06 Nov 2025 11:22
Replied by tommylight on topic Fiatech exhibition - 9 axis ethercat setup
Category: Show Your Stuff
Bedava means free, right?
  • kor
  • kor
06 Nov 2025 10:26 - 06 Nov 2025 10:59
pc for linuxcnc using ethercat and Mesa
I am looking to buy a "firewall" PC with 4 ethernet ports to have one ethernet port for my mesa 7i76e one for ethercat and one for LAN.
Do you have recommendations for that currently I am looking at this system on amazon: amzn.to/4nEujde it has 4 x i226-V 2.5Gigabit Ethernet ports and seems to be fine for a linuxcnc build what do you think.
Or do you think I should rather get a normal big pc and get pci-express lan cards?
  • pmchetan
  • pmchetan
06 Nov 2025 09:38
Replied by pmchetan on topic MECHATROLINK-II interface
Category: Driver Boards
Hey,
I have Omron R88D-GN04H-ML2 drives in a three axes CNC pick and place setup. The drive takes the commands from Omron trajexia MC04/ML04 motion controller. I was hoping, I could control the servo drives from linuxcnc but found out about the mechatrolink-II network is the only available command interface to the drives. I would like to buy the FPGA hadware that you developed. May I contact you through personal email?
  • KlausB
  • KlausB
06 Nov 2025 09:31
Touch Plate was created by KlausB
Touch Plate
Category: Qtvcp
With this installation, I also tried the touch plate function. It’s visible that after probing the touch plate, the program sets the Z value to the height of the touch plate before executing the retract. This causes the retract value to be added, and the resulting height above the object is correct.
Unfortunately, the program then subtracts the length of the current tool, which in my case is not useful.
Is it possible to disable this behavior?
Thank you very much for your support.
Best regards,
Klaus
  • KlausB
  • KlausB
06 Nov 2025 09:18
z_level_compensation again was created by KlausB
After experiencing issues with other software on my computer, I decided to perform a fresh installation using the current DVD version 2.9.4. (2.9.7 after Upgrade)
Unfortunately, I'm once again encountering problems with Z-Level Compensation.
After creating the “probe_points.txt” file, I can enable “Z-Comp”, but the value in the “Z_Axis Comp” field does not change as expected. Once “Z_COMP” is turned off, it cannot be reactivated without restarting the program.
Do you have any idea what might be causing this?
Best regards,
Klaus
  • Hakan
  • Hakan
06 Nov 2025 09:11
Replied by Hakan on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
What I noticed right away was that they use SyncManager 0 for process data. This is not normal.
SyncManagers 2 and above are for process data, SM 0 and 1 are for mailboxes and handles SDO upload/download especially during the early phases like INIT.
I don't think you can change the syncmanagers, the device has what it has, but a wild experiment could be to change the SyncManager idx="0" to idx="3". If you haven't thrown the device in the bin already :)
  • Gogonfa
  • Gogonfa
06 Nov 2025 08:18
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
EdingCNC uses a Chinese clone of this wireless handwheel, probably with a customized Product ID. I’m not sure if this is a general issue, but it might be interesting for users who want to switch from EdingCNC to LinuxCNC without buying a new wireless handwheel controller.
The controller sold by EdingCNC — which is basically identical to the ones available on AliExpress — costs more than €300. It is needed in order to run with the EDING CNC Software.
  • unknown
  • unknown
06 Nov 2025 08:08
@Gogonfa
It might be worth raising an issue on github & maybe request that the PID could included on the line that loads the driver.
Could be of immense help further down the track.
  • emresensoy
  • emresensoy
06 Nov 2025 07:42
Fiatech exhibition - 9 axis ethercat setup was created by emresensoy
1 x spindle
8 x ethercat servo motor
1 x pals dir step motor
1 x ethercat 12x digital analog io card
1 x ethercat 32x digital io card
linuxcnc 2.9
  • Gogonfa
  • Gogonfa
06 Nov 2025 07:29
Hi @all,
the issue with the Product ID on my Eding CNC branded wirless Handwheel ist solved. By changing the PorductID in the usb.h file and a rebuild of LinuxCNC, everything works fine
  • deltafox24
  • deltafox24
06 Nov 2025 06:42 - 06 Nov 2025 06:43
Replied by deltafox24 on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
Yes, of course, here it is.
I removed it from there.
GEOMETRY = AXYZ
from there because it doesn't work for me anyway.
File Name: mycnc.ini
File Size:6 KB
  • deltafox24
  • deltafox24
06 Nov 2025 06:24 - 06 Nov 2025 06:25
Replied by deltafox24 on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
I don't know about certification. But I do know that the system crashed in 80% of cases when I used this module. I installed CATIO-A and the system started working stably.
  • Ritterchen
  • Ritterchen
06 Nov 2025 06:06
Replied by Ritterchen on topic Injection molding
Injection molding
Category: CNC Machines
Hi there,
I implemented an DIY Arduino a few weeks back into my automatic injection molding machine. So cool to see that topic popping up again!
For the background, I have two CNC machines running on LinuxCNC as well and I am familiar with some Arduino-Coding too.
In the beginning I evaluated the exact same question as you here and went with the Arduino based PLC-Route as it is easier to implement hardware and manage timers easily, which there are a lot of in injection molding as many events in a cycle are time-based.
A few lessons learned so far were:
  • The evaluation of "Readymade" ESP32/Arduino resulted that there is no real all in one provider like Beckhoff Ethercat modules. That drove me away from it as you still need additional "raw PCB boards" for e.g. temperature input. Then "real" PLCs like Ethercat are freaking expensive if you need anything but standard IOs. Could be an option if you base everything on second hand components!
  • These modules are really nice: sequentmicrosystems.com/products/eight-t...bj3cF5BPXDmnSfa68zMp
    They are a bit more expensive then a MAX31855 etc. but a very clean solution, easy to install and you can just stack it on top of a Raspberry PI. And are very well documented too + some Libraries exist. Not affiliated with them, just made a really good impression!
  • Having temps all in one controller is nice for process debugging
  • Used Breakout boards as Optocouplers, SSR Output boards (240V AC 1-2A), external SSRs (40A) and DC Relay boards (24V) and the Temp input board of Sequent Microsystems.
    To be honest I would next time spend a bit more with Sequent Microsystems - they seem to be fairly well priced and offer a lot more IOs and flexibility then the "All in one" Arduino based PLCs. But if money is a big constraint you can go with the single modules too.
  • I prefer SSRs just because they are silent, and basically free today and never had a cheap Asian branded fail
  • For the IO side Arduino is pretty nice and fast as it is easy to connect components and debug them. E.g. for installing a linear scale I did not need a Mesa card or other boards just connected it to an interrupt and fed it to an existing Library.
  • I used BlockNot to create parallel tasks, such as asking for sensor states at fixed intervals, have interrupts for linear encoders, run all the cycle timers... that is a very cool lib to work with!
  • Okay now the butttt...
    As soon as you want to build an GUI for it it becomes annoying. Maybe its my lack of experience for it or I am not aware of better solutions. Let me know if anyone is aware of a similar GUI solution to LinuxCNC (in flexibility) but for simple controllers?!
    I tried to use Nextion Displays - which are displays with their own IC. That is cool as they mostly run smooth without Display lags in comparison to other solutions and have a GUI editor.
    The pain is that you need to manage the whole communication between the display IC and the IO-IC (e.g. Arduino) manually. Eg. read button pushes from the display and feed data back. That is not impossible but a ton of (unnecessary?) work. Additionally the GUI modules come with good limitations in all directions- e.g. you can only have 4 data inputs into a diagram display which is already limiting on e.g. temp tracking. The graph you get is also not really useful in manner of navigation as zoom/ set scale etc. There are many things that need to be build to get something usable.
So I got stuck and ran it from basically a serial console + manually edition code for changes. That kind of works for home/DIY but is not a "solution" I would say as I run this machine for work. Okay that is a bit funny, but its actually some kind of special setup that does not exist on the market.
So my position is that I have a working machine, but no real interface.
I consider now to mange all the IO's by Arduino as nothing is really time critical and the linear encoders in my app don't need to be updated to the GUI in real time. You can also mix both options and use a motion card like Mesa or a simple Breakout card for motor control and safety IOs and do the rest with an external "PLC".
Some strong points for LinuxCNC in this application:
  • Easy to build GUIs
  • Real time IO's for motors+safety
  • ShowHAL+HalScope is priceless for real-time debugging of states, that would need to be programmed as special IO's otherwise
  • Settings can easily saved in files - I would miss-use a .nc file to save projects, temps and timings?
Weak points for LinuxCNC in this application:
  • Calculations and conditions are just painful as you need to do everything with components, which would be a simple calc sign otherwise :/
  • Not sure how to implement a nice cycles with timings? Could be several timers connected to each other! Would be cool to be able to activate/deactivate these in real time on GUI input to control auxiliary devices.
  • Is there an option to use e.g. the HalScope inside a GUI? Or have another graph implemented?
Let me know your thoughts and considerations, happy to exchange ideas here!
  • unknown
  • unknown
06 Nov 2025 05:51
"file ./live/filesystem.squashfs failed the MDS checksum"
Category: Installing LinuxCNC
That's a windows splash screen, not a splash screen when booting a Linuxcnc install disk.
Download this program and install, after reading the whole page.
win32diskimager.org/
When you insert the USB stick you want to make a Linuxcnc bootdisk don't let windows do anything if it cant read your USB stick, windows does not be able to read the USB stick.
Run the Program you just installed.
Select the image, the image you have confirmed the md5sum is good, if not download it again and check again. I'm not a windows user so you'll have to search how to check the md5sum under windows. Also select your USB drive, do not select a hard disk.
Write the image to the USB stick.
If windows complains about not being able to read the disk DO NOTHING. Everything is ok.
Reboot the computer and select USB boot. If you are going to install make sure you have enough space on your disk or have an unused disk available for Linuxcnc.
I recommend this tool as all it does is copy form the image file to the usb stick byte for byte. It doesn't try to be fancy, it does exactly what is required to create a bootable USB Stick from the image.
  • clayton2ndtry
  • clayton2ndtry
06 Nov 2025 04:14
I got past that. It attempts to boot from USB drive but this is as far as it goes.  See attachment.
Displaying 7546 - 7560 out of 16721 results.
Time to create page: 0.446 seconds
