  • Unlogic
  • Unlogic
26 Sep 2024 21:11
Replied by Unlogic on topic Probe cancellation does not move the axes.
Category: QtPyVCP
Are you changing back to manual mode to enable jogging? When it doesnt complete a subroutine it will be in auto mode.
Maybe not Probe Basic specific... but is there a way to force manual mode via the 'on_abort' process?  So if any of the subroutines (probe, ATC, etc.) fails the machine jumps to manual mode.
If there is a way, that might be a nice-to-have addition to the PB config(s)... don't leave the machine hanging in an aborted auto mode.
That would be a great addition to Probe Basic.
  • PCW
  • PCW's Avatar
26 Sep 2024 21:09
Replied by PCW on topic Help with Mesa 7I97T card Servo wiring
Category: Installing LinuxCNC
If you have a 7I97T you need to have the latest mesaflash
The LinuxCNC ISO includes  version is 3.4.9 which does
not support the 7I97T
github.com/LinuxCNC/mesaflash
 (build instructions on bottom of page)
  • PCW
  • PCW's Avatar
26 Sep 2024 20:57
Replied by PCW on topic Building a chain driven Plasma table.
That means the host computer has a latency issue of some kind
Common causes:
Power management/speed-step/Turbo modes/C states >C1 enabled in BIOS
Network hardware issues with Ethernet connected cards
With Intel MACs you need to disable IRQ coalescing (man hm2_eth)
With Realtek MACs and the LinuxCNC buster release you may need to install
the DKMS RTK8168 driver as the driver included with the shipped kernel is broken
  • Ismacr63
  • Ismacr63
26 Sep 2024 20:38
Replied by Ismacr63 on topic Probe cancellation does not move the axes.
Category: QtPyVCP
I don't know why those modes aren't shown in my version. I just downloaded it, followed the installation instructions and it looked like this.
How can I add them?
  • spumco
  • spumco
26 Sep 2024 20:25
Replied by spumco on topic 8 Spindle Gang Router
Category: Show Your Stuff
There are no "special" parts there that I want or are worth much on their own. It is all of the time I put into building it that I hate to see go for naught. (There is a lot of "me" in that machine.)
Gut-punch understood.
  • spumco
  • spumco
26 Sep 2024 20:13
Replied by spumco on topic Probe cancellation does not move the axes.
Category: QtPyVCP
jog mode is activated.
"JOG" is not a mode.  Even if the on-screen jog button is highlighted, LCNC can still be in MDI or Auto mode.
It looks like your screen has been edited to remove the mode indicator-buttons... or you've got a different version.
I've circled the mode buttons in the attached pic.  You can also open halshow, and under 'halui' add the various mode indicators to the watch list to see what mode LCNC is in.
If, after a subroutine is aborted, LCNC is in Auto mode, you won't be able to jog regardless if the GUI's 'jog' button appears active.
  • Todd Zuercher
  • Todd Zuercher's Avatar
26 Sep 2024 19:50
Replied by Todd Zuercher on topic 8 Spindle Gang Router
  • Ismacr63
  • Ismacr63
26 Sep 2024 19:27
Category: QtPyVCP
  • Creative25
  • Creative25
26 Sep 2024 19:15 - 26 Sep 2024 19:19
Replied by Creative25 on topic Building a chain driven Plasma table.
   I keep getting the following error message on startup of Linuxcnc.Is there something I need to change on the configuration?
  • andreabonuc
  • andreabonuc
26 Sep 2024 18:31 - 26 Sep 2024 18:41
Replied by andreabonuc on topic Constant loss of position
thanks for the answers, I'll start by saying that I'm not very good at configuring linuxcnc and what I came up with is the result of the guided procedure and many tests to make everything work. I do it as a hobby even though I am a milling machine by profession. I don't know if it is possible to move the motors via software but I don't think so, but mechanically everything runs well and everything is lubricated. I also tried inverting the axis motors and even loading the parameters of other axes but nothing changed. I add my .ini file configuration of the x and y axis but I don't see huge differences, but the x and z axis are perfect, the x gives me problems. I have a printnc that I upgraded myself with aluminum components that has a dual motor y-axis and all cables shielded. I attach the ini file and the hal file so you can see what I configured so you can tell me if I'm wrong. If I made a mistake, please tell me in detail what I did wrong so I can understand where to correct it. you wrote to me to try to put 2000 on the direction setting and holding times, but I don't really know which string you are referring to. thanks for your help.
  • PCW
  • PCW's Avatar
26 Sep 2024 17:48 - 26 Sep 2024 17:49
Replied by PCW on topic Constant loss of position
Losing/gaining a fixed amount per reversal may indicate a a step timing issue
with direction (or inverted step polarity).
You can easily check this by setting long direction setup and hold times
(say 20000 ns) and seeing if the issue goes away.
Also in general unless it limits your maximum step rates I would set the
step time to double the manufacturers minimum step pulse width.
  • nartburg
  • nartburg
26 Sep 2024 17:45
Replied by nartburg on topic Mesa 7i96s pktUAT on P1
Category: Driver Boards
will try tomorrow thx
  • spumco
  • spumco
26 Sep 2024 17:40
Category: QtPyVCP
  • spumco
  • spumco
26 Sep 2024 17:35
most likely dump it at a dispersal auction after they take possession of the property
Buy it at auction and strip out the good parts?  You know nobody else will bid on it.
Or make an offer to the existing owner to purchase the components out of the machine before the deal is finalized.
Sorry to hear about the job and situation.
  • G0G53Z148
  • G0G53Z148's Avatar
26 Sep 2024 17:19
Replied by G0G53Z148 on topic Aktuelle hardware mit PCI
Category: Deutsch
ich danke dir das ist genau das was ich gesucht habe. da gibts sogar noch die 2.8.4. warum mit der alten version alles geht udn mit der 2.9.3 nicht ich habe keine Ahnung dazu bin ich zu wenig computer nerd
Displaying 20911 - 20925 out of 24484 results.
Time to create page: 0.504 seconds
