  • SOLD
  • SOLD
30 Oct 2024 05:58
AX58100 was created by SOLD
AX58100
Category: EtherCAT
Hello
I'm a newbie. I started DIY Ethercat board with AX58100
1. AX58100-16in-16out
2. AX58100-Step/DIR + Encoder ABZ +8in/8out GPIO
Everything works on Twincat and I can connect it to Linux lcec
I want to use it with Linux CNC as 3axis and 1 spindle
In the axis there are
-Step/Direct
-Input8
-Output8
-Encoder ABZ
And there is AX58100-16in-16out board as the main I/O of the system
But I still can't create the correct ethercat-conf.xml file. I don't understand if it needs to be used as CIA402 or not
I have attached the XML files from AXIS for both boards
Can you please suggest a generator for ethercat-conf.xml for this project
Thanks for your support
  • jonesmg1
  • jonesmg1
30 Oct 2024 04:09
Replied by jonesmg1 on topic Puma 6 axis Robotic Arm with Mesa 7i80/7i40
The system does have brakes which I have disabled (the joint free drops when it gets the follow error)
it doesn’t have a physical counterbalance that I can tell, maybe the gearbox has some sort of clutch?
When idle, the motors are able to hold the joint in place even if I push on it.
I have a feeling that there’s something off  between the motors and encoders.   When it moves, it seems to be miscalculating the actual vs expected travel - but that’s just gut feeling.   It sometimes errors moving up, but not always.. it always errors moving down.
  • m3chanist
  • m3chanist's Avatar
30 Oct 2024 01:26
Replied by m3chanist on topic New LinuxCNC-Ethercat git tree
Category: EtherCAT
link to fdarling's sample code if you don't already have it by now.
forum.linuxcnc.org/media/kunena/attachme...st.tar_2023-10-30.gz
  • Thayloreing
  • Thayloreing
30 Oct 2024 01:02
change the ini with the axis interface open was created by Thayloreing
Is there any way to create a button to select two different accelerations? example
my machine has an acceleration of 1000ms2 in the ini file, I want to create a button in the axis interface that when I press it changes the acceleration to 500, so I can work with heavy parts more smoothly without having to change it manually
30 Oct 2024 00:09
Replied by Cant do this anymore bye all on topic Installing LinuxCNC 2.9 on Raspberry Pi 4B with Preempt-RT kernel
Category: Installing LinuxCNC
First of all, my deepest deepest sympathies,sorry to hear you live in Melbourne, the only good thing Victoria has to other is Philip Island and the roads, airports and docks that lead out of the state.
Why aren't you using the premade image for your RPi ?
The links are on the Linuxcnc home page under downloads.
30 Oct 2024 00:04
Replied by Cant do this anymore bye all on topic recent Update makes LinuxCNC defect
Please supply config files.
29 Oct 2024 23:53
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
No the W5500 works, initiating (ip addrr and other such stuff) is done via the FPGA via the SPI interface.
You'll have to setup your config to use the W5500 so that the correct bitfile is generated.
Examples and docs are supplied on the github project page.
Remember "it doesn't" work isn't very helpful when trying to get help. Config files and such help. Remember this is not a trip to the dentist, we are not dentists and don't want to have to pull teeth to get information to help.
  • mBender
  • mBender
29 Oct 2024 22:55
29 Oct 2024 22:29
Replied by tommylight on topic Cannot stat/ no such file or directory
Any reason for not using the ready made debs from the releases page?
github.com/NTULINUX/RTAI/releases
Or from here
linuxcnc.org/dists/bookworm/base/binary-amd64/
and the corresponding LinuxCNC build from here
linuxcnc.org/dists/bookworm/2.9-rt/binary-amd64/
  • Micro2000
  • Micro2000
29 Oct 2024 22:25
Replied by Micro2000 on topic Cannot stat/ no such file or directory
I think I'm going to send it, because I found in the /usr/src/RTAI/ksrc/5.4.279 there are 4 .patch files that I think are what I needed.
29 Oct 2024 22:21
Replied by tommylight on topic Only one of the gantry joints move
Category: Basic Configuration
Yeah, to many things missing and/or wrong there, or wrong config files.
Use StepConf wizard to make a new config and choose as shown in the attached picture:
  • Micro2000
  • Micro2000
29 Oct 2024 22:20
This wouldn't happen to be what you are saying is it?
$ git clone /ksrc/patches/v5.4.279/"*.patch ; do patch -p1 < "${i}" ; done
  • Malteser01
  • Malteser01
29 Oct 2024 21:38
Replied by Malteser01 on topic Only one of the gantry joints move
So, now that I finally found time and access to a pc, I can share my .hal and .ini
I really appreciate any effort anyone puts into this.
  • Dougal9887
  • Dougal9887
29 Oct 2024 20:25
Replied by Dougal9887 on topic [Solved] Trying to install RTAI, got errors
Resolved issues by installing via dpkg from the Linuxcnc Downloads page rather than the Synaptic packages, ie followed the instructions above!
Max jitter on Dell Optiplex 980 i3 550 3.2GHz, 16GB ram, 512GB SSD, has dropped from c.60,000 using preemt rt to c.9800 using rtai with everything recommended disabled in BIOS.
So a good result.
Displaying 19006 - 19020 out of 24117 results.
Time to create page: 0.505 seconds
