b9:00, 16 bit, ""
    PDO entry 0x60ba:00, 32 bit, ""
    PDO entry 0x60bc:00, 32 bit, ""
    PDO entry 0x60fd:00, 32 bit, ""
  • voltaicsca
  • voltaicsca
08 Dec 2025 10:12
Replied by voltaicsca on topic Hybrid Manual/Stepper Control
Thanks for the replies! I have considered putting independent x/y MPGs somewhere on the machine, but it doesn't quite scratch the itch I'm trying to scratch.
My background is a manual machinist, and I wanted to add some CNC capability to my arsenal, even if that came at the cost of being able to do manual machining the way I used to. That said, there's no substitute from the feedback you get from turning the cranks, when you just need to make a quick slot, face a part, etc.
It seems like LinuxCNC (appropriately) is really intended almost exclusively for the CNC use case.
  • Hakan
  • Hakan
08 Dec 2025 07:58
Replied by Hakan on topic StepperOnline A6 Servo
Category: EtherCAT
Every slave must have its own configuration in the config xml file.
See example here. github.com/dbraun1981/hal-cia402/blob/ma...le/ethercat-conf.xml
You must enter the config for the new drive.
Displaying 5791 - 5805 out of 16959 results.
Time to create page: 0.398 seconds
