07 Jun 2025 21:19
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Nope, did not work for me either.
This does work, needs a bit of editing if you need faster step rates than 16kHz, i got it to 40kHz without issues and fixed a strange issue where it would sometimes send steps back and forth after a jog.
github.com/jzolee/HAL2UDP
07 Jun 2025 21:16
Replied by tommylight on topic CNC lathe to grinder.
Category: Basic Configuration
I did, but i forgot, sorry.
  • rodw
  • rodw's Avatar
07 Jun 2025 21:14
Feature Request: ramp piercing (aka moving piercing)
Category: Plasmac
Sorry to post on a old topic but I wanted to see if this functionality was in qtplasmac in the 2.9.4 install or if you need to be running from the 2.10 master?  Also, has anyone done moving piercing in Fusion360 CAM?
You really should read the previous post.
  • BlownCorona
  • BlownCorona
07 Jun 2025 21:01
Replied by BlownCorona on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Yesterday evening i was using chatgpt to help understand some of the nuts and bolts of what certain values mean. i made progress but perhaps you can check its homework.
i did set the following errors wider which has prevented this error occurring for the most part, though i understand this should eventually be taken right back down to the tight window it should be.
FERROR = 10
MIN_FERROR = 5
notably, it suggested changing the PWM scale from 10 to 1, claming that this would provide the expected +-10V and the voltage limits coming from the max outputs which on the surface makes sense and got me to the point where i was tuning a motor that was either violently oscillating or buzzing angrily, tuning pid values to a very low point gave a quieter (but not silent) motor but it was sluggish.
Now it could be that im not in a position to tune properly, or i could have screwed the code up much worse because i am quite aware that chatgpt is not our savior and it will be confidently wrong.
the documentation here supports the claim that the scale should = 1 however im not certain why mesaCT set that scale as = 10
www.linuxcnc.org/docs/html/man/man9/pwmgen.9.html
feels like progress, and i dont think im far off cracking it.
  • rodw
  • rodw's Avatar
07 Jun 2025 21:00
IO Questions around mixing IO between Ethercat and Pi 5?
Category: EtherCAT
Howdy all,
     I am working out the high level architecture (and ordering) for a Ethercat retrofit of my CNC Mill ( its VFD is dying and its as good an excuse as any to re work may decisions I made on it when I converted it to LinuxCNC the first time)..
Anyways, I am looking at the MPG and realizing that I have open IO pins on my pi (like all of them).
So here is my current "plan" for I/O which I would love feedback on
1x EK1100 - Ethercat to FieldBus coupler
2x EL1819  - 16 inputs (I need 28 so 2 it is) - (the response time is killer vs the EL1809)
1x EL2819 - 16 output (need 11 so that works)
1x EL5151 - Encoder for the MPG  <-- this is where I would love feedback because this guy is $250 used
The really open question is what risks on integration and general PITA am I facing if I use my Pi's IO pins to handle MPG encoder rather than the spendy EL5151.
I plan to use either Leadshine or Innovance mult-turn servos for all of my motors and spindle so my only current known need for an encoder is the MPG...  This is less a question of "can I mix Ethercat with Pi IO pins" and more a question of "should I"... Am I setting myself up for sparks and pain getting the realtime thread where the Pi IO will come in syncing with the rest of the system that is all running on the Server Thread?
To that end, should I be using other parts of the Pi's IO for emergency stuff like e-stop?
Thanks in advance.
  • rodw
  • rodw's Avatar
07 Jun 2025 20:54
Replied by rodw on topic QTPlasmac pierce delay handling
Category: Plasmac
The pierce delay starts from when qtplasmac gets an ArcOK signal signifying that arc transfer has occurred. If your synthesized arcOK is off, you will have problems.
Do yourself a favour and wire in the machine's arcOK signal. The time you will save stuffing around trying to get a synthesized arcOK working will more than cover the time you will spend wiring it in properly.
  • PCW
  • PCW's Avatar
07 Jun 2025 19:06
Replied by PCW on topic Index homing Heidenhain ls 403/exe602
I am still looking into this, I did make a small change to the encoder driver to simplify
the index spacing detection. (I added the option to not zero the position on index detection)
This should simplify the distance coded index detection hal component, otherwise I would
have needed to undo the encoder position zeroing in the hal component, and that was pretty ugly.
  • PCW
  • PCW's Avatar
07 Jun 2025 18:58
Replied by PCW on topic Mesa 7i97T & LinuxCNC setup struggles
I would try setting the following errors wider so you can see the actual behavior without getting an instant following error
(say 25 and 25 mm)
Then first set the PID up with all terms 0 except a small amount of P
Then check if the motors roughly hold position and move when jogged
  • TheTinkeringMechanic1
07 Jun 2025 18:46
Replied by TheTinkeringMechanic1 on topic CNC lathe to grinder.
Please read the post fully to understand why this is necessary.
07 Jun 2025 18:44
I will get this posted as soon as I can. Thank you.
  • farmer_mike
  • farmer_mike
07 Jun 2025 17:59
Replied by farmer_mike on topic Experimental XML config generator
Category: EtherCAT
Thanks for the help everyone. I decided to move my project to a Raspberry Pi 4, so I made sure to use the latest versions of LinuxCNC and Ethercat. I think I have the experimental XML config working now. I am a little unsure what to do with the output file.
I'll paste two files below. The first file is the ethercat-conf.xml from my CNC project when I had a single axis using an Rtelligent ECT 60 stepper motor.The single axis worked, so I have since bought two Rtelligent RS750E AC Servo drives. All I have done with the RS750E drives is power them up and connect the Ethernet. I haven't done any onboard parameter programming yet.
The experimental XML config generator recognized all three drives in order.
Is the output from the experimental XML config generator meant to be used to create the ethercat-conf.xml file?
<masters>
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
    <!-- Joint 0 -->
    <slave idx="0" type="generic" vid="00000a88" pid="0a880002" configPdos="true">
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
      <sdoConfig idx="2000" subIdx="0"><sdoDataRaw data ="88 13"/></sdoConfig>  <!-- Max motor current (5.0) -->
      <sdoConfig idx="2007" subIdx="6"><sdoDataRaw data ="05"/></sdoConfig>     <!-- Input 6 - Emergency Stop -->
      <sdoConfig idx="2007" subIdx="5"><sdoDataRaw data ="05"/></sdoConfig>     <!-- Input 3 - Home Function -->
      <sdoConfig idx="2011" subIdx="0"><sdoDataRaw data ="01 00"/></sdoConfig>  <!-- Closed loop -->
      <sdoConfig idx="6098" subIdx="0"><sdoDataRaw data ="11 00"/></sdoConfig>  <!-- Home mode 17 -->
      <sdoConfig idx="607C" subIdx="0"><sdoDataRaw data ="00 00"/></sdoConfig>  <!-- Home offset 0  -->
      <sdoConfig idx="609A" subIdx="0"><sdoDataRaw data ="F4 01"/></sdoConfig>  <!-- Home accelleration 500 -->
      <sdoConfig idx="6099" subIdx="01"><sdoDataRaw data ="C4 09"/></sdoConfig>  <!-- Home fast speed 2500-->
      <sdoConfig idx="6099" subIdx="02"><sdoDataRaw data ="F4 01"/></sdoConfig>  <!-- Home slow speed 500 -->
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
          <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
          <!-- Target Position -->
          <pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
          <!-- Target Velocity -->
          <pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
          <!-- Digtial Outputs (manufacturer's extension ECT86/ECT60)-->
          <pdoEntry idx="204A" subIdx="0" bitLen="16" halType="complex">
            <complexEntry bitLen="1" halPin="out-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-2" halType="bit"/>
            <complexEntry bitLen="14"/>
          </pdoEntry>
        </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
          <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
          <pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
          <pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
          <pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="actual-torque" halType="s32"/>
          <!-- Digtial_inputs (cia402 compatible) -->
          <pdoEntry idx="60FD" subIdx="0" bitLen="32" halType="complex">
            <complexEntry bitLen="1" halPin="CW-limit" halType="bit"/>
            <complexEntry bitLen="1" halPin="CCW-limit" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-home" halType="bit"/>
            <complexEntry bitLen="13"/>
            <complexEntry bitLen="1" halPin="in-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-2" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-3" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-4" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-5" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-6" halType="bit"/>
            <complexEntry bitLen="10"/>
          </pdoEntry>
        </pdo>
      </syncManager>
    </slave>
   </master>
</masters>
<masters>
  <master idx="0">
    <slave idx="0" type="ECT60" name="D1">
      <!-- Enable support for Cyclic Synchronous Position mode. -->
      <modParam name="enableCSP" value="true"/>
      <!-- Enable support for Cyclic Synchronous Velocity mode. -->
      <modParam name="enableCSV" value="false"/>
      <!-- Maximum stepper Amps. -->
      <modParam name="peakCurrent_amps" value="6.0"/>
      <!-- Operation mode: openloop, closedloop, or foc. -->
      <modParam name="controlMode" value="closedloop"/>
      <!-- Number of encoder steps per revolution. -->
      <modParam name="encoderResolution" value="4000"/>
      <!-- Output 1 use: general, alarm, brake, in-place. -->
      <modParam name="output1Func" value="alarm"/>
      <!-- Output 2 use: general, alarm, brake, in-place. -->
      <modParam name="output2Func" value="brake"/>
      <!-- Input 3 use: general, cw-limit, ccw-limit, home, clear-fault, emergency-stop, motor-offline, probe1, probe2 -->
      <modParam name="input3Func" value="cw-limit"/>
      <!-- Input 4 use: general, cw-limit, ccw-limit, home, clear-fault, emergency-stop, motor-offline, probe1, probe2 -->
      <modParam name="input4Func" value="ccw-limit"/>
      <!-- Input 5 use: general, cw-limit, ccw-limit, home, clear-fault, emergency-stop, motor-offline, probe1, probe2 -->
      <modParam name="input5Func" value="home"/>
      <!-- Input 6 use: general, cw-limit, ccw-limit, home, clear-fault, emergency-stop, motor-offline, probe1, probe2 -->
      <modParam name="input6Func" value="motor-offline"/>
    </slave>
    <slave idx="1" type="basic_cia402" vid="0x00000a88" pid="0x0a880013" name="D2">
      <!--RS750E(COE)-->
      <modParam name="ciaRxPDOEntryLimit" value="9"/>
      <modParam name="ciaTxPDOEntryLimit" value="9"/>
      <modParam name="enablePP" value="true"/>
      <modParam name="enablePV" value="true"/>
      <modParam name="enableTQ" value="true"/>
      <modParam name="enableHM" value="true"/>
      <modParam name="enableCSV" value="true"/>
      <modParam name="enableCST" value="true"/>
      <modParam name="enableActualFollowingError" value="true"/>
      <modParam name="enableActualTorque" value="true"/>
      <modParam name="enableDigitalInput" value="true"/>
      <modParam name="digitalInChannels" value="16"/>
      <modParam name="enableDigitalOutput" value="true"/>
      <modParam name="digitalOutChannels" value="16"/>
      <modParam name="enableErrorCode" value="true"/>
      <modParam name="enableFollowingErrorTimeout" value="true"/>
      <modParam name="enableFollowingErrorWindow" value="true"/>
      <modParam name="enableHomeAccel" value="true"/>
      <modParam name="enableMaximumCurrent" value="true"/>
      <modParam name="enableMaximumTorque" value="true"/>
      <modParam name="enablePolarity" value="true"/>
      <modParam name="enablePositionDemand" value="true"/>
      <modParam name="enablePositioningTime" value="true"/>
      <modParam name="enablePositioningWindow" value="true"/>
      <modParam name="enableProbeStatus" value="true"/>
      <modParam name="enableProfileAccel" value="true"/>
      <modParam name="enableProfileDecel" value="true"/>
      <modParam name="enableProfileMaxVelocity" value="true"/>
      <modParam name="enableProfileVelocity" value="true"/>
      <modParam name="enableTargetTorque" value="true"/>
      <modParam name="enableTorqueDemand" value="true"/>
      <modParam name="enableTorqueSlope" value="true"/>
      <modParam name="enableVelocityErrorTime" value="true"/>
      <modParam name="enableVelocityErrorWindow" value="true"/>
    </slave>
    <slave idx="2" type="basic_cia402" vid="0x00000a88" pid="0x0a880013" name="D3">
      <!--RS750E(COE)-->
    </slave>
  </master>
</masters>
  • farmer_mike
  • farmer_mike
07 Jun 2025 17:55
test post was created by farmer_mike
test post
<masters>
    <!-- Joint 0 -->
        <pdo idx="1600">
          </pdoEntry>
        </pdo>
      </syncManager>
        <pdo idx="1a00">
          </pdoEntry>
        </pdo>
      </syncManager>
    </slave>
   </master>
</masters>
<masters>
  <master idx="0">
    </slave>
      <!--RS750E(COE)-->
    </slave>
      <!--RS750E(COE)-->
    </slave>
  </master>
</masters>
07 Jun 2025 17:47
I do not have much experience with lathe, but homing near the chuck is just asking for trouble, there is a damn good reason to home as far as possible from the chuck, especially if the machine has a toolchanger.
07 Jun 2025 17:43
Try to set networking from serial, if it reboots do not bother with it as it will not work.
Something got left unfinished, the developer has not been around for a year or two, so short of you forking it and fixing it, there is not much use.
It also does not work with ESP32S3 despite him posting everything running on it, it will not compile at all.
Use the hal2udp version of it, the older version worked fine on ESP32Wroom, but the new version also has issues. You can get the older version on github, or try the new version as this one is being developed still.
Displaying 2026 - 2040 out of 25021 results.
Time to create page: 0.296 seconds
