  • chienMouille
  • chienMouille
18 Jul 2024 05:34
Replied by chienMouille on topic SMB share refresh question in debian
Category: Installing LinuxCNC
By changes I mean adding a new file or deleting one. Actually didn't try modifying the content of an existing one.
I tried both mounting using mount and using fstab.
Any changes made directly on disk will be reflected instantly in the file browser both in debian and in probebasic. So when the folder is hosted on the machine, even as an smb or nfs share, it does work. It doesn't only when it is a remote share. Like, it works, but I have to manually refresh it to see the changes. Either by F5 command or by exiting and re-entering the folder. (which doesn't work well in probe basic).
This also why the syncthing workaround functions. Because a full copy of the folder is hosted on the machine.
I believe the problem is with the remote share notification protocol.
  • cmorley
  • cmorley
18 Jul 2024 05:06
how to make my own custom page for qtdragon_hd?
Category: Qtvcp
Sorry late answer... but yes looks like you got it.
  • Georgeyork
  • Georgeyork
18 Jul 2024 01:54
Replied by Georgeyork on topic Reading programming off PLD chips (semi OT)
Category: Driver Boards
Have you been able to accomplish this? I have an equipment like this as well and its using a ispLSI 1048E chip controlling an optical equipment and the legacy hardware has no software available from the manufacturer. I understand that through the RS232 a pc was used with a gui program sending commands and then it retrieving data on to the pc for plotting etc. So I cam trying to figure out how to look into the chip with the program and decipher the commands to create a new program to drive this unit. Maybe one of the softwares from the Lattice website can be used to extract and retrieve the software inside the chip etc. Please let me know if you had any success and what angle of approach you took
  • my1987toyota
  • my1987toyota's Avatar
18 Jul 2024 00:35
Replied by my1987toyota on topic Mostly 3D Printed CNC Foam cutter
Category: CNC Machines
ahh don't sweat it . I have been a bit busy today doing research for the LCNC change over from GRBL.
PCW gave me a few Idea's to try out and I already have a basic profile on a 9020 optiplex. The
big thing will be setting the 7i96 to handle temp control of the hot wire.
  • my1987toyota
18 Jul 2024 00:18
Hot wire foam cutter - mapping Z and A axes to U and V
Category: Basic Configuration
I have built a cnc foam cutter with good success . As for the hot wire I have found Nichrome 80 wire
works great see the below link for what should work for you.
www.amazon.com/dp/B07CJ2JG6D/?coliid=I2O...c_wl_lv_ov_lig_dp_it
Thinner usually works better but looses temp faster over longer distances and thus requires higher voltage. I tend to
stay between 22 to 26 gauge and use a 24 volt power supply .I am also  in the process of switching from GRBL to
LinuxCNC and have built a few different types of machines that use LCNC. I am also in the procces of integrating in
a 5th axis on my foam cutter you may find this thread helpful.
forum.linuxcnc.org/30-cnc-machines/52683...-foam-cutter?start=0
  • slowpoke
  • slowpoke
18 Jul 2024 00:07
Replied by slowpoke on topic halui
halui
Aciera, Thanks for that, I can now see the halui stuff in HalShow
I think I'm pretty close, but need a little help troubleshooting please.
The configuration:
Axis connected to an Arduino board, the Arduino board has a couple of digital inputs(6,7) and a couple of digital outputs(8,9) that are linked to LinuxCNC via a python script. The Arduino/Python portion seems to be working just fine, I can trigger Arduino outputs with HAL file links and I can observe digital inputs to the Arduino in Hal Watch.
What I'm trying to do:  when I activate digital input 6 on the Arduino, I want Axis to jog X in the positive direction, (as if I mouse clicked the + "X")
What I have done:  I added the following to postgui.hal:
   net  jog-x-pos  halui.axis.x.plus
   net jog-x-pos  <= arduino.din.6
Arduino input 6 happens to be configured with a pullup, so when I push the button the input goes low, so I set the arduino.din.6-invert bit
What's happening:
When input 6 NOT pushed; arduino.din.6 is yellow (because it's pulled up), halui.axis.x.plus and jog-x-pos are both dark, so far so good
While input 6 IS pushed; arduino.din.6 is dark (it's now low), halui.axis.x.plus and jog-x-pos are both yellow, so far so good
However Axis does not jog. Estop is good, machine power is on, X is selected, just no movement and joint.0.kb-jog-active remains dark.
If I mouse click the actual + jog button in Axis, X moves and the joint.0.kb-jog-active watch LED briefly flashes yellow.
So for whatever reason my button press is not actually causing Axis to jog.
Please see attached, and thanks in advance for any guidance...
17 Jul 2024 23:26
ViaConstructor - Free and Opensource CAM for Linux and Mac
Category: CAD CAM
Made this a sticky so it is easier to find.
Thank you.
  • Ethercatuser
  • Ethercatuser
17 Jul 2024 23:03
Replied by Ethercatuser on topic EtherCat I/O
EtherCat I/O
Category: EtherCAT
Well I'm not fan of windows either but I suppose you'll be happy to hear that the runtime of codesys can be executed on linux and twincat on bsd. I use the preempt-rt patch and a dedicated core to run ethercat. It's surprisingly good 1-7us jitter most of the time and nearly always under 100us.
  • Linuxcncnoob
  • Linuxcncnoob
17 Jul 2024 22:25 - 17 Jul 2024 22:37
Height map and or points to cloud was created by Linuxcncnoob
Hello
What would be needed for Linuxcnc to do a height map and or points to cloud?
something like this >
It has probing options.....my machine is 5x10'
so let say I put a car hood and want it to probe at a set distance intervals ...what are the steps needed?
if I get the coordinates in txt file it would be sufficient for what I need.
Thank you!
  • rodw
  • rodw's Avatar
17 Jul 2024 22:12
Replied by rodw on topic EtherCat I/O
EtherCat I/O
Category: EtherCAT
Thanks for your help, I guess I could create a xml file in the format that I need though it is a little more difficult and I guess I'll find software to do it based on the info you've provided. If it works for you then the indexes must be correct.
I really hope the vendor gets back to me, as much as I'm a bit interested, I don't really want to spend time on this tbh. I hope all the info needed is in the file you have provided otherwise buying a different device would probably be wiser rather than trying to guess some default values added by the software you use which may or may not be in the documentation which is probably aimed at the user level.
Maybe I could ask how you arrived at the addresses for the pdo and sdo index and sub-index?
Some time you might be interested to see what the normal standards are and how they are used with Twincat and Codesys, both can run g-code and twincat is very advanced in that area.
thanks
The addresses I used came from the commands I quoted.
Yes what I did will work.
If you want to make it easier, use Beckhoff hardware as its well supported via single line entriesd in the xml file.
We don't need another motion controller that interprets gcode. We use Linuxcnc for that.
I have no interest in Windows anymore. I use Linux for everything now.
  • Ethercatuser
  • Ethercatuser
17 Jul 2024 22:00
EtherCat I/O
Category: EtherCAT
thanks
17 Jul 2024 21:22
Replied by tommylight on topic Dimensions Slightly Off
Category: Milling Machines
If the same drives are used, and the same motors, and if everything worked before, forget the power supply for now.
In the ini file, set acceleration to 100 for all axis, set the max velocity to 10 for all axis, do some tests.
Any improvement?
  • PCW
  • PCW's Avatar
17 Jul 2024 21:11
Torque mode control to Position (Emergency operating mode)
Typically the position loop ( position input, velocity output) will just have P and FF1
The velocity loop (torque output) is usually P,I but the FF term depends on whether
it has velocity in or position in (FF1 for velocity in, FF2 for position in) In the velocity loop
the feed forward terms are inertia dependent
  • my1987toyota
17 Jul 2024 20:46
Replied by my1987toyota on topic 7i96 non S PWM on an output possible?
On many of the Arduino based stuff they usually repurpose the spindle output for hot wire control.
  • rodw
  • rodw's Avatar
17 Jul 2024 20:25
EtherCat I/O
Category: EtherCAT
I have no idea about anything you are talking about.
I just type ethercat sdos and ethercat pdos and write the xml file we need.
We did work out the deiwu settings and is in my git
github.com/rodw-au/linuxcnc-cia402/blob/...hercat-conf.xml#L158
Note this is slave 3 in my config. That may be different for you.
Some devices, there are existing drivers in the repo I linked earlier but this one we needed to use the generic driver and define its pins. Take the time to read the docs in that repo.
Displaying 24961 - 24975 out of 25308 results.
Time to create page: 0.415 seconds
