  • cakeslob
  • cakeslob
24 May 2025 17:53
Replied by cakeslob on topic New side panel and axisui pins
Category: AXIS
Hey, you can try this one out, its still got some buts but it does the thing you want
github.com/cakeslob/regularmac_800/tree/search_gcode
  • Hakan
  • Hakan
24 May 2025 17:41
Replied by Hakan on topic help with ethercat and omron drives
Category: EtherCAT
From that Omron thread, it looks like Arvidb got it working, so can you try with the ecat-conf.xml?
<masters>
	<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
		<slave idx="0" type="R88D-KN02H-ECT">
			<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
			<watchdog divider="2498" intervals="1000"/>
		</slave>
	</master>
</masters>
It's the same xml that Arvidb used, but I have changed to what I think it the right model, based on the product code 6 you use.
  • Aciera
  • Aciera's Avatar
24 May 2025 17:30 - 24 May 2025 17:33
Replied by Aciera on topic problems with Verser Probe Screen 2.9
Category: Basic Configuration
You need to remove this from your hal
loadusr -W /home/cnc/linuxcnc/configs/lycnc/psng/python/probe_screen.py
You are already loading probe_screen.py with the EMBED_TAB_COMMAND in the INI.
To troubleshoot the pin problem, comment all lines with 'probe.' pins so the config starts up and use the 'Show Hal Configuration' tool to check if the pins are there.
  • ihavenofish
  • ihavenofish
24 May 2025 17:19
help with ethercat and omron drives was created by ihavenofish
Category: EtherCAT
Sooo, back at my ethercat fun and I think I've made progress, but I'm stuck.
I've gone right to the basics and am just using halshow to poke the drives.
I made a super basic xml file following some other examples on here.
So, following this:
EtherCAT: How to use the dedicated OmrG5 lcec driver? - LinuxCNC $ ethercat slaves shows me my 3 drives just fine
$ ethercat upload -p 0 -t int32 0x6064 0x0 shows me position just fine
$ ethercat safeop doesn't work and returns error 90 because the default sync0Cycle is wrong. This seems expected.
My xml is:
<masters>
<slave idx="0" type="generic" vid="#00000083" pid="#00000006">
</slave>
</master>
</masters>(using the generic driver here cause the omron one was saying no drive found)
then we do this in halshow:
loadrt threads name1=master period1=1000000
loadusr -W lcec_conf linuxcnc/configs/ecat-test.xml
loadrt lcec
addf lcec.read-all master
addf lcec.write-all master
start
All works, except after we get to start, the drives show error 83, and if you look at the pins, its actually cycling through preop, safeop, inti, op, error every so many ms.
So what have I done wrong here, or what do I need to add? The are many gaps in the information and steps people provide so I expect there's just something missing I don't know about.
Thanks!
  • knipknap
  • knipknap
24 May 2025 17:08
Replied by knipknap on topic MESA 7i76E burning out issue
Category: Driver Boards
Thanks a lot for your help!
Now that I hooked up an oscilloscope, the problem disappeared completely again - can't reproduce it anymore, at all.
That made generating pulses easier of course, I simply jogged the thing along. The levels of the step+/- pins on the motor side are around 4.8 volts, and -4.8 on a pulse.
I also noticed that the level between STEP- and the cable shield (GND) is around 40 volts AC (50 Hz). I can't say I understand why that would be so. Is that normal/intended?
  • theoneandonlyoreo
  • theoneandonlyoreo
24 May 2025 16:52 - 24 May 2025 16:54
Replied by theoneandonlyoreo on topic problems with Verser Probe Screen 2.9
It appears that the pins in question (probe.toolchange-change, etc) would be created by probe_screen.py.
In the INI file,
EMBED_TAB_NAME=PSNG
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u psng/python/probe_screen.py -x {XID} psng/probe_screen.glade
EMBED_TAB_LOCATION = ntb_user_tabs
And from custom_postgui.hal
# Ensure all toolchange pins are free to use
unlinkp iocontrol.0.tool-number
unlinkp iocontrol.0.tool-prep-number
unlinkp iocontrol.0.tool-change
unlinkp iocontrol.0.tool-changed
unlinkp iocontrol.0.tool-prepare
unlinkp iocontrol.0.tool-prepared
net tool-change            probe.toolchange-change      <=   iocontrol.0.tool-change
net tool-changed           probe.toolchange-changed     =>   iocontrol.0.tool-changed
net tool-number            probe.toolchange-number      <=   iocontrol.0.tool-number
net tool-prep-number       probe.toolchange-prep-number <=   iocontrol.0.tool-prep-number
net tool-prep-loopback     iocontrol.0.tool-prepare     <=   iocontrol.0.tool-prepared
net tool-prep-loop         iocontrol.0.tool-prepare      <=   iocontrol.0.tool-prepared
#loadusr -W probe_screen
  • cmorley
  • cmorley
24 May 2025 16:49
Replied by cmorley on topic Keyboard shortcut rempaping
Category: Qtvcp
Try this.
in your config folder add folders qtvcp/screens/qtdragon_hd
in the qtdragon_hd folder add this file, name it qtdragon_hd_handler.py
  • Lcvette
  • Lcvette's Avatar
24 May 2025 16:38
Replied by Lcvette on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
for installing qtpyvcp and probe basic use the apt install, it stay updated and will update as updates are available when you run sudo apt update for the system.
the linuxcnc installation seems to be a moving target, i use my own instructions in the stable_quick_start_apt for installing debian and linuxcnc and it seems to be the most reliable. but you technically should be able to do it the way you outlined above. please report back if you get errors.
  • mathwld
  • mathwld
24 May 2025 16:35
Retrofit Gildemeister ct40 was created by mathwld
Hello all,I’m in progress to get information about how to retrofit an old Gildemeister.To make a plan with what to buy and set the proper path. In the begging was pretty clear, new servo, new Vfd, go with ethercat and modbus for spindle. But when o checked today the spindle is a very large dc motor. The amplifier is old but in working condition. A new amplifier have a huge price for this motor. Do you have some suggestion for me?
  • billykid
  • billykid's Avatar
24 May 2025 16:24
Replied by billykid on topic sanmotion rs2a03a0al0w00
Hi Tom, with the new cable all four work. I looked for motors but they ask 200 euros, in your opinion are these drives valid or are new Chinese ones better?
I calculate the cost of the motors because the drives didn't cost me anything.
  • PCW
  • PCW's Avatar
24 May 2025 16:12
Replied by PCW on topic MESA 7i76E burning out issue
Perhaps an output is marginal because of previous damage
I would verify full 5V swing on all step/dir pins.
Here is a simple script to toggle all stepgen step and direction pins slowly:
File Name: stepgens_2...5-24.txt
File Size:1 KB
Download then
chmod +x stepgens.txt
and
./stepgens.txt to run
Note that this needs a relatively recent mesaflash
github.com/LinuxCNC/mesaflash
  • CallumRD1
  • CallumRD1
24 May 2025 16:07
Replied by CallumRD1 on topic Keyboard shortcut rempaping
Category: Qtvcp
I'm running version 2.9.3
  • COFHAL
  • COFHAL
24 May 2025 16:01
W5100S-EVB-PICO stepgenerator and encoder driver
When I open this link: developer.arm.com/downloads/-/gnu-rm, it says: This page is deprecated. See Arm GNU Toolchain for updated content and latest releases. Arm GNU Toolchain.
If I follow Arm GNU Toolchain, many download options appear. Which one should I download?
The truth is, I have little experience doing this type of installation from scratch, and it seems like what you've written on your Github is for experts. I don't know if there's a way to do all these processes automatically with bash.
  • cmorley
  • cmorley
24 May 2025 16:00
Category: Qtvcp
Which version of linuxcnc are you using?
  • tiagounderground
  • tiagounderground
24 May 2025 15:51 - 24 May 2025 16:21
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
i cant tell as am not machining anything, just moving the machine.
with other files this doesnt happen, but the position errors still happens
a lot of times i have drivers out off op state, then back on, i can run the same hardware on standard linuxcnc without any problem
edit:
emcMotionInit: emcTrajInit failed
this message shows in terminal when i start the scurve ethercat config, is this a problem?.
Displaying 3121 - 3135 out of 24893 results.
Time to create page: 0.464 seconds
