  • andypugh
  • andypugh's Avatar
16 Oct 2025 14:27
Replied by andypugh on topic Injection molding
Injection molding
Category: CNC Machines
It could be done. It's probably how I would do it if I had to control an injection moulding machine, but only because I already know how to use LinuxCNC.
(when your only tool is a hammer....)
Getting temperature into LinuxCNC HAL is not the easiest thing. One option is:
linuxcnc.org/docs/stable/html/man/man9/max31855.9.html
16 Oct 2025 14:25
Replied by tommylight on topic Injection molding
Injection molding
First such machine i fixed was back in 1990 !!!
They are complicated machines, but all are made from simple parts, so look at it as separate parts, makes it much easier.
The main hurdle with retrofitting such machines is the logic and interlocks, writing down whatever you already know will help a lot during programing.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 14:22
Replied by andypugh on topic what means TC abbreviation in TC_STRUCT?
Category: LinuxCNC Documents
TP - Trajectory Planner ( see src/emc/tp/tp.c)
TC - Trajectory Controller. (see src/emc/tp/tc.c))
  • Aciera
  • Aciera's Avatar
16 Oct 2025 14:19
Replied by Aciera on topic Tutorials
Tutorials
but if there's no new tutorials out there to guide newbs, then i might as well not waste my time and just install windows.
Makes me wonder why we bother maintaining about 1500 pages of written documentation:
linuxcnc.org/docs/html/
  • laurentl38
  • laurentl38
16 Oct 2025 13:51
Replied by laurentl38 on topic increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
Yes, that's a solution. I'll think about it, if I start modifying the code (I'm not very good at programming) or if I find a solution to add additional control switches (from my window, this solution seems the easiest to me)
  • andypugh
  • andypugh's Avatar
16 Oct 2025 13:27
Replied by andypugh on topic increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
Probe Basic is written in Python, you could modify it.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 13:21
Replied by andypugh on topic Enlarge Hal_Meter
Enlarge Hal_Meter
Category: GladeVCP
Try a different layout with a 2-element V-box with a 2-element H-box in the top box.
I think that your meter is being constrained to be same width as "Licht" as it is in the same column.
  • laurentl38
  • laurentl38
16 Oct 2025 13:19
Category: QtPyVCP
I've already looked through the list, but I didn't find anything conclusive.
It was just in case there was something I'd missed or done wrong.
So your comment supports my analysis, but not really the right one for me. I'll have to find another solution...
  • DerKlotz
  • DerKlotz
16 Oct 2025 12:52
Enlarge Hal_Meter was created by DerKlotz
Enlarge Hal_Meter
Category: GladeVCP
Hello,
i created a small ui with glade with two leds, two buttons and a Hal_Meter. How can i enlarge the Hal_Meter? Attached is a screenshot of my main window.
  • DerKlotz
  • DerKlotz
16 Oct 2025 12:37 - 16 Oct 2025 12:43
Replied by DerKlotz on topic Glade Hal Meter Spindle Speed -> postgui
Category: GladeVCP
Thatś it. Thanks
My custum_postgui.hat is now correct
#[Spindel]
net spindle-vel-cmd-rpm => gladevcp.Spindel1
I guess i really have some problems with reading signals in the machine.hal. I thought in my case "spindle.0.speed-out" give me directly my float value. Have to write a small manual for me.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 12:31
Category: QtPyVCP
This has been asked before on here (but don't bother looking, there was no helpful answer).
If you load the system then open a terminal and type "halcmd show pin" you will get a list of all the HAL pins. You would then need to search that list to see if any pins are of the OUTPUT type and look to be increment-related.
From a brief scan of the source code,I don't see anything, but I am not clear how QtPyVCP creates HAL pins (if it does)
  • JT
  • JT's Avatar
16 Oct 2025 12:27
Replied by JT on topic Tutorials
Tutorials
Have fun with windows...
  • timo
  • timo
16 Oct 2025 12:13
Replied by timo on topic Injection molding
Injection molding
Entry level regular PLCs are not all that expensive as well.
Linux CNC has Classic ladder to do PLC logic.
  • glct12
  • glct12
16 Oct 2025 12:09
Replied by glct12 on topic what means TC abbreviation in TC_STRUCT?
I know that refers to a path's segment.
Yes, it is possible to mean Trajectory Curve.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 12:07
Replied by andypugh on topic INI and HAL files
INI and HAL files
If you like ladder, then you can use that for your toolchanger.
(Though it isn't easy to program axis movements from Ladder)
linuxcnc.org/docs/stable/html/ladder/ladder-intro.html
linuxcnc.org/docs/stable/html/ladder/classic-ladder.html
linuxcnc.org/docs/stable/html/ladder/ladder-examples.html
I normally suggest controlling a toolchange sequence with G-code. It is a terrible programming language but does have built-in behaviour for moving axes around, for setting HAL pins, and for waiting for the state of HAL pins to change (with timeout).
See the example G-code routine here (which works in conjunction with the carousel.comp)
github.com/LinuxCNC/linuxcnc/blob/master...hange/toolchange.ngc
You can run that whole config (it's a simulator with a graphical representation of a milling machine) by starting LinuxCNC and picking the sim/axis/vismach/vmc_toolchange config and picking one of the two INI files
(this is also an example of two configs sharing HAL and support files, the configs deomnstrate two different types of tool carousel position feedback)
Displaying 8656 - 8670 out of 16966 results.
Time to create page: 0.987 seconds
