  • Aciera
  • Aciera's Avatar
08 Nov 2024 16:07
Replied by Aciera on topic Please help create atc code
Category: Configuration Tools
for your parport input you could use eg 'motion.digital-in-00'
linuxcnc.org/docs/html/man/man9/motion.9.html
in your hal you would connect the two pins like this:
net somesignal  <your_parport_pin17_here> motion.digital-in-00
in your ngc remap you would then use M66 P0 .. to interact with your input:
linuxcnc.org/docs/html/gcode/m-code.html#mcode:m66
  • COFHAL
  • COFHAL
08 Nov 2024 15:45
Hiden spindle control buttons in AXIS
Category: AXIS
Why are the spindle control buttons not visible in AXIS?
  • Lcvette
  • Lcvette's Avatar
08 Nov 2024 15:45
Replied by Lcvette on topic Use z probe and 3d probe in the same input?
Category: QtPyVCP
loadrt or2
addf or2.0 servo-thread
net probe-touchprobe or2.0.in0 <= hm2_7i76e.0.7i76.0.0.input-08
net probe-toolsetter or2.0.in1 <= hm2_7i76e.0.7i76.0.0.input-09-not
net probe-input motion.probe-input <= or2.0.out
this is about the simplest or2 use for two inputs to motion.probe-input, in this method you would want to use a 3pin touch probe connection jack so that when you unplug the touch probe the jack closes the circuit which takes the input out of triggered state.
something like this maybe and jumper when plug is removed the jack closes.
www.amazon.com/MEETOOT-5-5mm-Female-Sock...trical/dp/B09JP19XKP
  • Organical_rob
  • Organical_rob
08 Nov 2024 14:59
Help with EtherCAT PDO Mapping for Sensor Integration in LinuxCNC
Category: EtherCAT
Hello, I'm new here too, but I've had to deal with the topic intensively recently.
You can create the ethercat_conf.xml very roughly if you run "ethercat xml" and then copy what is displayed into the XML.
You can then load the XML for testing purposes with "halcmd loadusr -W lcec_conf ethercat_conf.xmf". Now run "halcmd lcec" and then you can use "halcmd show" to see whether it is displaying the variables.
As long as the ethercat master is still idle, you will unfortunately not see any content.
To do this, you have to put together a small dummy machine somehow. Then
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
must appear in the .hal file so that the values ​​are queried. then look for a machine ini from the demos (which also contains your hal file) and
then start linuxcnc **.ini
if that works, "ethercat master" will show you Phase: operation at the top and you can also look at the values ​​with halcmd show.
I hope that helps a little.
  • Muftijaja
  • Muftijaja
08 Nov 2024 13:30
QT Dragon - Funktionstaste mit "Override limits" belegen?
Category: Deutsch
Hallo cmorley, große Klasse! Dein Script funktioniert auf Anhieb und ich bin glücklich über diese Vereinfachung! Danke danke!
  • Danil
  • Danil
08 Nov 2024 11:46 - 08 Nov 2024 11:46
Replied by Danil on topic Please help create atc code
Thanks for the reply, now I'm trying to do something via remap but I'm not sure I'm doing it right. I can't figure out how to interact with pin 17 on port 0.So far there is this outline of the remap, I would appreciate it if you could point out any errors.Thanks for the links, I'll have a look.
  • sk_linuxcnc
  • sk_linuxcnc
08 Nov 2024 11:41
Execute G-code when triggered by an external input (on parallel port input pin)
thank you for the guide. i am looking into it and so far it seems promising. i might have some questions down the line when i start building my g-code around the suggested solution.
  • Adam_C
  • Adam_C
08 Nov 2024 11:14
Which LinuxCNC version for a MESA 7i96s in 2024?
Which version of LinuxCNC is recommended for the MESA 7i96s (for a beginner user) in late 2024 / '25?
Debian 10 (Buster) + 2.8.4 has a few very good youtube beginner tutorials.  Is Buster + 2.8.4 still a reliable and recommended install?
A forum search on 7i96s + 2.9 seems mainly to be posts of people with issues getting 2.9 working reliably ...
I'd just like whichever solution is easiest to get up and running reliably!
  • Aciera
  • Aciera's Avatar
08 Nov 2024 10:26
Have a look at the halui.program.* halpins:
linuxcnc.org/docs/html/man/man1/halui.1.html
Depending on the gui you are using it may provide its own hal pins to steer program execution.
  • meister
  • meister
08 Nov 2024 10:25
You need only to lower the voltage a little bit for the Level-Shifter with a Diode or two Resistors,
the FPGA can handle up to 3.3V input and the Level-Shifter need to detect 1.8V as high.
  • Aciera
  • Aciera's Avatar
08 Nov 2024 10:24
Replied by Aciera on topic Rotary axis Display
Rotary axis Display
but after applying G54 on X, it becomes a mess:
This issue is a known limitation of the feature. Please read paragraph 11 the documentation I posted above.
  • tommy
  • tommy
08 Nov 2024 09:35 - 08 Nov 2024 09:36
Replied by tommy on topic Rotary axis Display
Rotary axis Display
I hope this video will make more clear what is happening, I have no issue with g-code from CAM, machined parts are ok, only display section is a bit off in my case:
  • sk_linuxcnc
  • sk_linuxcnc
08 Nov 2024 09:34
Hello, i am new to the linuxCNC systems.
I wish to build a simple rotating axis controlled by linuxcnc gcode. And i have a external robot which would perform some machining operations on the rotating part.
Now i want to sync both the machines. such that when i start the robot, the linuxcnc should also start executing the gcode.
Is it possible to execute the gcode when an input is provided through one of the parallel port input pins?
does the M66 code work here?
how to then pause the program if i pause the action of the robot (incase i have to e-stop the robot) and how to make sure then that the gcode is resumed from the paused location once the robot restarts and sends execution trigger to the linux cnc.
  • behai
  • behai
08 Nov 2024 08:04
Installing LinuxCNC 2.9 on Raspberry Pi 4B with Preempt-RT kernel
Category: Installing LinuxCNC
A shot from the hip, but usually those drive/steppers will have wrong encoder wiring, would be prudent to double check.
Hi tommylight,
It just so turned out you were right: one of my encoder wire were loose, I tightened it on the CL57T-V41 driver and it behaves now.
This is the wiring diagram:
My References for the Wiring Diagram:
1.
From 34:14 CL57T Driver Overview.
2. help.stepperonline.com/en/article/wiring...tepper-motor-4cddqy/
The first CL57T diagram.
3. pypi.org/project/cl57t-raspberry-pi-stepper-drive/
See the table for signal pins to the Raspberry Pi 4B.
And I have learned to work the ENA+ pin: setting it to low to enable, to high to disable.
The Python code below turns the motor 1 revolution, pauses for a little then keeps on turning till Control C to stop.
If I changed [ gpio.output( ena_pin, gpio.LOW ) ] to [ gpio.output( ena_pin, gpio.HIGH ) ] the motor won't turn.
Now I am trying to figure out why I need 1600 to do one revolution, it is about how the DIP switches are set, I have to understand the table in the manual :)
Thank you and best regards,
...behai.
# 08/11/2024
# Enable by setting ENA+ pin to low. Expected: motor will run.
# /usr/bin/python3 nema23_04_ena_enabled.py
from time import sleep
import RPi.GPIO as gpio
direction_pin   = 13
pulse_pin       = 6
ena_pin         = 19
cw_direction    = 0
ccw_direction   = 1
gpio.setmode( gpio.BCM )
gpio.setup( direction_pin, gpio.OUT )
gpio.setup( pulse_pin, gpio.OUT )
gpio.setup( ena_pin, gpio.OUT )
gpio.output( direction_pin, cw_direction )
# Enable.
# ENA pin must be ahead of DIR by at least 200ms.
sleep( 0.5 )
try:
    while True:
        print( 'Direction CW' )
        sleep( .5 )
        gpio.output( direction_pin,cw_direction )
        for x in range( 1600 ):
            gpio.output( pulse_pin, gpio.HIGH )
            sleep( 0.0001 )
            gpio.output( pulse_pin, gpio.LOW )
            sleep( 0.0001 )
except KeyboardInterrupt:
    # Disable.
    gpio.cleanup()
Displaying 18466 - 18480 out of 24125 results.
Time to create page: 1.168 seconds
