  • rodw
  • rodw's Avatar
17 Jul 2024 07:33
Help understanding fundamentals of linuxcnc
This is quite different than using an external encoder
to jog.
I could never work out why Gmocappy added jogging pins. Using external hardware, this is the correct method
linuxcnc.org/docs/stable/html/examples/mpg.html
  • meister
  • meister
  • rodw
  • rodw's Avatar
17 Jul 2024 07:07
Replied by rodw on topic Safety relay and e-stop in LCNC?
Category: Basic Configuration
There are two ways to do this. You can either run an external latch (which is a momentary switch) that resets the safety relay. In this case, you should connect a signal to a Linuxcnc input which is connected in hal to iocontrol.0.emc-enable-in This is the approach I took.
There is no need to press anything in Linuxcnc
The other way is to  use iocontrol.0.user-request-enable instead of your external latch. Linuxcnc sends a pulse on this signal to act as the latch when the on screen estop is reset (S34 in the diagram).
When I researched this, this was compliant provided you isolated Linuxcnc (your controller) with redundant relays (K3 & K4). These needed to be force guided relays where a non conducting pin is forced between the contacts when they are triggered to ensure the contacts cannot become welded closed.
It's good that you used a safety relay with a timer in it can retain control until motion stops.
  • MrStupid
  • MrStupid's Avatar
17 Jul 2024 05:29
XHC-HB04: not work macro mdi_command Fn+macro3/macro4/macro8
On the lathe, I decided to use macro commands when changing tools: Т№M6 G43.
I have 10 instruments in total. I decided to bind these commands to xhc-hb04. I came across the fact that the macro3 macro4 macro8 buttons do not work, although the commands were written in the ini file. In the hal file responsible for the operation of mpg, I saw that these buttons are reserved.
Is it possible to somehow remove/exclude the default spindle control or change the hal file so that macros become active (Fn+macro3/macro4/macro8)?
p.s.
translated and voiced by Google translator
  • pippin88
  • pippin88
17 Jul 2024 05:25
Replied by pippin88 on topic Safety relay and e-stop in LCNC?
Ha e you tried just setting it up in hal as an estop?
I have a simple estop button to LinuxCNC and when I reset the button LinuxCNC comes out of estop.
I still have to hit "power on" on LinuxCNC after reseting estop. This is generally recommended behaviour
Reseting estop should never result in immediate motion
  • PCW
  • PCW's Avatar
17 Jul 2024 04:31
"error finishing read" with Mesa 7i92T on fresh install
Category: Driver Boards
Its very unlikely to be a card issue.
Try the ping command in the previous post to see what the Ethernet latency is.
You also have to disable basically all power management/speed shifting/
turbo modes etc in the PC BIOS
Finally, using isolcpus and pinning the Ethernet to the last CPU can help a lot
If you have isolcpus setup in the kernel command line, you can temporarily
pin the Ethernet IRQ with this script:
File Name: pinirq_2024-07-17.txt
File Size:1 KB
and check that its done the expected thing with this script:
File Name: checkmask_...7-17.txt
File Size:1 KB
  • cmorley
  • cmorley
17 Jul 2024 03:17
how to make my own custom page for qtdragon_hd?
Category: Qtvcp
Did you use linuxcnc-HAL radio/check buttons?
  • cmorley
  • cmorley
17 Jul 2024 03:00
Replied by cmorley on topic Spindle Inhibit while Probing.....
Category: Qtvcp
Yes, Pushed.
Looks like I made a spelling mistake, so it's under a different heading (missing hyphen).
[VERSA_PROBE OPTIONS]
ps_probe_tool = 0
I'll fix that soon.
Chris
17 Jul 2024 02:17
Replied by tommylight on topic Mostly 3D Printed CNC Foam cutter
Category: CNC Machines
Seems very easy to use, thank you.
  • sprintertrd
  • sprintertrd
17 Jul 2024 02:10
Replied by sprintertrd on topic Mesa Configuration Tool
Category: Configuration Tools
Hi JT,
Unfortunately Im not a programmer so I cant help you there but don't you create the file last when you hit save? Aren't all the items you enter placeholders for options that have been selected which will be saved into the file.
Only other suggestion I have is reorder the contents of the tabs so the workflow order is from top to bottom of the tab. IE; picking the default units would be the first item in the Machine Tab, then select Mesa card, then test card,
  • vre
  • vre
17 Jul 2024 01:56
Category: Qtvcp
I have added radiobuttons and checkboxes from qtdesigner
the radiobuttons and checkboxes shown in gui but no hal pins.
How can create the hal pins for radiobuttons ?
  • spumco
  • spumco
17 Jul 2024 01:33
Replied by spumco on topic Mini wannabe datron build
Sounds like you've got a solid plan.  Can't wait to see it.
  • shasse
  • shasse
17 Jul 2024 01:31
Sorry I have not been able to get back to these diagnostics. I tried another type of mini PC with the same failed results. I tried the driver update and kernel parameters from Rod's docs (all the mini pcs were RTL8111 ethernet chipsets), then I used a regular fairly old desktop which ran for much longer but eventually encountered the same issue.
I'm going to order another 7i92T to see if there is potentially a problem with the card itself,
I did at one point flash this with the Path Pilot 7i92T firmware as a part of a previous experiment running Path Pilot on the mini PC, but flashed it to the 7i92t_g540d firmware before all of this. I don't know if anything can persist from the Path Pilot flash process.
Thanks,
Scott
  • my1987toyota
  • my1987toyota's Avatar
17 Jul 2024 00:56 - 17 Jul 2024 01:08
Replied by my1987toyota on topic Mostly 3D Printed CNC Foam cutter
  Oh I agree and the eventual goal is to run linuxcnc on it . For now I am just seeing how far I can
push simple hardware. The end goal will be a 7i96 because I have 2 in my inventory but the newer
S version would work just as well. I don't think MESA makes a cheaper 5 axis ethernet board
then the 7i96S.
as far as free wing design software I use this
www.diyrcwings.com/app/
Displaying 25036 - 25050 out of 25323 results.
Time to create page: 0.413 seconds
