  • mariusl
  • mariusl's Avatar
27 Oct 2025 18:16
USB activity causes network error was created by mariusl
Category: Plasmac
I have seen the following issue occur on three machines that Range from 2.9.3 to 2.9.6.
The hardware is all cases are Lenovo i5 mini PC's running MX Linux 23.x Bookworm. The WiFi dongle is a USB type
What seems to happen is that when there is USB activity the network to the Mesa 7i96S will get a read error. It means that the network message could not be compete in one cycle. It typically happens when the USB stick is removed or inserted, especially if the machine is busy executing a program. It will also happen if the WiFi is active like when a file is uploaded to the nc_files directory from a laptop on the network.
Is there anyone else that has maybe seen this or know of a solution?
  • amanker
  • amanker
27 Oct 2025 18:14
Need Help in Kinamatics of Small DIY 6dof robotic arm.
It's giving kinamaticsInverse failed error. As per documents joints can't have offset values. So to align J1 and J2 these must be in line, arm j1-j2 should be horizontal to give offset values zero. But practically I can't make arm in this position.
  • PCW
  • PCW's Avatar
27 Oct 2025 18:13
Replied by PCW on topic MESA 7I92 programming
Category: Driver Boards
Xilinx based cards use .bit files, not bin files.
When you build a 7i92 configuration (using the seveni92,xise project file),
the tools will built a bitfile named TopEtherneHostmot2.bit.
Normally you would rename this to YourNewName.bit
  • Aciera
  • Aciera's Avatar
27 Oct 2025 17:49
With all joints in the zero position does the arm point down towards the floor as shown in the documentation?
Maybe you could elaborate a bit on what isn't working.
  • jc2ktr
  • jc2ktr
27 Oct 2025 17:45
ethercat verbindung zu bosch-rexroth HCS01 über eoe(ethernet over ethercat)
Category: Deutsch
Hallo,
EOE ist im igh ethercat driver nicht funktionstüchtig( driver < 1.7 ?) und sollte beim kompilieren deaktiviert werden.
Gruß
Rüdiger
Mag ja sein, wenn du den igh-Treiber aber aus dem Repository installierst ist EOE doch Automatisch aktiv? Oder kann man das ohne EOE installieren? Da wird ja dann nichts mehr kompiliert, ebenso ist es ja mit den verschiedenen Treibern auch ? (e100, e1000e & generic)
  • TJ
  • TJ's Avatar
27 Oct 2025 17:37
Replied by TJ on topic MESA 7I92 programming
I managed to install Xilinix.
It's not yet clear how it will generate the bin file.
It's not even clear where to insert the finished xx.bin file so that Mesa CT can see it, I can't see the directory structure.
Pncconf only throws up a couple of configs?
Where to insert it in Pncconf so that it can see the configuration pins.
This Linux is very different. :)
  • amanker
  • amanker
27 Oct 2025 17:35
I have read all documents and tried to understand DH parameters and how kinamatics works. And read the documents many times to have good grap of the subject. I tried my best to explain geometry of my DIY arm.
I am attaching photo explaining more about geometry of arm.
I hope this might better explain geometry of robotic arm.
  • jmp97
  • jmp97
27 Oct 2025 17:01 - 27 Oct 2025 18:00
Replied by jmp97 on topic LinuxCNC installation + 7I96S
Category: Installing LinuxCNC
I have something to mention. By increasing the Stepgen value on the three axes (from 24 to 30 in maxvel and from 120 to 150 maxaccel) when moving the motors quickly with the arrow keys, it no longer disconnects as easily as before. Could that be the source of the problem? When attempting to create a new configuration with Pncconf, there is some data that I do not know how to configure.
They also mentioned something about ‘isolcpus’ and ‘cpuset’ since my processor is an Intel Core i5-12400 2.5 GHz (new generation) and it could be related to that.
Edit:   I get this error (see attached image)
  • kb58
  • kb58
27 Oct 2025 16:32 - 27 Oct 2025 17:11
Replied by kb58 on topic Changing starting point on 2D job
Huh, shows what I know - I'll certainly check out Inkscape!
To be clear, I use Alibre for CAD and borrow Vcarve's vectoring feature to convert it to G-code with my own post-processor.
27 Oct 2025 16:32
Replied by tommylight on topic LinuxCNC installation + 7I96S
 With PNCConf, I couldn't get a configuration that would even allow LinuxCNC to exit emergency mode.
Make a new config, do NOT change or add anything at all except 3 stepgens and scaling.
You can go back and modify it, or make new configs to your hearts content, add switches and sensors and motors and propellers ... but do NOT just chose and change stuff at random.
27 Oct 2025 16:27
Replied by tommylight on topic Changing starting point on 2D job
Not what you asked, but try Inkscape, it is free and it exports ready for use gcode, and more importantly very easy to use and add a line for were you want the cut to start.
Vcarve is really, really not for EDM, as far as i am concerned.
  • Snoopyrider
  • Snoopyrider
27 Oct 2025 16:10
User Install for Probe Basic Py3 (For Machine Control)
Category: QtPyVCP
gents,
i would like to get some advise please. i have performed now a 2nd install, i tried APT ansd DEB also. i have an issue that :- the startup of probe basic takes "ages" compared to qtdragon, i mean like 30-40 sec( of course i could live with that, i just saw on my friend install it takes max 5sec.
- i can not reset estop. as i click on it timer froze up to 5-7 sec, nothing happens. the logic in hal was working fine with qtdragon so i assume there is nothing wrong there.
1 more thing that is still very confusing me, that in the configuration guide, "Step 2: Copy required files" it says "Copy the required files from the probe_basic_machine_config_setup_files folder to the Pncconf config folder." but ther are 2 folders, machine_config_setup_files folder AND probe_basic folder, both contained similar folders and files. From which i should copy the files?
thx in advance
  • PCW
  • PCW's Avatar
27 Oct 2025 16:01
7i97T stepgen outputs dead, encoders & I/O OK - suspect damaged P2 interface
Grounding is a really big subject but here a bit of advice
For standard step/dir drives with opto-isolated inputs, grounding is not
super important as there is little coupling from the drive to the step/dir lines
 It is important however  to keep encoder and step/dir lines away form any motor or power
lines to prevent unwanted coupling ( both inductive and capacitive ) from these noise
sources to the low voltage signal lines.
For encoder, analog, and step/dir lines to non opto isolated connections, a common ground
is vital between the 7I97T and the signal source/destinations. The exact wiring for the common ground
and reference to earth ground depends on the drive design. Typically motor drives will have an earth
ground but may have an isolated input or output common. If the drives have an isolated common input,
this should connect to the 7I97T GND and then be connected at one place to the earth ground.
  • ihavenofish
  • ihavenofish
27 Oct 2025 15:53
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
i'm not in linuxcnc yet. i'm testing it on windows. Drive settings are right. Its not receiving any data back of any kind. Feels like a cable thing. hmmm
  • Aciera
  • Aciera's Avatar
27 Oct 2025 15:51
There is documentation on how to set up genserkins:
www.linuxcnc.org/docs/stable/html/motion/dh-parameters.html
I can't quite tell from the picture how many joints your arm has but genserkins will only work for manipulators with 6 joints.
Displaying 8041 - 8055 out of 16894 results.
Time to create page: 1.182 seconds
