  • antonyvm
  • antonyvm
02 Oct 2025 18:28
Replied by antonyvm on topic Error in PnC Conf. connecting to Mesa 7i96s
Category: PnCConf Wizard
Yes the hack works, I had to reinstall with the new settings.
Had to set to Pacific Time.
So how come no one from India has not tried the mesa cards yet?
Or is this issue related to PnC Conf only and not to Linux CNC?
I am very certain there are many Linux CNC users in India.
02 Oct 2025 18:18
hm2/hm2_7i76e.0: error finishing read! iter=1342204
Category: Deutsch
Erst einmal vielen Dank für dein Interesse an meinem Problem!!
Sier sind immer wilkomen.
In welcher Sprache bist du aufgewachsen?
Albanische auf Kosovo.
Ist die ISO 6.13 RT released?
Nein, das hab ich gemacht, und nutzt die Linux Mint stadt Debian.
  • kb58
  • kb58
02 Oct 2025 18:03 - 04 Oct 2025 18:44
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Category: Driver Boards
I checked my config file and confirmed that it was 0xA8800002. Changed it to -1 and reloaded LinuxCNC. Checked the LEDs and
the status lights are now solid green, no longer blinking. Very tentatively clicked on Toggle Machine Power and immediately heard the steppers start making noise, unlike before. Cautiously brought up Manual Control and tried stepping X and Y in both directions ..... both work.
THANK YOU THANK YOU THANK YOU!
I was in the process teaching myself Geany line commands that report register contents. The plan was to start poking at them, hoping to have it tell me what the problem was. While I would like to say that I'd find the above eventually, I might also have given up in frustration and ordered the ECT version.
I would send you flowers and a fruit basket but don't want to cause trouble at your end :)
Thank you again - very much - and now I can get on with completing this beast of a project! Just so I know, where did you find the ERC60V202.xml esi file? The rTelligent site has zero downloads on the product page other than the manual.
  • aaron
  • aaron
02 Oct 2025 17:35
Replied by aaron on topic New Install of LCNC,Debian12 dumping core
Thanks for all your replies. I managed to do it by deleting all the partitions via the live usb (including one that I didn't recognize). Then reinstall using the whole disk. Sorry for doing it the windoze way!
Thanks again
  • Hakan
  • Hakan
02 Oct 2025 17:00
Did you check product code vs pid?
I just downloaded the ERC60V202.xml esi file, and there is says product code x0A880001,
you have 0x0A880002 in the ethercat-conf.xml you supplied in one of the early posts.
Check Product code and Vendor Information vs vid and pid.
You find it with "ethercat slaves -v" alternatively "lcec_configgen"
  • andypugh
  • andypugh's Avatar
02 Oct 2025 16:50
Replied by andypugh on topic Reading data from var file using Python
Category: O Codes (subroutines) and NGCGUI
Yes, to make my idea work you would need to either have pause commands in the G-code to give the Python time to see the new value, or implement some sort of flow control where the G-code sends a pair of values then waits for a rising edge on a third HAL pin pointing the other way.
(See M66 linuxcnc.org/docs/html/gcode/m-code.html#mcode:m66 )
  • MarkoPolo
  • MarkoPolo
02 Oct 2025 16:36
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
I made some adjustments to the regular expressions, and it seems to be displaying colors correctly now.
Check if everything is OK.
  • djones@burketruck.com
02 Oct 2025 16:33
Replied by djones@burketruck.com on topic Any Fiber Laser Successes?
Category: Plasma & Laser
Would Monokrom be a better choice since the customizability is similar to Probe Basic?
  • antonyvm
  • antonyvm
02 Oct 2025 15:23
Ok, Great.
I will try with the new settings and let you know.
Antony.
  • 2tinker
  • 2tinker
02 Oct 2025 14:44
Category: Deutsch
  • heaven
  • heaven
02 Oct 2025 14:35
Replied by heaven on topic Important EtherCAT configuration option
Category: EtherCAT
For a long time, I've been pondering this issue. I can't find any practical difference between free run and DC mode. Even though I've set up my motor to run in both modes, they seem identical or even worse in DC mode. It feels like I've never actually activated DC mode on LinuxCNC. This could really be a big discovery for me. Thank you very much!
02 Oct 2025 14:25
Category: Deutsch
Die ISO auf dem link runterladen, neu instalieren, testen.
Diese ISO hab 6.13 RT kernel, soll kein probleme vie die 6.01 im die officielle ISO haben, kan aber andere probleme habben.
Sorry, aber ich schriebe English mehrfah schneller. Und mache wenig fehler... :)
  • emresensoy
  • emresensoy
02 Oct 2025 14:11
Replied by emresensoy on topic EtherCAT Manual Panel
Category: Show Your Stuff
brewing...
  • 2tinker
  • 2tinker
02 Oct 2025 14:03
Category: Deutsch
Ich habe keine Ahnung was du mir damit sagen möchtest.
Es hat schon seinen Grund, warum ich im deutschsprachigen Teil dieses Forums schreibe.
Aber gerne berichte ich, ob der Prozessortausch etwas gebracht hat.
Displaying 9346 - 9360 out of 16967 results.
Time to create page: 0.449 seconds
