  • ihavenofish
  • ihavenofish
28 Sep 2024 02:38
Replied by ihavenofish on topic Decent servo suppliers and recommendations
That's leadshine. A potential option here, but their prices are way too high.
28 Sep 2024 02:35
Replied by tommylight on topic Decent servo suppliers and recommendations
Lichuan makes some lower priced kits people are trying out (ethercat as well as step/dir). I have not seen any on an actual linuxcnc machine running yet though.
forum.linuxcnc.org/ethercat/51830-marco-...utube-about-ethercat
  • ihavenofish
  • ihavenofish
28 Sep 2024 02:18
Replied by ihavenofish on topic converting a tos/intos fngj 40
Category: Milling Machines
Thanks. I screwed up my numbering. :)
  • ihavenofish
  • ihavenofish
28 Sep 2024 02:14
Delta is easily found for very cheap online and has a good reputation. Hard to beat for value from a top end supplier.
28 Sep 2024 02:05
Replied by tommylight on topic converting a tos/intos fngj 40
Just in case, for analog servos from Mesa, depending on availability :
7i97T
or
7i92TM + 7i77
or
7i92TM + 7i85 + 7i83
or
7i96S + 7i85 + 7i83
And if you end up needing more IO, grab a 7i84, it can be easily wired to any of the above combos
  • rodw
  • rodw's Avatar
28 Sep 2024 01:53
Replied by rodw on topic Where can I find .ko files
Category: HAL
You don't need to know where the .ko's live
Halcompile looks after that for you. Just write your component and
sudo halcompile --install mycomp.comp
  • rodw
  • rodw's Avatar
28 Sep 2024 01:49
Replied by rodw on topic 8 Spindle Gang Router
Category: Show Your Stuff
Sorry to hear that Todd. I'm sure many of us who you have helped over the years will feel the same,
  • ihavenofish
  • ihavenofish
28 Sep 2024 01:44 - 28 Sep 2024 02:16
As to the electrical... Mesa 7i77 would be where you start for analogue with quadrature encoders, but I would have in the back of my head replacing the servos with new ones.
  • ihavenofish
  • ihavenofish
28 Sep 2024 01:40
Oooh, nice. I always liked these.
For reference, these are basically the same is a MAHO, so all the same rules should apply.
Mine had the revolving nut for the z ram. But they way they did it was to have a normal ball screw nut mounted in a rotary mechanism. So check over what you have there already, it may be reusable with a normal ball screw.
  • bentiggin
  • bentiggin
28 Sep 2024 00:52
I'm looking for a small servo motor and drive combo and I'm just not having much luck.
I think I sold myself on yaskawa, but the few companies I've reached out to either will get back to me with a quote(it's friday, i get it) or haven't been helpful. I asked one company about driver dimensions and was told to google it...
So I figured I'd see if anybody had any opinions or suggestions.
I've heard the ebay seller industrialpartsshop is a good source but I'm nervous about pairing the correct motors and drives, since they sell them separate, although I haven't asked to see if they'll help with that yet.
I would definitely consider other brands, but yaskawa and delta seem like the best choices to me. I wouldn't mind paying a little more to a company that doesn't mind answering a few questions or is based in the us.
My mesa card sends analog signals so I like the idea of getting analog compatible drives. I know that step/dir and ethercat are possibilities, but I don't know any reasons why I shouldn't stick with analog.
28 Sep 2024 00:01
Replied by tommylight on topic x and y switched
x and y switched
Category: Plasmac
You are welcomed, always.
  • bentiggin
  • bentiggin
27 Sep 2024 23:48
Replied by bentiggin on topic x and y switched
x and y switched
Category: Plasmac
Thanks tommy.
I briefly went through that thread when I first set them up, but am definitely going to revisit it once I get a chance to tune them better. I appreciate you writing that tutorial, I wouldn't know where to start without it.
  • slowpoke
  • slowpoke
27 Sep 2024 23:25
Replied by slowpoke on topic HAL pin to indicate motion or pgm running ?
Category: HAL
If you just want to check for any motion, there is 'motion.current-vel' it is OUT FLOAT, i think you can use COMP for float to bit
Works like a charm, just what I was looking for and thanks for mentioning comp, that's what I used.
  • andreabonuc
  • andreabonuc
27 Sep 2024 22:41
Replied by andreabonuc on topic Constant loss of position
I'll try as soon as I can, but to change the output I didn't touch any wire, I simply removed and replaced the complete terminal, going from output 0 to output 4 which is exactly below.
  • andreabonuc
  • andreabonuc
27 Sep 2024 22:35
the cables are all shielded, I haven't made any changes and the router has been working for almost 2 years without this problem.
Displaying 20836 - 20850 out of 24471 results.
Time to create page: 0.614 seconds
