  • Ingo
  • Ingo's Avatar
22 Oct 2025 20:31
7i92H was created by Ingo
7i92H
Guys, I'd like to hear your opinions.
I have a 7i92H and would like to build something very compact with reasonable performance. What do you recommend using, a Raspberry Pi4, Pi5, or even a mini PC?
Ingo
  • Philip Lydin
  • Philip Lydin
22 Oct 2025 20:29
Subroutine error was created by Philip Lydin
Subroutine error
Im setting up my cnc which has a toolchanger but i have some weird issues that if the tool prepared and tool changed iocontrol hal pins goes high i get an error that line 0 would exeed the z axis / joint 2 limit. I have 2 machines running linuxcnc but still cannot seem to figure out the problem. Im very lost so any info would help.
o<toolchange> sub
M73
G90
G53 G0 Z0
G0 X0 Y0
o100 if [EXISTS[#<_ini[traj]axes>]]
    #<geometry> = #<_ini[traj]axes>
o100 endif
o110 if [#<geometry> EQ 4]
    G0 A0
o110 else if [#<geometry> EQ 5]
    G0 A0 C0
o110 endif
o<toolchange> endsub [1]
M2
this sub is just as a test.
File Name: hal_2025-10-22.txt
File Size:12 KB
File Name: ini_2025-10-22.txt
File Size:4 KB
  • Murphy
  • Murphy
22 Oct 2025 20:09 - 22 Oct 2025 20:23
As far as I know , only quadratic encoders are currently supported with remora and rt1052
I'm not sure about the ec300 but the ec500 has the ability for hardware counting but you have to bypass the optocouplers as they are shite.
  • royka
  • royka
22 Oct 2025 17:28
Replied by royka on topic Update LinuxCNC 2.9.5 on debian 13
Category: Installing LinuxCNC
Yeah I could but I'd like to have a Trixe & Bookworm base image to work off. I'll get that going tomorrow (doesn't take too long) and have a look at the amd64 live-build for Trixie. Tho I'm a little desperate for disk space and had to drag a 2TB mechanical drive out of the cupboard.
This week's spending money went on RAM........so maybe in a couple of weeks I'll grab a NVMe drive.
Maybe if I stuck with Mach3 I wouldn't spend so much money, bugger I said the quiet part out load.
But that's no fun, too easy
22 Oct 2025 16:25
How to create profile for path that is not closed loop
Category: CAD CAM
Do give dmap2gcode a try, it is free, it is python so can be edited, but it does generate perfect gcode for my "scratcher" machines, i just modified it to output M67 values instead of Z depth:
forum.linuxcnc.org/show-your-stuff/46752...ver-etcher-scratcher
Another tip for Inkscape to save time, lots of time, when exporting in the "path to gcode" window, click on "sort paths to reduce rapid distance", a huge time saver.
  • Unlogic
  • Unlogic
22 Oct 2025 15:41
Replied by Unlogic on topic Probe Basic backplot error when loading file
Category: QtPyVCP
Thank you for a quick reply!
Just as a precaution is there anything special I need to take into consideration when upgrading to the development version?
  • jc2ktr
  • jc2ktr
22 Oct 2025 15:23
Replied by jc2ktr on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Sorry for the late Answer,
yes i had this Error in Festo Automation Suite too first. I don´t really know what i´ve done that it works now.
File Name: cmmt.ini
File Size:2 KB
File Name: EtherCAT_CMMT.hal
File Size:4 KB
File Name: ethercat_CMMT.xml
File Size:2 KB
i put my working config in the Attachments.
  • RotarySMP
  • RotarySMP's Avatar
22 Oct 2025 15:06
Replied by RotarySMP on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
Thanks Andy. It was easy enough to edit the infeed angle for that one thread, and I did remember to edit it back, but having a conversational entry for this would be nice.
  • Routerworks
  • Routerworks
22 Oct 2025 14:50
Category: CAD CAM
For what it is worth, I have been working with Inkscape and find it is excellent for creating engraving paths and generating g code. Much easier than using Freecad. However Blender still seems the best for bas reliefs and generating their g code. Freecad has is best for CAD drawings and generating milling g code. Image2gcode may be on option however I use a windows computer for developing my g code and linuxcnc strictly for operating my router.
Your seggestion of using inkscape for carvings or engraving makes life much much easier than the other routes. These softwares seem to be the big three for coverng 2D to 3D g code with free software.
Thanks again for your advise as it is saving me tons of time generating engraving paths from curved drawings or text.
Thanks again
  • Gartenzwerg
  • Gartenzwerg
22 Oct 2025 14:30
Replied by Gartenzwerg on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
..ich antworte mir mal selbst:
Bin nochmal aufmerksam durch beide Dateien gegangen, und habe ein paar Fehler gefunden und ausgebessert.
Jetzt fahren alle Achsen, und auch die Endschalter funktionieren.
Einzig die Spindelsteuerung fehlt in der GUI, den Sprühnebel Knopf habe ich aber mittlerweile.
File Name: diadrive20...22-2.ini
File Size:3 KB
File Name: diadrive20...22-2.hal
File Size:9 KB
  • andypugh
  • andypugh's Avatar
22 Oct 2025 14:20
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
I think 6.1.0-30-rt should probably be OK. (though I think that the packages were built on 6.1.0.10-rt )
  • Lcvette
  • Lcvette's Avatar
22 Oct 2025 14:13
Replied by Lcvette on topic Probe Basic backplot error when loading file
Category: QtPyVCP
I think this was resolved in the develop branch, multiple offsets but was something we found also, you can upgrade to the develop version which should resolve the issue
  • DerKlotz
  • DerKlotz
22 Oct 2025 13:58
Category: GladeVCP
Hello,
you answered one of my posts. Can you help me installing the right kernel. I don´t know how to do it.
"Try repeating after typing
sudo apt purge raspi-firmware
If you still gets errors, share the output of uname -r as it appears it is trying to install an incorrect kernel version. "
I got this message 6.1.0-30-rt-amd64
  • andypugh
  • andypugh's Avatar
22 Oct 2025 13:32
Replied by andypugh on topic linuxcnc.command().mdi() vs .program_open()
Why not just write a simple G-code program to probe your 5 points and log the data to file?
(probeopen proberesults.txt)
G53 G0 Z 100
G53 G0 X0 Y0
G38.2 Z0
G53 G0 Z100
G53 G0 X0 Y1000
G38.2 Z0
G53 G0 Z100
G53 G0 X1000 Y1000
G38.2 Z0
G53 G0 Z100
G53 G0 X1000 Y0
G38.2 Z0
G53 G0 Z100
G53 G0 X500 Y500
G38.2 Z0
G53 G0 Z100
(probeclose)
M2
  • newbynobi
  • newbynobi's Avatar
22 Oct 2025 13:26
Displaying 8341 - 8355 out of 16961 results.
Time to create page: 0.438 seconds
