  • rodw
  • rodw's Avatar
06 Oct 2025 10:43
Replied by rodw on topic ARE YOU KIDDING ME YOUTUBE !!!
I have not published a video for a month. I was puzzled to see that there was an upwards trend in my views which had doubled during the month without any new content.
I think this was because I added AI generated thumbnails and revised titles to be more in line with what Youtube wants. TIme will tell.
Yesterday, I published a new video about installing on Trixie and its the best performer I've done. I think this was because I followed a script, added some chapter heading banners and used a cheap Teleprompter (which I also bought a foot switch for). I also used my DSLR with a 50mm F1.4 lens. The ficus hunted a bit but the deot of fields is nicer when I am in focus... You be the judge
I bought a video switcher and I want to do an installation walkthrough but last night I realized that the HP PC I wanted to use does not have an HDMI port so Ihave ordered a VGA to HDMI adapter. Hopefully I will be able to capture the screens from the BIOS and the Debian Installer. Wish me Luck!
  • Cooped-Up
  • Cooped-Up
06 Oct 2025 10:30
Replied by Cooped-Up on topic 5i25t firmware screwup
Category: Driver Boards
I think I have gotten the firmware situation figured out, but now I am trying to add some things to the machines hal file for the retrofit based off a guide for a maho 400e. I added the following and now the cnc panel gives me an error. it seems to be saying it cant find pins on the 7i77
added to the machines.hal file=
loadrt matrix_kb config=5x5s names=maho_panel
addf maho_panel servo-thread
setp maho_panel.negative-logic 0
#scan out
net maho_panel.row_00_sig-out maho_panel.row-00-out => hm2_5i25.0.7i77.0.0.output-01
net maho_panel.row_01_sig-out maho_panel.row-01-out => hm2_5i25.0.7i77.0.0.output-02
net maho_panel.row_02_sig-out maho_panel.row-02-out => hm2_5i25.0.7i77.0.0.output-03
net maho_panel.row_03_sig-out maho_panel.row-03-out => hm2_5i25.0.7i77.0.0.output-04
net maho_panel.row_04_sig-out maho_panel.row-04-out => hm2_5i25.0.7i77.0.0.output-05
#scan in
net maho_panel.col_00_sig-in maho_panel.col-00-in <= hm2_5i25.0.7i77.0.0.input-05
net maho_panel.col_01_sig-in maho_panel.col-01-in <= hm2_5i25.0.7i77.0.0.input-06
net maho_panel.col_02_sig-in maho_panel.col-02-in <= hm2_5i25.0.7i77.0.0.input-07
net maho_panel.col_03_sig-in maho_panel.col-03-in <= hm2_5i25.0.7i77.0.0.input-08
net maho_panel.col_04_sig-in maho_panel.col-04-in <= hm2_5i25.0.7i77.0.0.input-09
loadrt mh400e_gearbox
addf mh400e-gearbox servo-thread
# --- GEARBOX CONTROL ---
net sig_return_actual_speed mh400e-gearbox.spindle-speed-out => motion.spindle-
speed-in
net sig_return_spindle-at-speed mh400e-gearbox.spindle-at-speed => motion.spindle-at-
speed
net sig_stop_spindle mh400e-gearbox.stop-spindle => halui.spindle.stop
net set-gear-shift-start mh400e-gearbox.start-gear-shift =>
hm2_5i25.0.7i84.0.2.output-05
net set-reverse-shaft-motor mh400e-gearbox.reverse-direction =>
hm2_5i25.0.7i84.0.2.output-04
net activate-reducer-motor mh400e-gearbox.reducer-motor =>
hm2_5i25.0.7i84.0.2.output-01
net activate-midrange-motor mh400e-gearbox.midrange-motor =>
hm2_5i25.0.7i84.0.2.output-02
net set-shaft-motor-lowspeed mh400e-gearbox.motor-lowspeed =>
hm2_5i25.0.7i84.0.2.output-00 # MAHO calls this Anwahl Mittelstellung
net activate-input-stage-motor mh400e-gearbox.input-stage-motor =>
hm2_5i25.0.7i84.0.2.output-03
net activate-spindle-twitch-cw mh400e-gearbox.twitch-cw =>
hm2_5i25.0.7i84.0.2.output-06
net activate-spindle-twitch-ccw mh400e-gearbox.twitch-ccw =>
hm2_5i25.0.7i84.0.2.output-07
Error I now get
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/coopedup/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/coopedup/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25t at 0000:04:06.0
hm2/hm2_5i25.0: Low Level init 0.15
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin tx1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin rx1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:06.0
hm2_5i25.0: dropping AnyIO board at 0000:04:06.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./my_LinuxCNC_machine.hal:298: Pin 'hm2_5i25.0.7i77.0.0.output-01' does not exist
1999
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f5cd11d7000
  • Aciera
  • Aciera's Avatar
06 Oct 2025 10:07 - 06 Oct 2025 10:09
Replied by Aciera on topic Pin does not exist
Pin does not exist
Category: ClassicLadder
You might need to increase the number of pins (default is 15 input- and 15 output-pins):
linuxcnc.org/docs/html/ladder/classic-ladder.html#_variables
  • laurentl38
  • laurentl38
06 Oct 2025 08:32
Replied by laurentl38 on topic orient spindle with ethercat EL5101
Category: EtherCAT
hello,
I've spent hours playing with the PID values ​​and still have the same problem...
In the meantime, I've made progress on other points on the machine to take my mind off things.
If I move the spindle to 45 degrees, then 145, 245, and 345, no problem; it positions itself correctly at the value. However, if I move it from 45 to 245, the spindle goes to maximum speed without stopping...
But since yesterday, I've had an interesting lead. When this doesn't work, I realized that the spindle command becomes negative (LCNC, probably choosing the shortest path, by wanting to rotate the spindle in the opposite direction).
And that's the problem: the spindle doesn't change direction, so the PID drifts...
To confirm my idea, I made the same movements, but imposed the rotation direction with an M19 Rx P1.
And then, if I move the spindle from 45 to 145 degrees or from 45 to 345, there's no longer a problem; it positions itself every time.
I've probably found the cause, but how to resolve it, I don't know.
Do I have an error in my HAL or am I missing a line?
Do you have any leads?
  • MarkoPolo
  • MarkoPolo
06 Oct 2025 08:23
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
The LEDs are working properly.
The label translation is perfectly sufficient.
Thanks for the good work.
  • Hakan
  • Hakan
06 Oct 2025 08:14
Replied by Hakan on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Switched to the generic driver, ok.
You probably need to add the configPDOS="true" to the line
<slave idx="0" type="generic" vid="0x0000001d" pid="0x007b1a95" name="D1">
like
<slave idx="0" type="generic" vid="0x0000001d" pid="0x007b1a95" name="D1" configPDOS="true">
  • Ahmed.emara
  • Ahmed.emara
06 Oct 2025 08:04
door signal implementation was created by Ahmed.emara
Hello everyone,I have a proximity sensor that detects whether the machine door is open or closed. I’d like to integrate this signal into my system so that:
  1. If the door is open, the program automatically pauses.
  2. If the door is closed, the program continues.
  3. The program should not start if the door is open — it should only start once the door is fully closed.
What’s the best way to implement this behavior in my setup?
  • Hakan
  • Hakan
06 Oct 2025 07:47
Replied by Hakan on topic Config-Problem Ethercat
Category: Deutsch
Haha, ok..
Taking this as the cia402 reference example github.com/dbraun1981/hal-cia402/blob/main/example/cia402.hal
you normally connect opmode to the cia402 module. I would say connect lcec.0.5 to cia402.2 in the same way as in the example.
  • minimac
  • minimac
06 Oct 2025 07:14
Hilfe bei Pinbelegung ERL PCSE200 an Mesa 7i96S (Step/Dir
Category: Deutsch
Grüß dich michael,
das ist dann mein Plan B,
ich hoffe natürlich das noch irgendjemand vielleicht ein Datenblatt hat.
Der diesen Eintrag hier liest.
Viele Grüße,
  • Ri
  • Ri
06 Oct 2025 06:47 - 06 Oct 2025 09:15
Pin does not exist was created by Ri
Pin does not exist
I get this error:
./sodick.hal:253: Pin 'classicladder.0.in-15' does not exist
It sees all the pins, all the inputs and outputs work, but it doesn't see the 16th pin.
HAL:
loadrt classicladder_rt
# Подключение входов Classic Ladder к физическим входам
net cl-in-01 lcec.0.5.in-01 => classicladder.0.in-00
net cl-in-02 lcec.0.5.in-02 => classicladder.0.in-01
net cl-in-03 lcec.0.5.in-03 => classicladder.0.in-02
net cl-in-04 lcec.0.5.in-04 => classicladder.0.in-03
net cl-in-05 lcec.0.5.in-05 => classicladder.0.in-04
net cl-in-06 lcec.0.5.in-06 => classicladder.0.in-05
net cl-in-07 lcec.0.5.in-07 => classicladder.0.in-06
net cl-in-08 lcec.0.5.in-08 => classicladder.0.in-07
net cl-in-09 lcec.0.5.in-09 => classicladder.0.in-08
net cl-in-10 lcec.0.5.in-10 => classicladder.0.in-09
net cl-in-11 lcec.0.5.in-11 => classicladder.0.in-10
net cl-in-12 lcec.0.5.in-12 => classicladder.0.in-11
net cl-in-13 lcec.0.5.in-13 => classicladder.0.in-12
net cl-in-14 lcec.0.5.in-14 => classicladder.0.in-13
net cl-in-15 lcec.0.5.in-15 => classicladder.0.in-14
net cl-in-16 lcec.0.5.in-16 => classicladder.0.in-15
# Подключение выходов Classic Ladder к физическим выходам
net cl-out-01 classicladder.0.out-00 => lcec.0.5.out-01
net cl-out-02 classicladder.0.out-01 => lcec.0.5.out-02
net cl-out-03 classicladder.0.out-02 => lcec.0.5.out-03
net cl-out-04 classicladder.0.out-03 => lcec.0.5.out-04
net cl-out-05 classicladder.0.out-04 => lcec.0.5.out-05
net cl-out-06 classicladder.0.out-05 => lcec.0.5.out-06
net cl-out-07 classicladder.0.out-06 => lcec.0.5.out-07
net cl-out-08 classicladder.0.out-07 => lcec.0.5.out-08
net cl-out-09 classicladder.0.out-08 => lcec.0.5.out-09
net cl-out-10 classicladder.0.out-09 => lcec.0.5.out-10
net cl-out-11 classicladder.0.out-10 => lcec.0.5.out-11
net cl-out-12 classicladder.0.out-11 => lcec.0.5.out-12
net cl-out-13 classicladder.0.out-12 => lcec.0.5.out-13
net cl-out-14 classicladder.0.out-13 => lcec.0.5.out-14
net cl-out-15 classicladder.0.out-14 => lcec.0.5.out-15
net cl-out-16 classicladder.0.out-15 => lcec.0.5.out-16
There is a PIN in the terminal:
37  bit   OUT         FALSE  lcec.0.5.in-01 ==> cl-in-01
    37  bit   OUT         FALSE  lcec.0.5.in-02 ==> cl-in-02
    37  bit   OUT         FALSE  lcec.0.5.in-03 ==> cl-in-03
    37  bit   OUT         FALSE  lcec.0.5.in-04 ==> cl-in-04
    37  bit   OUT         FALSE  lcec.0.5.in-05 ==> cl-in-05
    37  bit   OUT         FALSE  lcec.0.5.in-06 ==> cl-in-06
    37  bit   OUT         FALSE  lcec.0.5.in-07 ==> cl-in-07
    37  bit   OUT         FALSE  lcec.0.5.in-08 ==> cl-in-08
    37  bit   OUT         FALSE  lcec.0.5.in-09 ==> cl-in-09
    37  bit   OUT         FALSE  lcec.0.5.in-10 ==> cl-in-10
    37  bit   OUT         FALSE  lcec.0.5.in-11 ==> cl-in-11
    37  bit   OUT         FALSE  lcec.0.5.in-12 ==> cl-in-12
    37  bit   OUT         FALSE  lcec.0.5.in-13 ==> cl-in-13
    37  bit   OUT          TRUE  lcec.0.5.in-14 ==> cl-in-14
    37  bit   OUT         FALSE  lcec.0.5.in-15 ==> cl-in-15
    37  bit   OUT          TRUE  lcec.0.5.in-16
    37  bit   IN          FALSE  lcec.0.5.out-01 <== cl-out-01
    37  bit   IN          FALSE  lcec.0.5.out-02 <== cl-out-02
    37  bit   IN          FALSE  lcec.0.5.out-03 <== cl-out-03
    37  bit   IN          FALSE  lcec.0.5.out-04 <== cl-out-04
    37  bit   IN          FALSE  lcec.0.5.out-05 <== cl-out-05
    37  bit   IN          FALSE  lcec.0.5.out-06 <== cl-out-06
    37  bit   IN          FALSE  lcec.0.5.out-07 <== cl-out-07
    37  bit   IN          FALSE  lcec.0.5.out-08 <== cl-out-08
    37  bit   IN          FALSE  lcec.0.5.out-09 <== cl-out-09
    37  bit   IN          FALSE  lcec.0.5.out-10 <== cl-out-10
    37  bit   IN          FALSE  lcec.0.5.out-11 <== cl-out-11
    37  bit   IN          FALSE  lcec.0.5.out-12 <== cl-out-12
    37  bit   IN          FALSE  lcec.0.5.out-13 <== cl-out-13
    37  bit   IN          FALSE  lcec.0.5.out-14 <== cl-out-14
    37  bit   IN          FALSE  lcec.0.5.out-15 <== cl-out-15
    37  bit   IN          FALSE  lcec.0.5.out-16
    37  bit   OUT          TRUE  lcec.0.5.slave-online
    37  bit   OUT          TRUE  lcec.0.5.slave-oper
    37  bit   OUT         FALSE  lcec.0.5.slave-state-init
    37  bit   OUT          TRUE  lcec.0.5.slave-state-op
    37  bit   OUT         FALSE  lcec.0.5.slave-state-preop
    37  bit   OUT         FALSE  lcec.0.5.slave-state-safeop
  • michaeln
  • michaeln
06 Oct 2025 06:43
Category: Deutsch
Hallo Jochen,
ohne Datenblatt kommst du nicht weiter.
Meistens ist es leider so, dass nur eine Schnittstelle an solchen Antrieben vorhanden ist.
D.h. entweder CanOpen ODER Puls-/Richtung-Schnittstelle.
Ich würde den Motor gegen eine Schrittmotor ersetzen, vieleicht findest du einen passenden zu dem PLE60-Getriebe und kannst wenigstens dies behalten.
Viele Grüße
  • minimac
  • minimac
06 Oct 2025 06:32 - 06 Oct 2025 06:41
Category: Deutsch
Hier jetzt noch mal die Platine von der Rückseite.
  • minimac
  • minimac
06 Oct 2025 06:26 - 06 Oct 2025 06:28
Category: Deutsch
Ja das mache ich natürlich sehr gerne, ein wenig habe ich ja schon raus gefunden.Nur nicht welcher Logikpegel von dem Regler erwartet wird.Die Stromversorgung habe ich schon lokalisiert plus/minus, habe ich mit dem Multimeter schon ermittelt.Die Firma wird mir auch wahrscheinlich nicht mehr antworten, bei genauerem hinsehen auf der Webseite habe ich gemerkt, dass die Home Seite gelöscht wurde und die Firma Zeit 2014 aus dem Amtsregister gelöscht wurde. Es sind nur noch wenige Daten verfügbar, ausgerechnet mein Regler nicht.Anbei aber die Bilder die ich gemacht habe.Ich bin für jede Hilfe dankbar.
  • Red_D85
  • Red_D85
06 Oct 2025 05:42
Replied by Red_D85 on topic Config-Problem Ethercat
Category: Deutsch
sorry im a idiot. this was the wrong file.
File Name: cia402_2025-10-06.hal
File Size:4 KB
  • cmorley
  • cmorley
06 Oct 2025 05:33
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
I think I pushed a fix for the leds staying on problem - at least in the tests I did it worked.
The label is a bit harder to fix satisfactorily. It's now at least translatable.
Displaying 9196 - 9210 out of 16968 results.
Time to create page: 0.333 seconds
