  • Aldenflorio
  • Aldenflorio's Avatar
22 Nov 2024 20:33
Replied by Aldenflorio on topic Installing LinuxCnc on and SSD
  Thank you, I’m getting this… so maybe my SSD is bad. But it’s new so I didn’t know
22 Nov 2024 20:33
Replied by tommylight on topic LinuxCNC on Linux Mint Debian Edition 6
Category: Installing LinuxCNC
You can still use Mint19 but finding all the dependencies and coresponding LinuxCNC is not easy.
You can use the 2.8.4 ISO and add the RTAI kernel and RTAI version of LinuxCNC.
This should also be possible on 2.9.3 but i did not try it.
22 Nov 2024 20:30
Replied by tommylight on topic Installing LinuxCnc on and SSD
0. Remove the internal hard drive/SSD/NVME
6. Install on the external drive same as when using internal one.
  • natholego11
  • natholego11's Avatar
22 Nov 2024 20:29
N/O Probe issue was created by natholego11
N/O Probe issue
Category: HAL
Im not sure what happened as of late. but I recently have been getting an error with my probe when probing. I keep getting the error "probe is already tripped when starting G38.2 or G38.3 move" blah blah blah.
with the probe plugged in the HALmeter is showing that its "TRUE" and when I actuate the probe it goes to "FALSE"
and here is a link to the probe I have.
here is my HAL code.
# Generated by PNCconf at Tue Jan 18 09:12:59 2022
# Using LinuxCNC version:  2.8
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS #num_dio=30 num_aio=30
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=1 num_stepgens=5 sserial_port_0=00xxxx"
setp    hm2_7i96.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s
loadrt abs names=abs.0,abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt scale names=scale.spindle
loadrt near
loadrt or2 names=tool_probe, names=E_stop_comb
loadrt mux16 names=jogincr
addf hm2_7i96.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.a.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf scale.spindle            servo-thread
addf abs.spindle              servo-thread
addf lowpass.spindle          servo-thread
addf near.0                   servo-thread
addf hm2_7i96.0.write         servo-thread
addf abs.0              servo-thread
addf tool_probe           servo-thread
addf E_stop_comb          servo-thread
addf jogincr                  servo-thread
# external output signals
# --- COOLANT-MIST ---
net coolant-mist  =>     hm2_7i96.0.ssr.00.out-01
# --- Probe Blast---
#net probe-blast => hm2_7i96.0.ssr.00.out-02
# external input signals
# --- MACHINE-ON ---
net external-machine-on <= hm2_7i96.0.gpio.003.in_not
# --- ESTOP-EXT ---
net estop-ext     <=  hm2_7i96.0.gpio.000.in #=> E_stop_comb.in0
# --- PROBE-IN ---
#net probe-in     <=  hm2_7i96.0.gpio.001.in
net toolsetter-in     <=  hm2_7i96.0.gpio.001.in => tool_probe.in0
net probe-in     <=  hm2_7i96.0.gpio.002.in_not => tool_probe.in1
# --- ESTOP-EXT ---
#net estop-pendant     <=  hm2_7i96.0.gpio.045.in_not #=> E_stop_comb.in1
net tool-or-probe tool_probe.out
#net comb_E_stop E_stop_comb.out
#  AXIS X JOINT 0
setp   pid.x.Pgain     [JOINT_0]P
setp   pid.x.Igain     [JOINT_0]I
setp   pid.x.Dgain     [JOINT_0]D
setp   pid.x.bias      [JOINT_0]BIAS
setp   pid.x.FF0       [JOINT_0]FF0
setp   pid.x.FF1       [JOINT_0]FF1
setp   pid.x.FF2       [JOINT_0]FF2
setp   pid.x.deadband  [JOINT_0]DEADBAND
setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp   pid.x.maxerror 0.000500
net x-index-enable  <=> pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-pos-fb        =>  pid.x.feedback
net x-output        <=  pid.x.output
# Step Gen signals/setup
setp   hm2_7i96.0.stepgen.00.dirsetup        [JOINT_0]DIRSETUP
setp   hm2_7i96.0.stepgen.00.dirhold         [JOINT_0]DIRHOLD
setp   hm2_7i96.0.stepgen.00.steplen         [JOINT_0]STEPLEN
setp   hm2_7i96.0.stepgen.00.stepspace       [JOINT_0]STEPSPACE
setp   hm2_7i96.0.stepgen.00.position-scale  [JOINT_0]STEP_SCALE
setp   hm2_7i96.0.stepgen.00.step_type        0
setp   hm2_7i96.0.stepgen.00.control-type     1
setp   hm2_7i96.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= joint.0.motor-pos-cmd
net x-vel-cmd    <= joint.0.vel-cmd
net x-output     <= hm2_7i96.0.stepgen.00.velocity-cmd
net x-pos-fb     <= hm2_7i96.0.stepgen.00.position-fb
net x-pos-fb     => joint.0.motor-pos-fb
net x-enable     <= joint.0.amp-enable-out
net x-enable     => hm2_7i96.0.stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw     =>  joint.0.home-sw-in
net x-neg-limit     =>  joint.0.neg-lim-sw-in
net x-pos-limit     =>  joint.0.pos-lim-sw-in
#  AXIS Y JOINT 1
setp   pid.y.Pgain     [JOINT_1]P
setp   pid.y.Igain     [JOINT_1]I
setp   pid.y.Dgain     [JOINT_1]D
setp   pid.y.bias      [JOINT_1]BIAS
setp   pid.y.FF0       [JOINT_1]FF0
setp   pid.y.FF1       [JOINT_1]FF1
setp   pid.y.FF2       [JOINT_1]FF2
setp   pid.y.deadband  [JOINT_1]DEADBAND
setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror 0.000500
net y-index-enable  <=> pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-pos-fb        =>  pid.y.feedback
net y-output        <=  pid.y.output
setp   hm2_7i96.0.stepgen.01.dirsetup        [JOINT_1]DIRSETUP
setp   hm2_7i96.0.stepgen.01.dirhold         [JOINT_1]DIRHOLD
setp   hm2_7i96.0.stepgen.01.steplen         [JOINT_1]STEPLEN
setp   hm2_7i96.0.stepgen.01.stepspace       [JOINT_1]STEPSPACE
setp   hm2_7i96.0.stepgen.01.position-scale  [JOINT_1]STEP_SCALE
setp   hm2_7i96.0.stepgen.01.step_type        0
setp   hm2_7i96.0.stepgen.01.control-type     1
setp   hm2_7i96.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd    <= joint.1.motor-pos-cmd
net y-vel-cmd    <= joint.1.vel-cmd
net y-output     <= hm2_7i96.0.stepgen.01.velocity-cmd
net y-pos-fb     <= hm2_7i96.0.stepgen.01.position-fb
net y-pos-fb     => joint.1.motor-pos-fb
net y-enable     <= joint.1.amp-enable-out
net y-enable     => hm2_7i96.0.stepgen.01.enable
net y-home-sw     =>  joint.1.home-sw-in
net y-neg-limit     =>  joint.1.neg-lim-sw-in
net y-pos-limit     =>  joint.1.pos-lim-sw-in
#  AXIS Z JOINT 2
setp   pid.z.Pgain     [JOINT_2]P
setp   pid.z.Igain     [JOINT_2]I
setp   pid.z.Dgain     [JOINT_2]D
setp   pid.z.bias      [JOINT_2]BIAS
setp   pid.z.FF0       [JOINT_2]FF0
setp   pid.z.FF1       [JOINT_2]FF1
setp   pid.z.FF2       [JOINT_2]FF2
setp   pid.z.deadband  [JOINT_2]DEADBAND
setp   pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror 0.000500
net z-index-enable  <=> pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-pos-fb        =>  pid.z.feedback
net z-output        <=  pid.z.output
setp   hm2_7i96.0.stepgen.02.dirsetup        [JOINT_2]DIRSETUP
setp   hm2_7i96.0.stepgen.02.dirhold         [JOINT_2]DIRHOLD
setp   hm2_7i96.0.stepgen.02.steplen         [JOINT_2]STEPLEN
setp   hm2_7i96.0.stepgen.02.stepspace       [JOINT_2]STEPSPACE
setp   hm2_7i96.0.stepgen.02.position-scale  [JOINT_2]STEP_SCALE
setp   hm2_7i96.0.stepgen.02.step_type        0
setp   hm2_7i96.0.stepgen.02.control-type     1
setp   hm2_7i96.0.stepgen.02.maxaccel         [JOINT_2]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.02.maxvel           [JOINT_2]STEPGEN_MAXVEL
net z-pos-cmd    <= joint.2.motor-pos-cmd
net z-vel-cmd    <= joint.2.vel-cmd
net z-output     <= hm2_7i96.0.stepgen.02.velocity-cmd
net z-pos-fb     <= hm2_7i96.0.stepgen.02.position-fb
net z-pos-fb     => joint.2.motor-pos-fb
net z-enable     <= joint.2.amp-enable-out
net z-enable     => hm2_7i96.0.stepgen.02.enable
net z-home-sw     =>  joint.2.home-sw-in
net z-neg-limit     =>  joint.2.neg-lim-sw-in
net z-pos-limit     =>  joint.2.pos-lim-sw-in
#  AXIS A JOINT 3
setp   pid.a.Pgain     [JOINT_3]P
setp   pid.a.Igain     [JOINT_3]I
setp   pid.a.Dgain     [JOINT_3]D
setp   pid.a.bias      [JOINT_3]BIAS
setp   pid.a.FF0       [JOINT_3]FF0
setp   pid.a.FF1       [JOINT_3]FF1
setp   pid.a.FF2       [JOINT_3]FF2
setp   pid.a.deadband  [JOINT_3]DEADBAND
setp   pid.a.maxoutput [JOINT_3]MAX_OUTPUT
setp   pid.a.error-previous-target true
setp   pid.a.maxerror 0.000500
net a-index-enable  <=> pid.a.index-enable
net a-enable        =>  pid.a.enable
net a-pos-cmd       =>  pid.a.command
net a-pos-fb        =>  pid.a.feedback
net a-output        <=  pid.a.output
setp   hm2_7i96.0.stepgen.04.dirsetup        [JOINT_3]DIRSETUP
setp   hm2_7i96.0.stepgen.04.dirhold         [JOINT_3]DIRHOLD
setp   hm2_7i96.0.stepgen.04.steplen         [JOINT_3]STEPLEN
setp   hm2_7i96.0.stepgen.04.stepspace       [JOINT_3]STEPSPACE
setp   hm2_7i96.0.stepgen.04.position-scale  [JOINT_3]STEP_SCALE
setp   hm2_7i96.0.stepgen.04.step_type        0
setp   hm2_7i96.0.stepgen.04.control-type     1
setp   hm2_7i96.0.stepgen.04.maxaccel         [JOINT_3]STEPGEN_MAXACCEL
setp   hm2_7i96.0.stepgen.04.maxvel           [JOINT_3]STEPGEN_MAXVEL
net a-pos-cmd    <= joint.3.motor-pos-cmd
net a-vel-cmd    <= joint.3.vel-cmd
net a-output     <= hm2_7i96.0.stepgen.04.velocity-cmd
net a-pos-fb     <= hm2_7i96.0.stepgen.04.position-fb
net a-pos-fb     => joint.3.motor-pos-fb
net a-enable     <= joint.3.amp-enable-out
net a-enable     => hm2_7i96.0.stepgen.04.enable
net a-home-sw     =>  joint.3.home-sw-in
net a-neg-limit     =>  joint.3.neg-lim-sw-in
net a-pos-limit     =>  joint.3.pos-lim-sw-in
#  SPINDLE
setp   pid.s.Pgain     [SPINDLE_0]P
setp   pid.s.Igain     [SPINDLE_0]I
setp   pid.s.Dgain     [SPINDLE_0]D
setp   pid.s.bias      [SPINDLE_0]BIAS
setp   pid.s.FF0       [SPINDLE_0]FF0
setp   pid.s.FF1       [SPINDLE_0]FF1
setp   pid.s.FF2       [SPINDLE_0]FF2
setp   pid.s.deadband  [SPINDLE_0]DEADBAND
setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp   pid.s.error-previous-target true
setp   pid.s.maxerror 0.000500
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm     => pid.s.command
net spindle-vel-fb-rpm      => pid.s.feedback
net spindle-output        <=  pid.s.output
setp   hm2_7i96.0.stepgen.03.dirsetup        [SPINDLE_0]DIRSETUP
setp   hm2_7i96.0.stepgen.03.dirhold         [SPINDLE_0]DIRHOLD
setp   hm2_7i96.0.stepgen.03.steplen         [SPINDLE_0]STEPLEN
setp   hm2_7i96.0.stepgen.03.stepspace       [SPINDLE_0]STEPSPACE
setp   hm2_7i96.0.stepgen.03.position-scale  [SPINDLE_0]STEP_SCALE
setp   hm2_7i96.0.stepgen.03.step_type        0
setp   hm2_7i96.0.stepgen.03.control-type     1
setp   hm2_7i96.0.stepgen.03.maxaccel         [SPINDLE_0]MAX_ACCELERATION
setp   hm2_7i96.0.stepgen.03.maxvel           [SPINDLE_0]MAX_VELOCITY
net spindle-vel-cmd-rps  => hm2_7i96.0.stepgen.03.velocity-cmd
#(enables the DMM drive with the power button)
net machine-is-on <= halui.machine.is-on
net machine-is-on => hm2_7i96.0.ssr.00.out-00
#(enables the spindle stepgen)
net machine-is-enabled <= motion.motion-enabled
net machine-is-enabled => hm2_7i96.0.stepgen.03.enable
setp    hm2_7i96.0.encoder.00.counter-mode 0
setp    hm2_7i96.0.encoder.00.filter 1
setp    hm2_7i96.0.encoder.00.index-invert 0
setp    hm2_7i96.0.encoder.00.index-mask 0
setp    hm2_7i96.0.encoder.00.index-mask-invert 0
setp    hm2_7i96.0.encoder.00.scale  [SPINDLE_0]ENCODER_SCALE
net spindle-revs             <=   hm2_7i96.0.encoder.00.position
net spindle-vel-fb-rps       <=   hm2_7i96.0.encoder.00.velocity
net spindle-index-enable     <=>  hm2_7i96.0.encoder.00.index-enable
net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  spindle.0.speed-out
net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs
net spindle-enable             <=  spindle.0.on
net spindle-cw                 <=  spindle.0.forward
net spindle-ccw                <=  spindle.0.reverse
net spindle-brake              <=  spindle.0.brake
net spindle-revs               =>  spindle.0.revs
net spindle-at-speed           =>  spindle.0.at-speed
net spindle-vel-fb-rps         =>  spindle.0.speed-in
net spindle-index-enable      <=>  spindle.0.index-enable
net spindle-vel-cmd-rps    =>  near.0.in1
net spindle-vel-fb-rps-abs =>  near.0.in2
net spindle-at-speed       <=  near.0.out
net spindle-vel-fb-rps         =>  abs.0.in
net spindle-vel-fb-rps-abs abs.0.out
setp near.0.scale 1.000000
setp near.0.difference 2.00
#  Use ACTUAL spindle velocity from spindle encoder
#  spindle-velocity bounces around so we filter it with lowpass
#  spindle-velocity is signed so we use absolute component to remove sign
#  ACTUAL velocity is in RPS not RPM so we scale it.
setp     scale.spindle.gain 60
setp     lowpass.spindle.gain 1.000000
net spindle-vel-fb-rps        =>     scale.spindle.in
net spindle-fb-rpm               scale.spindle.out       =>   abs.spindle.in
net spindle-fb-rpm-abs           abs.spindle.out         =>   lowpass.spindle.in
net spindle-fb-rpm-abs-filtered  lowpass.spindle.out
# connect miscellaneous signals
#  ---HALUI signals---
net axis-select-x  halui.axis.x.select
net jog-x-pos      halui.axis.x.plus
net jog-x-neg      halui.axis.x.minus
net jog-x-analog   halui.axis.x.analog
net x-is-homed     halui.joint.0.is-homed
net axis-select-y  halui.axis.y.select
net jog-y-pos      halui.axis.y.plus
net jog-y-neg      halui.axis.y.minus
net jog-y-analog   halui.axis.y.analog
net y-is-homed     halui.joint.1.is-homed
net axis-select-z  halui.axis.z.select
net jog-z-pos      halui.axis.z.plus
net jog-z-neg      halui.axis.z.minus
net jog-z-analog   halui.axis.z.analog
net z-is-homed     halui.joint.2.is-homed
net axis-select-a  halui.axis.a.select
net jog-a-pos      halui.axis.a.plus
net jog-a-neg      halui.axis.a.minus
net jog-a-analog   halui.axis.a.analog
net a-is-homed     halui.joint.3.is-homed
net jog-selected-pos      halui.axis.selected.plus
net jog-selected-neg      halui.axis.selected.minus
net spindle-manual-cw     halui.spindle.0.forward
net spindle-manual-ccw    halui.spindle.0.reverse
net spindle-manual-stop   halui.spindle.0.stop
net machine-is-on         halui.machine.is-on
net jog-speed             halui.axis.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
#net probe-in     =>  motion.probe-input
net tool-or-probe     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
#net comb_E_stop   =>  iocontrol.0.emc-enable-in
net estop-ext     =>  iocontrol.0.emc-enable-in
#net estop-pendant  => iocontrol.0.emc-enable-in
#  ---manual tool change signals---
net tool-change-request     iocontrol.0.tool-change       =>  hal_manualtoolchange.change
net tool-change-confirmed   iocontrol.0.tool-changed      <=  hal_manualtoolchange.changed
net tool-number             iocontrol.0.tool-prep-number  =>  hal_manualtoolchange.number
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
  • Stanislavz
  • Stanislavz
22 Nov 2024 19:56
Replied by Stanislavz on topic LinuxCNC on Linux Mint Debian Edition 6
Kind of old one, i was used to mint 19 and 2.9 kernel. But now i can see no lind to download them.
  • Aldenflorio
22 Nov 2024 19:45 - 22 Nov 2024 19:46
Wait!
I think I think I remember where to find the instructionsFresh installs of LinuxCNC are most easily created using the Live/Install Image. This is a hybrid ISO filesystem image that can be written to a USB storage device or a DVD and used to boot a computer. At boot time you will be given a choice of booting the "Live" system (to run LinuxCNC without making any permanent changes to your computer) or booting the Installer (to install LinuxCNC and its operating system onto your computer’s hard drive).The outline of the process looks like this:
  1. Download the Live/Install Image.
  2. Write the image to a USB storage device using Rufus.
  3. Boot the Live system to test out LinuxCNC.
  4. Boot the Installer to install LinuxCNC.
  • gardenweazel
  • gardenweazel's Avatar
22 Nov 2024 19:42
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
I believe that I see what is going on.
There is a variable named MAXPROBE that is called from the INI as follows:  #<_ini[VERSA_TOOLSETTER]MAXPROBE>
There is also a variable that is read from the versaprobe screen saved in the qtdragon_hd.pref file as follows:  ps_probe_max_z_travel
The variable is also know as max_z_travel is some of the functions.
It appears as if both VARS are used for the same purpose. If I'm not mistaken the documentation indicates that the values are to be set and used in the INI file under VERSA_TOOLSETTER (brackets omitted).
I somewhat ignored the values in the qtdragon_hd.pref file which when I compared were NOT the same values. I know for a fact that my Z will travel more that 115mm which is what it was set at in the pref file. However, in my INI file I have set the value of 150mm which covers the length of all my tools.
Additionally I found a typo which I submitted a pull request a few hours ago.
I'll test this shortly and respond appropriately.
  • Aldenflorio
22 Nov 2024 19:36 - 22 Nov 2024 19:39
Installing LinuxCnc on and SSD was created by Aldenflorio
Hello,
first off I want to apologize. I know this is asked all the time and I have asked it before. Though I always ALWAYS have tons of trouble with this and I don’t know why.
I have an external SSD drive that I want linuxcnc on. I have a usb drive I intend to use as the downloader for that SSD drive. I can never fully figure out how to do this properly.
It will control a plasma CNC table that utilizes an Ethernet mesa card. I do not want a live system. I want a fully functional and programmable one
what do I download onto the usb to format the SSD?
again I’m sorry!
  • andypugh
  • andypugh's Avatar
22 Nov 2024 18:52 - 22 Nov 2024 18:52
Best version for Parport machine and how to install
You can select from submenus, but the format isn't well documented and it might take some experimentation to figure out which menu and submenu are which number.
I have:
GRUB_DEFAULT="4>2"
22 Nov 2024 18:26
Replied by tommylight on topic Latency on a Lenovo M715q
Is that base period or servo period?
In the ini file, do not change the value of servo period, it should be 1000000 (1 million).
  • okielaxplyr
  • okielaxplyr
22 Nov 2024 18:23 - 22 Nov 2024 18:24
Replied by okielaxplyr on topic Latency on a Lenovo M715q
hello Tommy
I am getting this error now.
Actually I have been getting this error all the time.
22 Nov 2024 18:22
For parallel port use the Wheezy ISO from the downloads page.
  • PCW
  • PCW's Avatar
22 Nov 2024 17:57 - 22 Nov 2024 18:12
Help: configure a Servo motor with (PUL/DIR) as a Spindle by Par-port stepconfig
Category: StepConf Wizard
Your X axis is using reset mode but the spindle is not:
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1 <<<<<<<<<<<<<<<
net xdir => parport.0.pin-03-out
net spindle-step => parport.0.pin-04-out
setp stepgen.0.steplen 1 <<<<<<<<
setp stepgen.0.stepspace 0 <<<<<<<<<
Also the spindle scale should be 800 for 800 steps/turn since you
are setting the stepgen velocity in RPS
(it should be 13.33333 if you set the stepgen velocity in RPM)
  • royka
  • royka
22 Nov 2024 17:12
If I remember it correctly that component doesn't work, you might want to try:
github.com/scottalford75/Remora/tree/mai...omponents/Remora-eth
and change in your hal settings to "loadrt remora-eth-3.0"
  • PCW
  • PCW's Avatar
22 Nov 2024 15:24
Replied by PCW on topic Mesa 7i92 with PC-2-Route Model M2 BOB
Category: Driver Boards
This should be close:
File Name: 7i92_slpc2x2d.zip
File Size:99 KB
Displaying 17641 - 17655 out of 24064 results.
Time to create page: 0.635 seconds
