  • Mcelroy434
  • Mcelroy434
11 Jun 2025 03:30
Replied by Mcelroy434 on topic Plasmac Post Processors
Category: Plasmac
Hi taloot, I am very new to CNC and am trying to setup my home made machine with QTPlasmaC. This post processor is a .doc file, Fusion is prompting me for a .cps post configuration file. Am I missing another step or something really obvious for how to load this post into my Fusion library? Appreciate any advice!
11 Jun 2025 02:14
Replied by tommylight on topic test post
test post
Bump to remove it from "No replies" section.
This was also posted somewhere else on the forum and replied, so this remains a test post.
Thank you.
11 Jun 2025 02:11
Replied by tommylight on topic QtPlasmaC using w axis
Category: Plasmac
Moved to "PlasmaC" section.
11 Jun 2025 02:09
Replied by tommylight on topic Latency Issues - Histogram Shape
Category: Installing LinuxCNC
Not sure if base period is required to run EtherCAT, i can not recall it being mentioned from what i read on this forum.
Either way, your latency results are terrible and to see just how terrible add --show at the end of the latency-histogram line.
In short:
-If you do need base period use older LinuxCNC ISO with Debian Wheezy, does not work with Mesa EtherNET boards and might most probably not work with EtherCAT
-If you do not need base period use the latest 2.9.4 ISO, do not edit or modify anything, just install a new RT-Preempt kernel, 6.13 should do just fine
-Make a config, run the machine, see if LinuxCNC complains about anything, if not = happy machinning
  • COFHAL
  • COFHAL
11 Jun 2025 01:38
Replied by COFHAL on topic ERROR DE SEGUIMIENTO
Que controladora usa?
  • dunnitagain
  • dunnitagain
11 Jun 2025 00:45
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Thank You Andy, Im sure it was my fault, just to old and Technologically inferior to comprehend.
  • dunnitagain
  • dunnitagain
11 Jun 2025 00:43
Great ! i have to figure out how to load the error files to a USB Stick .
The builder was a bit of a Conspiracy theorist... he had everything locked down.
  • FixItWithMonkeyWrench
11 Jun 2025 00:08
Latency Issues - Histogram Shape was created by FixItWithMonkeyWrench
Hi all,
I'm new to Lcnc, and have been for the past week trying to get my PC to hit the right latency levels.
After a week i've managed to get the base thread down from 126us to about 90us (worst case) which I've read is okay if you're using it with ethercat.
However I've noticed most of the graphs, especially for the servo period Histogram Latency graph that the shapes that most users have is a single peak. I've always been getting 3 peaks.
I'd like to confirm whether having this type of histogram shape is normal? or whether this shape indicates further sources of latency to be reduced.
For Background:
Setup:QBiX-GLKB4125-A1 Mini -PC  J4125 Processor
I've grubbed out all i can think of to help the latency with a small amount of success to when it was out of the box
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash kthread_cpus=0,1 irqaffinity=0,1 rcu_nocbs=2,3 nohz_full=2,3 isolcpus=2,3 rcu_nocb_poll nohz=on intel_pstate=disable amd_pstate=disabled amd_idle.max_cstate=1  processor.max_cstate=0 idle=halt skew_tick=1 idle=poll cpufreq.off=1 cpuidle.off=1 intel_idle.max_cstate=0 nowatchdog nosoftlockup igb.EEE=0 apm=off nosmt=force acpi_irq_nobalance i915.enable_rc6=0 i915.enable_dc=0 i915.enable_psr=0 i915.enable_fbc=0 drm_kms_helper.poll=0 pcie_aspm=off r8168.aspm=0 r8168.eee_enable=0 mitigations=off pcie_aspm=off hpet=disable"
got the governor running on performance, and .sh to set the IRQ affinities.
disabled stuff in the bios
updated drivers via the terminal but haven't yet tried updating the NIC,Graphics, and Chipset drivers from the manufacturer.
Any help would be much appreciated, as I'm new to linux. Thanks.
  • unknown
  • unknown
10 Jun 2025 23:38
Replied by unknown on topic Flyback diode mesa 7i95t
Category: Driver Boards
Is it really bickering when correcting so much bad information from langdons ?
This is what I meant in my problem thread.
Apologies to the OP, just didn't want you to do anything that could cause issues.
  • unknown
  • unknown
10 Jun 2025 23:32
Raspberry Pi Kernel recompile for waveshare 1Gbit Network interface
Like I said the kernel in the image is the same as the RPi OS (with realtime added)
Driver is there:
cnc@raspberrypi:/boot$ ls /lib/modules/6.12.11/kernel/drivers/net/ethernet/realtek/
r8169.ko.xz
cnc@raspberrypi:/boot$ sudo modinfo r8169
filename:       /lib/modules/6.12.11/kernel/drivers/net/ethernet/realtek/r8169.ko.xz
firmware:       rtl_nic/rtl8126a-3.fw
firmware:       rtl_nic/rtl8126a-2.fw
firmware:       rtl_nic/rtl8125b-2.fw
firmware:       rtl_nic/rtl8125a-3.fw
firmware:       rtl_nic/rtl8107e-2.fw
firmware:       rtl_nic/rtl8168fp-3.fw
firmware:       rtl_nic/rtl8168h-2.fw
firmware:       rtl_nic/rtl8168g-3.fw
firmware:       rtl_nic/rtl8168g-2.fw
firmware:       rtl_nic/rtl8106e-2.fw
firmware:       rtl_nic/rtl8106e-1.fw
firmware:       rtl_nic/rtl8411-2.fw
firmware:       rtl_nic/rtl8411-1.fw
firmware:       rtl_nic/rtl8402-1.fw
firmware:       rtl_nic/rtl8168f-2.fw
firmware:       rtl_nic/rtl8168f-1.fw
firmware:       rtl_nic/rtl8105e-1.fw
firmware:       rtl_nic/rtl8168e-3.fw
firmware:       rtl_nic/rtl8168e-2.fw
firmware:       rtl_nic/rtl8168e-1.fw
firmware:       rtl_nic/rtl8168d-2.fw
firmware:       rtl_nic/rtl8168d-1.fw
license:        GPL
softdep:        pre: realtek
description:    RealTek RTL-8169 Gigabit Ethernet driver
author:         Realtek and the Linux r8169 crew <netdev@vger.kernel.org>
srcversion:     668EE5A1A5251AE4E5F0F08
alias:          pci:v000010ECd00003000sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008126sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008125sv*sd*bc*sc*i*
alias:          pci:v00000001d00008168sv*sd00002410bc*sc*i*
alias:          pci:v00001737d00001032sv*sd00000024bc*sc*i*
alias:          pci:v000016ECd00000116sv*sd*bc*sc*i*
alias:          pci:v00001259d0000C107sv*sd*bc*sc*i*
alias:          pci:v00001186d00004302sv*sd*bc*sc*i*
alias:          pci:v00001186d00004300sv*sd*bc*sc*i*
alias:          pci:v00001186d00004300sv00001186sd00004B10bc*sc*i*
alias:          pci:v000010ECd00008169sv*sd*bc*sc*i*
alias:          pci:v000010FFd00008168sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008168sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008167sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008162sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008161sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008136sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008129sv*sd*bc*sc*i*
alias:          pci:v000010ECd00002600sv*sd*bc*sc*i*
alias:          pci:v000010ECd00002502sv*sd*bc*sc*i*
depends:
intree:         Y
vermagic:       6.12.11 SMP preempt_rt mod_unload modversions aarch64
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        14:CE:12:BC:56:1A:45:BD:26:4B:22:D7:A5:0D:7A:06:44:B9:F4:69
sig_hashalgo:   sha1
signature:      4A:5E:4B:28:A7:ED:65:3D:C8:53:C3:E2:BD:07:40:04:C0:32:C0:8E:
		4E:C5:37:6A:AE:02:25:29:77:E4:6F:92:65:10:15:3D:2A:05:62:9C:
		13:B7:B5:8A:8F:CA:95:FF:A6:B6:73:E2:85:75:D2:FD:C1:1E:58:64:
		3D:B1:97:1A:DB:85:9D:30:5F:98:FB:B6:55:54:42:37:8E:33:C2:36:
		0A:D5:DF:96:4D:9E:C1:1E:FE:B3:33:B1:7F:B2:1B:B4:76:FD:16:2C:
		66:22:9C:02:B2:ED:32:99:47:6B:96:FB:4D:1F:0F:DF:BE:D2:D7:F2:
		4E:FB:DB:AF:70:ED:AD:91:22:3F:08:96:88:C3:C9:BB:7A:80:7F:E4:
		40:E7:4D:AA:25:E5:DD:0D:78:0D:7E:14:EB:98:05:36:31:D2:2F:FA:
		9E:55:3F:11:71:F6:3A:4C:A5:F2:A7:F7:D6:B3:84:31:27:88:0B:18:
		61:F6:68:F9:31:D6:C7:8D:E6:9C:17:2F:25:05:DF:3F:19:7F:69:95:
		5E:C4:1F:09:D1:31:CE:E2:77:A3:F2:63:F4:16:9D:EC:B8:5D:33:01:
		75:BB:59:6E:6D:70:93:92:4F:CF:45:9A:9C:AA:DB:F0:C3:CB:CD:54:
		14:EF:25:C3:61:5F:05:52:BB:57:9D:D4:DA:F6:72:F4:AC:56:1E:EC:
		5D:3D:79:EB:15:67:2A:80:CD:D8:2E:D1:AA:07:8F:C5:BB:E3:BD:32:
		A7:E8:32:F7:5E:CD:E0:42:C1:05:EB:28:41:C4:FE:34:E0:6D:7E:E1:
		4F:34:EF:C0:25:95:A3:4D:7F:AE:04:7A:9A:9E:17:91:5C:89:CF:F1:
		E7:27:B1:D9:E2:F5:9E:45:DE:C3:78:15:B9:35:29:3A:83:0E:54:EF:
		80:D6:A6:09:0D:9C:F0:18:4A:5C:00:89:88:10:B6:66:44:31:78:A9:
		C3:47:1D:73:C6:1C:0E:33:DE:01:13:A8:C1:7B:13:82:D9:CB:0F:E5:
		2C:AC:24:70:F1:4A:45:E9:67:0F:38:94:0A:51:72:A7:4A:3A:BA:05:
		89:D0:0D:13:A2:23:05:3A:1B:96:EE:5E:28:79:14:C9:20:F6:D4:94:
		F7:C0:20:FB:E3:B9:52:3D:BB:C5:BB:68:DE:F8:08:32:4E:A4:F2:F5:
		2C:98:87:E8:E5:23:3A:7A:7A:A7:4C:AA:97:04:07:3A:4A:FF:AD:EA:
		1C:52:C0:2D:20:73:F7:75:A1:94:92:4E:64:21:4A:0E:35:22:73:81:
		92:84:97:98:3A:C2:3E:06:99:42:86:1D:33:7E:8A:22:90:3F:66:8C:
		57:76:DE:B3:EC:D2:AA:DE:54:E4:C0:6E
You may have to check dmesg for any references to R8169. PCIe should be enabled, I used a NVMe boot drive. Remember that the location of config.txt is
/boot/broadcom/config.txt
I sure this is mentioned in the main image RPi5 thread.
  • mediocre_chloride
  • mediocre_chloride's Avatar
10 Jun 2025 22:43 - 10 Jun 2025 22:44
Thanks for the fast reply
I Downloaded 2.94 Rpi 5 based OS from the official linuxcnc/download site.
The Waveshare user guide states that something in the lines of:
Device Drivers
> Network device support
    > Ethernet driver support
       > Realtek devices
          > Realtek 8169/8168/8101/8125 ethernet support
needs to be added if not using original rpi os.
i am pretty sure that is the problem, as i see the card with lspci as described in the user guide:
but not in ifconfig:
it is also stated, drivers could be installed manually but its not recommended.
Also, there are other rpi linuxcnc distros floating around, do you think its worth switching around?
  • jlfauvel
  • jlfauvel's Avatar
10 Jun 2025 22:26
Replied by jlfauvel on topic LinuxCNC will not start... report file crated
… any advice on how to fix that?
  • Benb
  • Benb's Avatar
10 Jun 2025 22:14
Request for adding second led to existing hal push button
Category: Qtvcp
Chris is it possible to add a second hal led to the existing hal push button similar to:
Thank you
  • russkinch
  • russkinch's Avatar
10 Jun 2025 21:13
Replied by russkinch on topic Encoder for rigid tapping
Category: HAL
I did as you suggested. Many thanks. It worked a dream and I can still thread at 1000rpm. Going to sort my motor slow down speed as its currently two revolutions. So i have modified my ngc file for not to account for this. Many thanks again
Displaying 1726 - 1740 out of 25064 results.
Time to create page: 0.268 seconds
