  • AndyDM01
  • AndyDM01
05 Sep 2024 18:43 - 05 Sep 2024 18:45
Replied by AndyDM01 on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
this link would be the latest update? and would not be another install from zero.
only the ethercat part?
still wasn't able to get something moving
  • PCW
  • PCW's Avatar
05 Sep 2024 18:43
First time linux cnc user - no stepper movement.
The critical one would be the "Step-On time" parameter
  • crazycajun
  • crazycajun
05 Sep 2024 18:18
Replied by crazycajun on topic First time linux cnc user - no stepper movement.
thats the one with the drop down box for different drivers correct? if so i selected the k 4030
  • automata
  • automata
05 Sep 2024 18:18
Replied by automata on topic New update on STMBL
New update on STMBL
Category: Driver Boards
What would it take to get the drive ethercat enabled with either microchip lan9252b or with beckhoff ek1100 as an add-on?
Would there be enough interest to take on this sort of a project?
I know that lan9252b is available in a QFP form factor but it may not be the best for a servo drive for throughput over SPI.
Would be great to hear opinions..
- automata
  • PCW
  • PCW's Avatar
05 Sep 2024 18:10
Not calculated steps, but the steplength parameter
  • PCW
  • PCW's Avatar
05 Sep 2024 17:54
Replied by PCW on topic 7i77 TTL encoder
7i77 TTL encoder
The single ended vs differential option is only an electrical interface setting
Its not related to the count scaling at all.
Normally you use 4X quadrature which means you get 4X the number of counts
as the number of lines. That is if the scale has 200 lines per mm, the scale would
be set for 800 (counts per mm)
05 Sep 2024 17:15
Replied by tommylight on topic LMDE6 or Mint 22 ??
LMDE6 or Mint 22 ??
Category: Installing LinuxCNC
No easy way to install LinuxCNC on Linux Mint 22, yet.
05 Sep 2024 17:13
Replied by tommylight on topic 7i77 TTL encoder
7i77 TTL encoder
Not sure, so i can not reply, sorry.
One thing though, "differential" and "single ended" are terms used for wiring of signals where single ended is one wire per signal and differential is 2 wires per signal.
It has nothing to do with "encoder or glass scales", both can have both types of wiring.
05 Sep 2024 16:56
Replied by tommylight on topic install over version 2.8
Version 2.8 is when everything moved from Python 2 to Python 3.
  • crazycajun
  • crazycajun
05 Sep 2024 16:55
i set the calculated steps from 32000 to 5000, no change in operation.
  • crazycajun
  • crazycajun
05 Sep 2024 16:46
Most common issue with no motion is too short step times
I would set the step length to say 5000 and try again
i set the step to 32000 like i had it in mach3. is that too short?
  • crazycajun
  • crazycajun
05 Sep 2024 16:44
also, i am on kernel 6.1.0-7-rt-amd64 with an inspiron 545s
  • PCW
  • PCW's Avatar
05 Sep 2024 16:44
  • zmrdko
  • zmrdko's Avatar
05 Sep 2024 16:36
Ethercat installation from repositories - how to step by step
Category: EtherCAT
just a guess, try:
sudo dpkg-reconfigure ethercat-dkms
  • PCW
  • PCW's Avatar
05 Sep 2024 16:32
7i76e step dir signal missing for stepgen type 0
I would probably set the step space and step length to 5000,5000
and dir setup and dir hold to 10000,10000 on that drive.
That is, double the minimum drive timings.
Displaying 21841 - 21855 out of 24869 results.
Time to create page: 0.384 seconds
