  • rajsekhar
  • rajsekhar
17 Nov 2024 16:51
10 or 11 stepgen was created by rajsekhar
10 or 11 stepgen
How can I use 10 or 11 stepgen with mesa? What cards to be used?
  • rajsekhar
  • rajsekhar
17 Nov 2024 16:47
Replied by rajsekhar on topic 5 axis kinematics implementation
Well, machine is not complete yet..I will share may be within a month
  • Steffen
  • Steffen
17 Nov 2024 16:34 - 17 Nov 2024 16:35
Replied by Steffen on topic Download Lube component
Category: Deutsch
Der steigt beim laden der Komponenten aus, da alles schon vorhanden ist.
Die Zeit zwischen den Pulsen kann ich da auch nicht einstellen?
Ich hab mal meine Hal und Ini angehängt.
Seither habe ich einen Schalter für die Zentralschmierung in der Custom.Hal, das wurde zum testen ausgeklammert.
  • flexbex
  • flexbex
17 Nov 2024 16:10
linux keeps restoring to an old workspace state after reboot
Oh sorry that it wasn't clear. With workspace I mean the Linux environment. So at one point which I don't quite remember, I had several terminal windows and Firefox open. Now every time I start Linux, even when I already closed all windows or opened others, it gets back to this state.
  • RDA
  • RDA
17 Nov 2024 15:17
Replied by RDA on topic Trajectory Planner using Ruckig Lib
In what setups this is a problem? Parport?
If you have an ethercat servo, the servo takes care about the encoder pulses and you just read the position from the drive. So as long as the servo drives can keep up, lcnc side is ok.
I would assume this is the same with mesa stuff. The FPGA counts the pulses and lcnc just retrieves the pulse count periodically.
Or maybe I just misunderstand something.
  • Aciera
  • Aciera's Avatar
17 Nov 2024 15:15
Replied by Aciera on topic Download Lube component
Category: Deutsch
17 Nov 2024 15:14
All my "Mach3 Cloned Wizards" for lathe (NGCGUI routines)
Category: Lathe Library
Hi. this archive can't exstract.
If using Debian:
sudo apt install unrar
  • Aciera
  • Aciera's Avatar
17 Nov 2024 15:06 - 17 Nov 2024 15:07
Works fine for me.
  • BoxCNC
  • BoxCNC
17 Nov 2024 14:54
  • Steffen
  • Steffen
17 Nov 2024 14:32 - 17 Nov 2024 14:32
Category: Deutsch
Ich habe die selben Probleme wie sonst im Forum zu lesen, die Lube.py kann nicht gefunden werden.
Ich hab den Pfad neu angeben, Lese/Schreibrechte gesetzt und es ausführbar gemacht. Dazu alles mögliche in der Datei mit Python/2/3 versucht.
Eigentlich brauche ich nur was, wo mir alle 2 Minuten für ein paar Sekunden den Ausgang öffnet, ohne Überwachung.
Kann mir da jemand helfen?
Danke
Grüße
Steffen
  • Aciera
  • Aciera's Avatar
17 Nov 2024 14:16
Replied by Aciera on topic Spindle delay
Spindle delay
Category: Basic Configuration
Your signal names don't match up.
replace
net spindle-on => timedelay.0.in
with
net spindle-enable => timedelay.0.in
the editor is buggy and messes up the formating when you edit things. Use the 'Source' button in the top left of the editor to see the tags and move them around.
  • LabOuest
  • LabOuest
17 Nov 2024 14:06 - 17 Nov 2024 14:37
Yeah, I was running a youtube video in the background but still, you're right, it's quite high.
I thought that this could be a possible cause so I've already made all of the recommended changes to the bios.
Thank you for the heads up on the core isolation, I must have misunderstood Talla83's video.
I will try to better understand kernel settings, unfortunately, there's isn't a lot of information about my dell optiplex 3020m.
Pinging the EC500 gives a latency between 0.130 and 0.25ms.
I'm trying to narrow down the possible causes, do you experience about the same ethernet latency as I do ?
EDIT: Using Halshow I can get so more debug information:
  • remora.read.time is between 5 to 700 000
  • remora.update-freq.time is between 4-700
  • remora.write.time is 5 to 800 000
17 Nov 2024 13:49
Replied by tommylight on topic 10.5 x 25 cnc plasma table retrofit
Case is very nice, PC should be good (i have a similar looking one, works perfectly for Mesa), 5 phase steppers are nice as they vibrate less but also have less torque and yours seem to be the 5000 step per revolution ones!!! Damn, those are nice for some precise stuff. Vexta should be easy to find info on them, although lately google is failing miserably to find anything.
Power supply should do just fine, just do not expect record braking speed.
  • f3nix
  • f3nix
17 Nov 2024 13:46 - 17 Nov 2024 13:49
Replied by f3nix on topic Spindle delay
Spindle delay
Thanks @Aciera
I've tried that but the machine does not move after that. Trying to run some gcode the spindle starts but nothing else happens.
Cheers,
Mateusz
P.S. Are the code blocks broken in the forum?
  • Aciera
  • Aciera's Avatar
17 Nov 2024 13:35
Spindle delay
remove/comment this line in your spindle section:
net spindle-at-speed           <=  spindle.0.at-speed
Displaying 17941 - 17955 out of 24109 results.
Time to create page: 0.378 seconds
