  • COFHAL
  • COFHAL
26 Oct 2024 12:47
Replied by COFHAL on topic AC Servo ball screw pitch adjustment
Category: EtherCAT
Put in hal file setp cia402.1.velo-scale XXXXX. XXXfor velocity mode or setp cia402.1.pos-scale XXXXX. XXX for position mode the servo.
  • bkt
  • bkt's Avatar
26 Oct 2024 12:45
mb2hal & ethercat master on same rj45 port
Category: EtherCAT
someone have never try it ... some special config on to ethercat config file? .... because never find port number only mac adress and ip adress on that file .... so not sure can work.
  • Macwolf
  • Macwolf
26 Oct 2024 12:29
Replied by Macwolf on topic AC Servo ball screw pitch adjustment
Category: EtherCAT
thanks but where is this entered? in the encoder but under which category? Homing
  • COFHAL
  • COFHAL
26 Oct 2024 12:21
Category: EtherCAT
It's simple: divide the encoder resolution by the screw pitch.
  • JT
  • JT's Avatar
26 Oct 2024 10:46
Replied by JT on topic What is gs2_vfd ?
What is gs2_vfd ?
I just got a GS20 drive yesterday as a replacement for my mill but first I have to learn how to configure it for another project.
JT
  • Macwolf
  • Macwolf
26 Oct 2024 10:29
AC Servo ball screw pitch adjustment was created by Macwolf
Category: EtherCAT
Hello, I use an AC servo with an EC interface. With a normal servo you set the steps on the encoder and then enter the steps in the controller.
My question is, is this also done with the Ethercat servo? I don't have any experience with servos like this. Or is it done in the Lcnc settings?
If this is the wrong forum, please move it, thanks
  • Aciera
  • Aciera's Avatar
26 Oct 2024 09:19
Replied by Aciera on topic linuxcnc trajectory planner
Yes that seems to work.
Note: Running './installer' ends with an error when trying to open a config in the end. But opening a new terminal then running 'source scripts/rip-environment' fixes it.
  • fly up
  • fly up
26 Oct 2024 08:19
How to connect after source code download linuxcnc and ethercat
Category: EtherCAT
Okay, I'll do what I can to try to solve the problem until I run into a new one.
thanks.
  • tar_san
  • tar_san
26 Oct 2024 02:31
Help me solve big latency (INTEL NUC7 / Pentium J5005 )
Thank you so much.
I posted new result ( but I did not apply these options )
I will test later.
I should learn these options and tips.
  • tar_san
  • tar_san
26 Oct 2024 02:29
Thank you.
I set the package power limit in BIOS to 0 for both sustained and burst mode,
But PC worked incredibly slow ..
Anyway, thank you so much. I posted new result, very improved.
  • tar_san
  • tar_san
26 Oct 2024 02:26
Thank you for your advice, everyone.
I got this result so far. (90 μsec jitter) really improved.
My question is " Is 90 μsec jitter is good enough to run LinuxCNC with MESA(Ethernet FPGA Stepper) ?
  • cakeslob
  • cakeslob
26 Oct 2024 01:46
anyone looking to use the new thing with RPi5, keep in mind, you need to use the new firmware also. Right now Ive added a precompiled firmware for octopus446 and more will be added later but you can compile your own in the meantime
  • Micro2000
  • Micro2000
26 Oct 2024 00:21
Replied by Micro2000 on topic Base Thread Over 100k
To be more specific I have SMP PREEMPT RT Debian 4.19.316-1. I'll still swap it with RTAI.
25 Oct 2024 21:16
Replied by tommylight on topic Another EMI issue
Another EMI issue
Category: Basic Configuration
The ones in red can be removed, but it is very OK to leave them on.
The ones in blue should have the same thing as the ones in green.
I know it is working, but i like it done properly. :)
  • Grotius
  • Grotius's Avatar
25 Oct 2024 21:12
Replied by Grotius on topic linuxcnc trajectory planner
Hi Arciera,
Had the same error's as you had, can not find liblinuxcnchal.so.0
But before that, i had symbol errors. Can not find tp....
Now after a few moments... it works here.
It looks to me like building liblinuxcnchal, motmod and tpmod must have a build order to properly be linked.
Therefore liblinuxcnc hal is now also build by the cmake system, to avoid errors.
Belos is a new clone from the linuxcnc repository. History can be seen now. And we can synchronize so now and then.
Then added the cmake dir and scripts to it. It seems to work now.
linuxcnc
It builds the original motmod, as we now can focus on the tpmod.
Displaying 19201 - 19215 out of 24144 results.
Time to create page: 1.157 seconds
