  • LCR
  • LCR
02 Dec 2025 21:53
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I don't seem to have that handy. I will be back to the machine in a week or 2. I will make a backup and upload my configuration. What issues are you having?
  • Gogonfa
  • Gogonfa
02 Dec 2025 20:48
Delta ASD-B3, CiA402 and joint following error
Category: EtherCAT
could you finally solve the following error problem with your delta Servos?
I am really interested to learn more about the problem and the final solution.
best wishes,
Gogonfa
  • PCW
  • PCW's Avatar
02 Dec 2025 20:46 - 02 Dec 2025 20:53
Replied by PCW on topic Reduce read-all timing 7i76e + 7i77
That's a great condensed source of network latency reducing tips
Only quibble I would have is that:
setp hm2_7i76e.0.read.timeout 100000
Is not correct as the hm2 read timeout is scaled in percent of the servo period
EDIT: actually that is correct as values larger than 100 are interpreted as ns
But a 100 usec margin is very small on most systems and will likely result in many
unnecessarily dropped packets .
Default is 80% of servo period and this is fine normally
  • Sandro
  • Sandro
02 Dec 2025 20:26
Replied by Sandro on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
How did you realise the integration loop? Is it possible to share your cia402.conf?
  • speppino
  • speppino
02 Dec 2025 19:58
Test to check if I can submit a post was created by speppino
just checking if I can read my submitted post. I submitted one previously but do not seem to find it even in my recent post tab.
  • endian
  • endian's Avatar
02 Dec 2025 19:14
Replied by endian on topic Reduce read-all timing 7i76e + 7i77
Rod share your tips please or add them to my guide ... I really like to learn something new about this topic!
  • zoeper
  • zoeper
02 Dec 2025 19:06
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
My ears have their own ring, so I get used to things like that easily. I would however love to dump the 30+ year old DC servos and Amps in favour of something more modern. Looking at the complexity of my electrical cabinet in comparison to modern systems makes me think there is room for improvement too. If I can get it up and running first, at least it can make some money to pay for its own upgrades. ;)
  • dcsilvias13
  • dcsilvias13
02 Dec 2025 18:24
Ethercat Leadshine L6N Gantry XYYZ Config was created by dcsilvias13
Category: EtherCAT
Hello, I wanted to add my configuration files to help some of you.  I know many of you have been like me scowering around for answers looking up every possible key word to get your system up and running.  Now I don't have a spindle hooked up yet this is just to get X Y Y2 Z up and running.  There was some configuration in the Leadshine Parameters as well that had to be made. 1 of those is Parameter 6092 (0x01) had to change to 10000, not sure why, but it just worked.  Also make sure all the slaves correspond as well with the PDO's. Just remember this is very basic in what I had to do to get the servos moving and running with one home/limit switch per AXIS.
File Name: axis.ini
File Size:6 KB
File Name: ethercat-conf.xml
File Size:4 KB
File Name: EtherCatv1.2.hal
File Size:5 KB
  • nanowhat
  • nanowhat
02 Dec 2025 18:19
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
The next time I see that error, I will try those things.
  • NWE
  • NWE's Avatar
02 Dec 2025 17:47 - 18 Dec 2025 05:16
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
I am working on an Ursviken press brake retrofit to LinuxCNC and decided to document my progress, schematics, etc here, and probably ask questions along the way. If you have any hints or advice for me, feel free to say so.
This press brake came with a Compaq pc booting some form of MSDOS and a Mitsubishi FX-64M PLC. The machine had been forgotten in a warehouse for who knows how long until the current owner ended up buying it. After installation in the shop, upon first power-up, it complained of a depleted PLC battery. Sadly, the new battery didn't recover the lost memory. After multiple unsuccessful attempts to get Ursviken to get the thing working again, he showed me this project. I said I think I can make it run on LinuxCNC.
I pulled the PC and the PLC and installed a "Fanless industrial mini-pc" with 4 ethernet ports. For i/o I am using Mesa 7i80HDT + 7i36 + 7i54 and Beckhoff ethercat EL1409 16-inputs and EL2409 16-outputs.
Original 10 axis configuration was:
Y1 and Y2 = left and right ram (top die height)
X = backgage forward/backward motion
R = backgage up/down motion
Z1 and Z2 = independent left/right motion of the two backgage fingers.
Crowning: This feature currently has a mechanical malfunction so the customer asked me if I could leave crowning as an option for later if he decides he wants it. I said yes.
VDT = variable width bottom die, appears to have been present on the machine at some point but was apparently deleted.
PSB and PSA = automatic sheet lifter with a height axis and an angular axis. My customer requested to remove that because it will be in his way more than he uses it.
Target configuration:
Y1, Y2, X, R, Z1, Z2, and optional crowning. Y2 is slave of Y1. Z1 and Z2 are independent, except they run on the same rail and must not collide.
Y1 and Y2 speed and direction are powered by two servo valves, driving those with h-bridge outputs on the Mesa 7i54 card is working great. Plus, there are six 24VDC spool valve coils that need to be activated with relays in the correct combination for up, down, fast, slow, dwell, and decompression. Tonnage is set open loop via a proportional relief valve powered by an h-bridge output from the Mesa 7i54 card. 0% pwm = no pressure, 100% pwm = max pressure. The proportional solenoid coil had an RC snubber attached that interfered with the 7i54's current regulation, I removed that RC snubber, as the 7i54 neither needs nor likes it.
X and R axis each have a Baldor 90VDC servo with tachometer feedback to the Cybelec servo amps and encoder feedback to the PC controller. The Cybelecs' speed command is set with +/-10VDC from the 7i36 card.
Z1 and Z2 axis are DC worm drive motors powered by fwd/rev contactors and basic encoder feedback to the mesa card.
Crowning is a common AC 3 phase induction motor on a worm gear box driving an ACME lead screw protruding from the left side of the bottom bed. It is powered by a fwd/rev contactor.
  • Dudelbert
  • Dudelbert
02 Dec 2025 17:31 - 02 Dec 2025 17:43
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
I’m heavily dyslexic, so I write it myself but let ChatGPT make it readable, even though it changes the grammar more than I’d like — it’s still better.
Regarding the question of manual tool changes, what I mean is this:
Consider that you have a toolholder with two tools in tool-changer position 1. Because you’re making a very complicated part, you need more toolholders than you have positions in the changer. In this situation, you will eventually have to exchange the holders manually.
What I want is for the machine to ask me only when my input is actually needed. I’m not too concerned about a few unnecessary moves.
What I do want to minimise is the number of times I have to intervene, and the number of points where I can mess up. That’s why I want a single point of truth for the pocket number on a ganged toolholder.
Edit:
Examples of when it should not do a manual tool change:
Changing to a different pocket that already has the correct toolholder in it.
Changing to the same toolholder but to a different tool mounted on that holder.
And if it does need me to exchange a holder, it should have already rotated the turret so the pocket to be used is positioned in front
  • speppino
  • speppino
02 Dec 2025 16:30
MesaCT 2.1.8: Scale vs Encoder Scale was created by speppino
Category: Configuration Tools
Dear all, I am new to Linuxcnc and trying to setup a bench test before connecting motors to my machine. I got Stepperonline A6 series 400W that allow analog control. I setup velocity mode on them and I setup a mesa 7i97T to control them with analog signal and get a feedback from the servo drive. I am sure I nailed all the wiring properly, but when I setup the MesaCT 2.1.8 to generate the configuration file I have doubts on what to put into the tool when it comes to selecting the axis Scale and then the encoder scale. My A6 drive have 17bit encoders that translate into 131072 pulse/rev. But I also see in the drive parameter that it is set by default 2500 lines ( that in quadrature should be 10000pulse/rev). my max velocity in the drive is set to 3000rpm.
My confusion is now to understand what parameters to input in the mesact config. for now I just want to test a motor (x axis) without any connection. Can someone expert chime in on the value to input in Max Velocity, Max acceleration, axis Scale, and encoder scale, to make this run and proceed to next step PID calibration?
What I need is a clear explanation on what is SCALE vs Encoder Scale input field. I seem to be confused when I read the manual of the mesact. They seem to be the same thing. I understand that the scale should be calculated based on gear ration between encoder and motor etc etc. In my case the encoder is the motor encoder and the SCALE of the axis is for now not connected to anything. The plan is later to place this motor on a 1604 leadscrew (4 mm pitch).
Thanks in advance and apologies for this novice question, but could not find anywhere a clear explanation.
  • PCW
  • PCW's Avatar
02 Dec 2025 16:07
parport observation in outport out-inverter-1 seems not to work
Category: HAL
I think you may be misinterpreting how the invert parameter operates,
it does not change the state of the parport.0.pin-NN-out hal pin.
(It cannot as this hal pin would be driven by a hal signal)
but rather changes the physical output polarity. You cannot
detect this change in the parport.0.pin-NN-out hal pin but only by
measuring the actual parallel port hardware output pin.
  • Dudelbert
  • Dudelbert
02 Dec 2025 15:55
Category: Turning
I may be misunderstanding something, but I personally would not want to think about where I need to insert an M1 to manually change a holder. I want LinuxCNC to make that decision automatically based on the tool table.
That’s not actually the case in my system.
The diameter is only used on the “tool descriptor” entries, which represent toolholders, not real tools.
These descriptor tools never get used for cutting, so they never participate in G41/G42 or wear offsets.
But yes—this could just as well use the Pocket field. I didn’t think of that originally.
I will lrady make that change in the rest off this post.
Why I believe encoding the holder layout in the tool table is better
Here is a heavily simplified tool table to show the idea:
T5 P1 X0 Z0 D0 // holder #1 in turret pocket 1
T6 P— X100.34 Z-15 D10 // spot drill
T7 P— X120.876 Z-32.657 D10 // drill
T8 P— X140.298 Z-15 D10 // drill
T9 P— X160.3 Z-15 D10 // boring bar
T10 P5 X0 Z0 D0 // holder #2 in pocket 5 (5%5 = 0 → rear post)
T11 P— X100.23 Z23.456 D0 // parting blade
The descriptor (T5, T10, T15, …) stores the physical pocket number. so they are th single sorse of trus for this.
This means LinuxCNC can always determine:
Whether a manual holder change is needed
Whether the correct holder is already in place
Where the turret needs to rotate
Which tools belong to which holder
Whether a requested child tool even exists
If we don’t have this structure, I don’t see how LinuxCNC could determine where a tool belongs.
You’d have to manually encode the correct pocket into every single tool entry.
This leads to another issue.
Problem with the pocket-in-every-tool approach
Imagine two tools in CAM that both used to be in turret position 1.
But for a different job, you need to rearrange holders.
Then you must:
Change the pocket numbers in LinuxCNC for all affected tools
Update your CAM tool library to match
Remember to do this every time you rearrange holders
Add M1 manually at the right positions
Hope nothing gets out of sync between CAM and LinuxCNC
This is exactly the kind of workflow that causes human error.
Maybe I am overcomplicating things — but in my head this system makes sense.
It gives LinuxCNC the information it needs to make reliable decisions, without forcing the user to manually sync CAM, tool table, and machine setup every time a different combination of holders is used.
Displaying 5986 - 6000 out of 16959 results.
Time to create page: 0.271 seconds
