  • Aciera
  • Aciera's Avatar
30 Aug 2024 08:42
Replied by Aciera on topic Is there an easy way to swap axes?
I have converted 2 mills with vertical and horizontal configurations. One does the switch in hal and the other does the switch in a custom kinematic.
I'd like to help but I'm not familiar with configs before 2.8.
  • Masiwood123
  • Masiwood123's Avatar
30 Aug 2024 08:26
Replied by Masiwood123 on topic Is there an easy way to swap axes?
this postprocessor refers to tool center, not tool length, so it exports gcode in relation to how you turned the spindle manually, straight or at an angle,
it calculates the z coordinate in relation to the angle at which the tool is.
  • tivoi
  • tivoi's Avatar
30 Aug 2024 08:23 - 30 Aug 2024 08:23
Replied by tivoi on topic servo motor for a spindle
Category: Milling Machines
Most industrial machine spindle motors are induction type.
can facing and riggid tapping
it is special desgin . Rate about 1500 rpm only, and max is 8000rpm or 10 to 12krpm
  • karlhe
  • karlhe
30 Aug 2024 08:00 - 01 Sep 2024 17:47
Replied by karlhe on topic Probe panel for Axis GUI
Category: AXIS
  • PhilipME
  • PhilipME's Avatar
30 Aug 2024 07:18 - 30 Aug 2024 07:23
Replied by PhilipME on topic servo motor for a spindle
vi.aliexpress.com/item/1005006990514922....ller%7Cquery_from%3A
Thanks for the reply
never knew such thing existed. Actually I asked in several forums including industrial arena, but unfortunately did not get such reply
will the spindle servo have enough torque at low speed? I may have to go low speed for facing toolpath (milling)
  • zmrdko
  • zmrdko's Avatar
30 Aug 2024 06:39
5x10 servo router rebuild - analog of step/dir with mesa card?
I would think that leaving it step/dir would be the easiest path
and would require few wiring changes. It also would not require
changing the drive setup, tuning the drives or tuning LinuxCNC's
feedback loop.
The only real advantage to an analog setup is that you can disable
the drives without losing position.
i have a working setup with mesa 7i95t (step/dir) and Delta B3-L drives. I am using velocity mode and feedback from drive/encoders, so position is kept while disabling the drives. That means you dont have to re-home after powering off, which is useful on long axes.
You have to tune servo drives in position mode first. Then you can switch to velocity mode and tune lixnucnc PID to minimize following error. I was able to reach the peak of ~ 0.005 during accelerations.
github.com/zmrdko/mesa_7i95t_config
  • tivoi
  • tivoi's Avatar
30 Aug 2024 05:42 - 30 Aug 2024 05:45
hi why you dont use spindle servo ?
induction motor with closed loop control, can run position/ speed control
  • G0G53Z148
  • G0G53Z148's Avatar
30 Aug 2024 05:38
Replied by G0G53Z148 on topic Aktuelle hardware mit PCI
Category: Deutsch
Laut anleitung hat 7i96 kein 0-10v (oder ist das nicht dokumentiert)
Auch hat sie nur 6 ausgänge wir brauchen mehr welche Ausgangs karte kann man dazu stecken?
Welche auch in pnc conf Unterstützung findet
Das sind alles fragen die geklärt sein müssen bevor ich noch mehr geld in die hand nehme.
7i76eu wäre die erste wahl doch nicht fertig und 7i76 ausverkauft
Greez from austria
  • RotarySMP
  • RotarySMP's Avatar
30 Aug 2024 05:22
Replied by RotarySMP on topic Is there an easy way to swap axes?
I manually did that to finish the job, but it doesn't address the behaviours like tool length offset which are associated with Z.
  • PhilipME
  • PhilipME's Avatar
30 Aug 2024 05:01
  • PCW
  • PCW's Avatar
30 Aug 2024 03:51
Replied by PCW on topic Aktuelle hardware mit PCI
Category: Deutsch
A 7I96S has built in analog circuitry
Not sure how a 7I76 can damage a 5I25/PC unless a
high voltage (say 12 or 24V) is connected to the 5V pins
  • G0G53Z148
30 Aug 2024 03:05 - 30 Aug 2024 03:07
Category: Deutsch
Das weis ich das 7i76 das kann,
doch diese scheint defekt zu sein und die 5i25 zerstört und weiters das mainboard des Rechners deswegen ja 7i95t oder 7i96 + output karte(welche)
Nur wie pwm in 0-10v regeln
  • PCW
  • PCW's Avatar
30 Aug 2024 01:37
Category: Deutsch
A 7I96S has an analog output
  • onceloved
  • onceloved's Avatar
30 Aug 2024 01:05
Replied by onceloved on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
I'm currently playing Discord. You can add me as a friend. My username is: onceloved.cn
Displaying 22201 - 22215 out of 24901 results.
Time to create page: 0.424 seconds
