  • EdWorks
  • EdWorks's Avatar
16 Nov 2025 14:47
I think StepConf does not work for my installation?
Category: StepConf Wizard
Parallel ports share much in common with GPIO pins so I wasn't sure. Thanks for the response and particularly the references.
  • PCW
  • PCW's Avatar
16 Nov 2025 14:33
Replied by PCW on topic 7i96 with analog Spindle Servo
Category: Driver Boards
I think that should work with a couple conditions:
1. You must have a digital spindle enable signal because the spindle output will default to -5V
when LinuxCNC is not running or after a watchdog fault
2. You need to set the PWMgens offset mode "true" so that a 0 PWM value results in
a 50% duty cycle and therefore a 0V output
  • mooser
  • mooser
16 Nov 2025 14:30 - 16 Nov 2025 14:36
2.9.4 7i96s - pendant doesn't go active until after a MDI move is made
Category: HAL
That's what I figured but I can't seem to get it to work.
I've tried
setp halui.mode.in-teleop 1 but that's an output so it errors as not writable
setp halui.mode.is-manual 1 but that's also an output so it errors as not writable
Tried
setp halui.mode.manual 1 doesn't seem to do anything
setp halui.mode.teleop 1 doesn't seem to do anything
setp halui.mode.enabled 1 No such pin error
Looking at the states when the program loads and I can't use the MPG
10  bit   IN          FALSE  halui.mode.auto
    10  bit   OUT         FALSE  halui.mode.is-auto
    10  bit   OUT          TRUE  halui.mode.is-joint
    10  bit   OUT          TRUE  halui.mode.is-manual
    10  bit   OUT         FALSE  halui.mode.is-mdi ==> MDI-mode
    10  bit   OUT         FALSE  halui.mode.is-teleop
    10  bit   IN          FALSE  halui.mode.joint
    10  bit   IN          FALSE  halui.mode.manual
    10  bit   IN          FALSE  halui.mode.mdi
    10  bit   IN           TRUE  halui.mode.teleop
and after I make some kind of MDI move
    10  bit   OUT         FALSE  halui.mode.is-joint
    10  bit   OUT          TRUE  halui.mode.is-teleop
    10  bit   IN           TRUE  halui.mode.manual
I see that the halui.mode.is-joint went from true to false. And probable a coincidence but the last thing I did was to get the MPG to work AFTER a MDI move I also changed the references for the MPG from joints(from a previous setup I did years ago)  to axis references.
Guess I'll try setting that to false as well and see what happens
Thanks for the help.
M
  • abs32
  • abs32
16 Nov 2025 14:22 - 16 Nov 2025 14:26
v2.9 and not the perpendicularity of X and Y
Thank you, however, this is not necessary. If you already have a Matrixkins component built into the LinuxCNC kernel, then you need to use it. According to the description, it is quite suitable. The main thing is to understand the configuration synatxis for hal.
According to the description, the component built into the kernel solves issues of three axes at once. Simple (linear), but closes.
I don’t have the realkins component itself. The forum where this component was published has already died. The module is here. That's exactly what's holding me up on version 2.8.4
  • Aciera
  • Aciera's Avatar
16 Nov 2025 13:42
If you attach the code of your current 'relkins' component I can have a look at updating it to be used in version 2.9
  • juergen-home
  • juergen-home
16 Nov 2025 13:20
  • abs32
  • abs32
16 Nov 2025 13:11 - 16 Nov 2025 13:15
From the description at the link I see the following alorhythm -
1. I know the amount of deviation
2. in the case of XU, I need to explicitly specify the parameter for the formula -
X_joint = C_xx * X_axis + C_xy * Y_axis + C_xz * Z_axis
Those. I know the coefficient from clause 1
C_xx = 1
C_xy = (deviation X divided by width Y)
But what are the rules of use, syntax, examples?
loadrt matrixkins count=0
C_xx = 1
C_xy = 0.03
or
C_xy = [3/100]
or otherwise?
how to change the C_xy parameter on the fly without rebooting the program?
if loading a component requires specifying the contact number count=N, then N is what, what are the options? And where should this count be specified in the C_xy job?
In general, we need examples of syntax and application
In man, the example section of the configuration file shines with emptiness
  • Wischi
  • Wischi
16 Nov 2025 12:58
Sinker EDM machine based on diy pulse generator
I just worked through the Ben Fleming circuit (not 100 % yet). It seems that the voltage is ~ 100 V DC and the current can be limited by power resistors. A couple of mosfets get pulsed by a 555 timer, the pulse duration is set via pots. I replicated part of the circuit in LTSpice an ran a couple of different pot settings to get an idea of the pulse on and off duration. Also compared these values to commercial machines. The calculated frequency is ranging from 0,5 kHz to 60 kHz. Do I even need the 555 timer and the two pots or could I use PWM signal from linux to do that? A mesa card can go up to 386 kHz so should be plenty of room for that.
All those can be easily done with any microcontroller, but might need better ADC converters.
That would be important for the voltage gap feedback. Would an off the shelf voltage to frequency converter work for that?
  • Nest
  • Nest's Avatar
16 Nov 2025 12:50
Problema de altura en el eje Z was created by Nest
Category: Español
Hola a todos. Tengo una CNC3040 con motores nema 23 con electrónica mesa 7I96 y husillos de bolas recirculantes.
    la utilizo para la fabricación de prototipos de placas de circuito impreso o PCB, pues antes de empezar ha hacer el trabajo tengo que subir y bajar muchas veces el eje Z para que corte a la medida exacta... Por ejemplo.
Mando el comando para que los ejes se posicionen en el origen de la pieza y le cargo el archivo gcode y le doy a empezar. Pues observo que no está cortando a la altura correcta, vuelvo a mandar los ejes al origen máquina y vuelvo a darle a comenzar el trabajo y vuelve a cortar a la altura incorrecta y vuelvo a repetir el ciclo hasta que en una de esas ya corta a la altura correcta y ya no vuelve a perder la altura y termina el trabajo perfectamente, en los ejes X e Y no le pasa eso ¿Alguien sabe que le pasa al eje Z y como podría corregir el problema?.
Saludos
  • abs32
  • abs32
16 Nov 2025 12:48
sounds really good, thanks for the answer.
Are there any configuration examples somewhere? that loadrt is clear.
The current version 2.8.4 I can -
1. enable
2. launch a geometry check program, which, based on the results of the Sonde of the first class square, will calculate and tell me the amount of deviation from the perpendicular
3. Without turning off the program, I can enter a command like - in the terminal -
halcmd setp relkins.adjX.Y1030 -1.82
and get the corrected geometry without restarting the program.
How to do this in version 2.9? are there any examples?
  • Aciera
  • Aciera's Avatar
16 Nov 2025 12:37
I'm not familiar with 'relkins' but it will likely need updating due to the addition of the switchable kinematic feature. Discussion:
forum.linuxcnc.org/49-basic-configuratio...-xyz?start=10#311322
However there is a hal component included in version 2.9 that should handle all kinds of skew corrections:
www.linuxcnc.org/docs/devel/html/man/man9/matrixkins.9.html
  • Aciera
  • Aciera's Avatar
16 Nov 2025 12:17
probe_basic_postgui.hal conflicts with my gamepad*.hal
Category: QtPyVCP
By default it is not possible to 'loadrt' the same hal component twice.
Try enabling TWOPASS:
linuxcnc.org/docs/html/hal/twopass.html
  • juergen-home
  • juergen-home
16 Nov 2025 12:02
Category: QtPyVCP
I try to integrate my gamepad (which is working under axis) into Probe Basic.
When I read the error report correct "not: already exists" is the complaint.
I tried to format the not function in an other way in the probe_basic_postgui.hal, but that doesn't work.
Even if I only add a simple halfile = not.hal (instead of gamepad-encoder-16.hal) with a single not function I get an error.
  • gravedigger
  • gravedigger
16 Nov 2025 09:50
Replied by gravedigger on topic 7i96 with analog Spindle Servo
  Does this diagram apply to a bipolar connection?
www.aliexpress.com/p/tesla-landing/index...aXGaNZQaAvhREALw_wcB
  • Masiwood123
  • Masiwood123's Avatar
16 Nov 2025 07:29
Replied by Masiwood123 on topic MesaCT 7i96s + 7i77
MesaCT 7i96s + 7i77
Category: Configuration Tools
I have now installed version 2.1 which accepts the official version of mesaflash 4.3.6... and I have no problem with exporting the configuration, but mesact messes up the configuration and here are a few things
1: does not export the given maximum velocity
2: export joint 0 instead of x for 7i77
3. will not enable drivers trough ena+ ena- on 7i77
4: instead of recognizing the pins it exports something like 7i96s.0.7i77.0.4 analogout instead of 7i96s.0.7i77.0.1
5.i/o also exports 7i96s.7i77.0.3 instead of 7i96s.0.7i77.0.0
and so on... I can't get a configuration that otherwise works with pnccfg normally, except that I would have to manually enter everything related to 7i96s, so in the end I will have to do that. I don't know how to post what you suggested on github so that the errors can be corrected. sure thank you very much
Displaying 7081 - 7095 out of 16695 results.
Time to create page: 0.283 seconds
