  • gravedigger
  • gravedigger
12 Oct 2025 10:32
Replied by gravedigger on topic Probleme WIFI Rasperry Pi5 mit 2.9.6
Category: Deutsch
Weil ich schon gerne wüsste, warum es nicht geht.
Evtl. braucht man es ja doch mal.
  • spicer
  • spicer's Avatar
12 Oct 2025 09:54
Replied by spicer on topic Probleme WIFI Rasperry Pi5 mit 2.9.6
Category: Deutsch
Und warum dann die Übung, wenn das Wlan dann gar nicht notwendig ist?
  • st2s
  • st2s
12 Oct 2025 09:23
XHC-WHB04B-6 установка для LINUXCNC
Category: Russian
Вроде разобрался
  • unknown
  • unknown
12 Oct 2025 08:43
fixing "raspi firmware" errors on the official amd64 ISO
Category: Installing LinuxCNC
OK I think I've found a fix for this thing when installing from the ISO. The ISO needs rebuilding, the one built failed during the grub install, this was tracked down to an issue to dpkg install when building the ISO.
So I had to do some messing about, to install grub inside the installed system in my virtual machine. I haven't had chance to fix/find out why I had the issue with the ISO.
A small edit is required to the config/includes.install/preseed.cfg
At the end of the file add this line:
d-i preseed/late_command string in-target apt-get -y purge raspi-firmeware
Obviously a new image ISO will need to be created, for this mod to be included.
Whilst the installer still installs raspi-firmware at the end of the install process the above line removes the package. The live session will still have the raspi-firmware but I really haven't heard of anyone attempting to update the kernel on a live session. Still a bit of a hack, but the system once installed to a HDD\SSD or large storage rock it wont have the raspi-firmware installed.
The ISO issue maybe cos I was using Mint to build the image and had to install live-build from the debian repo & there might have been a mis-match......I dunno
  • gravedigger
  • gravedigger
12 Oct 2025 08:37 - 12 Oct 2025 08:41
Probleme WIFI Rasperry Pi5 mit 2.9.6 was created by gravedigger
Category: Deutsch
Ich möchte von Mach auf LinuxCNC mit Rasperry umrüsten und stehe am Anfang.
Nachdem ich es geschafft habe, dass der Raspi von SSD startet, habe ich noch ein Problem mit WIFI.
Mit der Raspi SD und Raspi OS läuft es mit dem WLAN und ich bekomme auch unter Linux CNC die SSID s von mir und meinen Nachbarn angezeigt, hab aber keine Verbindung ins Netz.
In der Datei hab ich auch die SSID und das Passwort in der WPA Datei eingetragen. Es klappt aber im 2.4 und 5 Netz nicht. Hab auch schon probeweise auf feste IP umgestellt.
Was kann ich noch nachschauen bzw. testen?
Welche USB Ethernet Adapter funktionieren am Raspi? Habe Probeweise einen USB -Ethernet an den blauen USB Port gesteckt und der macht keinen Mucker, aber am PC klappt es mit dem .
Dauerhaft will ich an der Maschine eh kein WIFI haben, weil im Keller das Netz schlecht ist.
Grüße
Harald
  • unknown
  • unknown
12 Oct 2025 03:37
This is kind of preplexing, shouldn't the architecture be arm or similar
Package: raspi-firmware
Architecture: all
Version: 1.20220830+ds-1
Priority: optional
Section: non-free-firmware/misc
Maintainer: pkg-raspi <pkg-raspi-maintainers@lists.alioth.debian.org>
Installed-Size: 22281
Pre-Depends: dpkg (>= 1.17.14)
Depends: dosfstools
Suggests: firmware-brcm80211, firmware-misc-nonfree, bluez-firmware
Breaks: linux-firmware-raspi3 (<< 1.20161123-2), raspi3-firmware (<< 1.20190718-1~)
Replaces: linux-firmware-raspi3 (<< 1.20161123-2), raspi3-firmware (<< 1.20190718-1~)
Filename: pool/non-free-firmware/r/raspi-firmware/raspi-firmware_1.20220830+ds-1_all.deb
MD5sum: 02766adeeeea1246010c8a3c2851a73b
SHA1: f37dba3e827325667381703815ac227ee1aa9b64
SHA256: 0094ced47a7fbb6a220ff83e7b43aa637a5d8f6802461e2e4e474597fb796f62
SHA512: 2ef6547b160b9207ce6bdf33572a4eed389c56db0b7172e049c5bf4c8471ee60f7fd5f05fd8bf08075ec4e8baae8a602e219b5592a854ed3e6678222a989a2d7
Homepage: https://github.com/raspberrypi/firmware
Description: Raspberry Pi family GPU firmware and bootloaders
 This package contains all the proprietary files necessary to boot a
 Raspberry Pi board. This should work with all models in the 0, 1, 2, 3 and
 4 families.
 Raspberry Pi is a trademark of the Raspberry Pi Foundation.
  • Fastfred
  • Fastfred
12 Oct 2025 03:00
Replied by Fastfred on topic Gmoccapy tool setter install "errors"
Category: Gmoccapy
I was able to figure out the end of line issue , but now not getting any movement after asking for tool change or pop up window?
  • Aciera
  • Aciera's Avatar
12 Oct 2025 01:30
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
I'm sorry, I forgot the ini file part:
[DISPLAY] section:
GLADEVCP = example.ui
[HAL]
POSTGUI_HALFILE = example_postgui.hal
11 Oct 2025 23:50
Replied by tommylight on topic INI and HAL files
INI and HAL files
/home/cnc/linuxcnc/configs/
Notice cnc is the user name so it will be whatever user name you have on that PC.
And it does not matter at all where the config files are, as long as they are readable and have no spaces in the name (this was an issue way way before, no idea if still true).
You can have configuration files on a USB stick or network share or ... and still they can be run and used to control the machine.
For editing the config files, never ever use windows or office suits, use only simple text editors like xed or gedit or geany or nano or vim.
Use the PncConf wizard, it can do pretty much everything needed, and it can also edit the created configs.
Another thing, you can have multiple configs for the same machine with different setups, so make as much as you like till you get things working as you like them to.
11 Oct 2025 23:40
@Rob,
as long as you are chrooted into the ISO, you can do everything you can on a normally running system, so yes, easy to remove at any point in time while preparing and before building the final ISO.
  • Twitchy88
  • Twitchy88
11 Oct 2025 23:26
INI and HAL files was created by Twitchy88
INI and HAL files
Hello
Can someone give me a quick run down of the INI and HAL files.  I successfully got an axis on my Fadal mill moving today with mesa 7i96s and DMM Dyn4 servos using axis. I used PNCCONF and it still wouldn't work, then I realised the files needed to be put somewhere but for the life of me I couldn't figure out what files needed to go where. After watching a video I saw the button to "create desktop launcher to start linux with this configuration".
I would like to learn how to modify the files manually and put them where they need to go. If I were to start from scratch without PNCCONF what files need to be modified and put where?
11 Oct 2025 23:22
@Andy,
sorry i was not aware anyone except Rod is involved into it.
  • Twitchy88
  • Twitchy88
11 Oct 2025 22:53
Replied by Twitchy88 on topic User interface
User interface
Thanks everyone, I have taken rodw advice and starting out with Axis.
  • Fastfred
  • Fastfred
11 Oct 2025 22:49
Category: Gmoccapy
Forgot to say I got the error after asking for tool change in the GUI.
  • Fastfred
  • Fastfred
11 Oct 2025 22:46
Category: Gmoccapy
Not Getting errors on start up, but a pop up saying file ended with no percent sign (%) or program end (M2)
File Name: change.ngc
File Size:2 KB
File Name: gmoccapy_p...0-11.hal
File Size:1 KB
File Name: custom_pos...0-11.hal
File Size:1 KB
File Name: CNC_2025-10-11.ini
File Size:6 KB
File Name: CNC.hal
File Size:13 KB
Displaying 8851 - 8865 out of 16971 results.
Time to create page: 0.703 seconds
